SEOS Fusion 10 Pure Assembly - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 09-20-2013, 07:17 PM - Thread Starter
cogeng182's Avatar
This will be a simple picture summary of the assembly as it developes. I know these assemblies have been covered already multiple times but i'm too excited not to post a few pics.
Got the speaker kits and flat packs today. biggrin.gif I couldn't find screws for the woofers, I know they are not floating around in the boxes or attached to the waveguides but I will keep looking.
The gluing has begun.
Question: How thick of material should I use to line the boxes? Polybatting or recycled cotton or some other material?
cogeng182 is offline
Old 09-20-2013, 07:51 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2572
great idea!
2-3 inches thick of fiberglass would be good.
others will have other opinions.
Listen. It's All Good.
LTD02 is offline
Old 09-20-2013, 08:13 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
check inside one of the boxes for the compression drivers for the screwes, or with the Xover parts,
Sibuna is online now
Old 09-20-2013, 08:28 PM - Thread Starter
cogeng182's Avatar
I searched all of the boxes, but no mounting screws besides the ones for the compression driver to waveguide connection. I wonder if the big box stores will have black Hex socket wood screws, doubtful. Should I pick up #8 x 1" ?
Old 09-20-2013, 08:30 PM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
hmmm, the screws that I was sent for mine was just standard 1 inch black wood screws. you can get robinson bit screws under the cabinetry section of HD or Lowes though.
wormraper is online now
Old 09-20-2013, 08:53 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
I normally put them in the box with the crossover parts. But if you ordered the assembled crossovers, there's no box to put the screws in, so I sometimes put the little bag inside one of the ports before wrapping it up. That's also where I put the gasket material for the back of the waveguides.
_______________________
The SEOS Waveguide Project
Erich H is offline
Old 09-20-2013, 09:21 PM - Thread Starter
cogeng182's Avatar
I found the gasket material and the binding posts I ordered inside the ports but no screws. It is also totally possible that they got stuck to some of the paper and tape wrapped around the ports and got tossed in the garbage. No biggy, have to go pick up some other supplies anyway wink.gif
And thanks for the kits, they came much faster than I expected.
Old 09-21-2013, 10:12 AM - Thread Starter
cogeng182's Avatar
Progress. Titebond is messy.
Old 09-21-2013, 12:25 PM - Thread Starter
cogeng182's Avatar
Next question. Installing the ports, do I need to seal them to the baffle, or just glue them in, or just knock them in with a mallet and call it good?
Old 09-21-2013, 12:27 PM
Erich H's Avatar
Liked: 1768
Installing the ports should be one of the last things you do after you get the baffles installed. They'll be tight enough to just push them in. I guess you could use some glue or silicone if you really wanted to, but they seal up pretty good on their own.
Erich H is offline
Old 09-21-2013, 12:41 PM
tuxedocivic's Avatar
Quoted: 1903 Post(s)
Liked: 1724
Install them when you install the drivers, after paint. You won't get them out easily again.
Good luck with the build! If you have any design questions about the kit, ill try and follow along. But if I miss it hit me with a pm.
Ryan
tuxedocivic is online now
Old 09-21-2013, 12:47 PM - Thread Starter
cogeng182's Avatar
Thanks Tux/Erich, I will be careful not to get ahead of myself.
I did get the pre-assembled crossover, I am assuming I hook it up exactly how it is labeled, no need to switch polarity on the CD or anything right?
Old 09-21-2013, 02:20 PM - Thread Starter
cogeng182's Avatar
One Baffle Glued up. One setting. Sanding/filling/sanding next.
Old 09-21-2013, 03:11 PM
Liked: 1724
From memory, the Pure is normal polarity.
Ryan
Old 09-22-2013, 06:54 PM
dclapps's Avatar
Not to hijack your thread, but can you elaborate on the proper polarity required? I have a Fusion 8, and noticed that Erich/someone highlighted the 'reverse polarity' portion of the crossover schematic. What does this mean?
dclapps is offline
Old 09-22-2013, 08:39 PM
Liked: 1724
It means the output from the tweeter side of the cross over goes into the negative tweeter terminal. And the positive tweeter terminal goes into the common ground (negative) on the XO board.
Is yours pre assembled? I'm not sure how Erich is doing it, but if he's labeling thing it might already be reversed and you just hook it up.
Ryan
Old 09-22-2013, 09:38 PM
amo76's Avatar
Quoted: 16 Post(s)
My pre-assembled xover for Tempest already had polarity reversed so I just hooked + to + and - to -. I'd guess he is doing it for all of them.
amo76 is offline
Old 09-22-2013, 09:58 PM
Erich H's Avatar
Liked: 1768
The Tempest does not have reversed polarity.
