Celestion 15" to AE TD15M - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By rajacat
post #1 of 30 Old 09-23-2013, 09:06 AM - Thread Starter
Willie's Avatar
Quoted: 78 Post(s)
Liked: 110
I recently did a cheap thrill build. Wondering if there is a crossover design out there that will work for swapping out the Celestion 15" for a AE TD15M-8, and replacing the the DNA-350 with the 360. Cabinet is sealed. Is it nuts to want to do this?
I pretty much drive by the AE facility on my way to and from my office, so it just seems like I should . . .
Willie is offline
post #2 of 30 Old 09-23-2013, 11:56 AM
Erich H's Avatar
Quoted: 1453 Post(s)
Liked: 1868
What are you hoping to gain?
_______________________
The SEOS Waveguide Project
Erich H is offline
post #3 of 30 Old 09-23-2013, 01:49 PM - Thread Starter
Willie's Avatar
Quoted: 78 Post(s)
Liked: 110
That is an excellent question. I am not dissatisfied with the Celestion at all. I think more than anything I would like to hear a speaker that cost roughly 6X as much; has to sound better, doesn't it? However, if the difference is only audible at reference levels then maybe not.
Willie is offline
post #4 of 30 Old 09-23-2013, 04:13 PM
mobeer4don's Avatar
Quoted: 130 Post(s)
Liked: 128
You might be surprised how little difference the 6x in price will make. I'm not knocking AE, I use the TD15M in my mains. The Celestion was an absolute steal at $50.
mobeer4don is offline
post #5 of 30 Old 09-23-2013, 06:41 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 180
If you do indeed end up buying the TD15's for replacing the Celestion woofers, then I would be happy to buy the Celestion woofers from you, should you decide to sell them! If so, keep me in mind and send me a PM!
Martycool007 is offline
post #6 of 30 Old 09-23-2013, 11:04 PM
LTD02's Avatar
Quoted: 2461 Post(s)
Liked: 2781
"I recently did a cheap thrill build. Wondering if there is a crossover design out there that will work for swapping out the Celestion 15" for a AE TD15M-8, and replacing the the DNA-350 with the 360. Cabinet is sealed. Is it nuts to want to do this?"
i'm pretty sure that there is a td15m/dna360 crossover floating around. the size of the cab and whether or not they are ported shouldn't matter as I don't believe baffle step correction is built in, but I don't remember where the plan is.
Listen. It's All Good.
LTD02 is offline
post #7 of 30 Old 09-23-2013, 11:05 PM
LTD02's Avatar
Liked: 2781
LTD02 is offline
post #8 of 30 Old 10-04-2013, 01:24 PM - Thread Starter
Willie's Avatar
Quoted: 78 Post(s)
Liked: 110
Broke out some Sonny Landreth including a duet with Joe Satriani today. The Celestion/SEOS combination is pretty sweet. After reading the original bwaslo design thread at DIYSoundgroup I am guessing I probably don't really need the upgrade to the TD15M; since I don't listen to anything much louder than about 75-80dB. Bwaslo's comments suggest that the benefits of the AE didn't become evident till much louder.
If I am not careful I am going to end up with a garage full of speakers and parts . . . eek.gif
Willie is offline
post #9 of 30 Old 10-04-2013, 03:10 PM
ChopShop1's Avatar
Quoted: 323 Post(s)
Liked: 319
ChopShop1 is offline
post #10 of 30 Old 10-05-2013, 11:37 AM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
When bwaslo compared the AE15M to the Celestion 15" was the incorrect polarity issue evident and taken into account at the time? If it wasn't then the SQ comparison should be repeated with the polarity problem corrected.
Mfusick likes this.
rajacat is offline
post #11 of 30 Old 10-05-2013, 12:44 PM - Thread Starter
Willie's Avatar
Quoted: 78 Post(s)
Liked: 110
I don't know the answer to that. I will say I am still vacillating on whether or not to try the TD15M/DNA-360/SEOS-12 combo in my cheap thrill cabinets.
Matt G.; if your reading this I am looking forward to you posting the upgraded crossover parts for the TD15/SEOS-12/DNA-12 in the thread at DIYSoundgroup. After I see the parts list I will most likely make the switch. (Unless someone talks me down).
Willie is offline
post #12 of 30 Old 10-05-2013, 01:10 PM
LTD02's Avatar
Liked: 2781
"After I see the parts list I will most likely make the switch. (Unless someone talks me down)."
from