When MTG90 makes the assembled crossovers, if the design calls for it, he switches polarity in the crossover so the end user simply hooks up the positive to positive and negative to negative just like any other speaker. That's the way other companies would do it to make it easy. The assembled crossovers don't come with schematics, so you would just hook them up the way you would hook up anything else. He has the woofer + and - listed along with the tweeter + and -.
Erich H is offline
Old 09-22-2013, 09:59 PM
dclapps's Avatar
I didn't purchase an assembled one, it was just the components. I hooked it up and the woofer sounded fine, but the tweeter sounded quiet, and not quite right.
I think I need to look into your comment, tuxedo. Does the tweeter, or CD have a positive and negative terminal itself? I didn't see any markings.
dclapps is offline
Old 09-22-2013, 10:05 PM
Liked: 1724
Should be marked, possibly with a red dot. My DNA-205 doesn't have markings, but I have fresh off the factory floor versions. I had to find my polarity with an impulse response, but I'm betting you don't know how to do that wink.gif The version Erich is sending out should be marked. I'd be surprised if not. But who knows.
Also check your wiring and post a photo maybe. Low tweeter level sounds like a padding problem.
Ryan
Old 09-22-2013, 10:14 PM
dclapps's Avatar
I sent you a PM tuxedo.
dclapps is offline
Old 09-23-2013, 06:16 AM
Erich H's Avatar
Liked: 1768
The compression drivers are marked on the terminals from the factory just like the B&C DE10's. They have a red mark on the positive terminal. The only one that didn't was the very first one I sent Tux, because it was the very first factory sample.
Every one after that has the red mark on the terminals because I check each one's frequency response before shipping them. If it didn't have the mark on the terminals, I would know very quickly because it's the first thing I look for before testing. smile.gif
Erich H is offline
Old 09-23-2013, 10:15 AM - Thread Starter
cogeng182's Avatar
Speakers are finished...mostly. Stayed up late last night duratexing, soldering, drilling, lining the cabs, and installing the drivers and binding posts. I will post some final pics later today. I was able to hook them up and give a quick listen at low levels, I was impressed with the details I was hearing and the very nice vocals coming from the speakers. I'm sure they will need some breaking in before sounding their best but so far I like smile.gif I did notice that the default amplitude on my receiver is too high for these speakers, with my old Polk monitor 60's, for low level listening, I usually set it at -30, to get a similar level with these I had to set it at about -40. Can't wait to get home today and crank these up biggrin.gif
To really finish these guys up I need to build some grills and stands. Anyone have some tips on how to install magnets into the baffle?
Old 09-23-2013, 11:14 AM
Liked: 1724
Forstner bit and super glue.
Ryan
Old 09-24-2013, 07:25 AM - Thread Starter
cogeng182's Avatar
And, here is the finished product - ghetto stands included!
I would like to do some measurements. Which usb mic should I get?
UMM-6 or UMIK-1?
The UMM says it measures down to 18hz, max db = 127
The UMIK is down to 20hx, max db = 133
Anything else I need to consider?
Rush Tempo likes this.
Old 09-24-2013, 07:38 AM
Liked: 1724
I have the UMIK that I got from cross spectrum, but if you don't wanna pay for the extra calibration, it has to come from Hong Kong. The UMM comes from parts express and that's handy.
They look fantastic. Had a chance to hear them yet?
Ryan
Old 09-24-2013, 02:11 PM
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Looks great!!! I hope mine turn out that nicely too. How do they sound?
mmarki is offline
Old 09-24-2013, 06:39 PM - Thread Starter
cogeng182's Avatar
Tux I didn't see you post before I ordered the UMIK directly from MiniDsp, didn't realize that it would ship from Hong Kong lol.
I did quite a bit of listening last night, I think that music sounded great but I can tell that streaming MP3's will probably not get me the quality that these speakers are capable of. I did try one of the music HT demo disks provided by one of the forum members and that was really just excellent biggrin.gif
Movies surprised me a bit, I thought that the dynamic swings were big before, hah!, now they are borderline deafening, which may be okay for very short bursts but I may have to work on a solution for listening while the little one is sleeping.
For me, these are excellent speakers. I still do want to measure just because I am paranoid that I may have damaged a CD when soldering AND i think it will be fun to learn how to do measurements wink.gif
Old 09-24-2013, 08:28 PM
Liked: 1724
It'll come fairly quick from Hong Kong. Or at least people report that it does. It's pretty hard to over hear a CD with a soldering iron.
Ryan
Old 09-24-2013, 08:46 PM - Thread Starter
cogeng182's Avatar
Listened some more.... I'm fairly certain that I couldn't get the high quality sound I am hearing if one of the CDs was damaged. I really cranked up the level while listening to Pendulum - The Tempest , credit to Sibuna, and I was VERY impressed. I need to start collecting some really good source material now. What format is generally available for this? DVDA/SACD?
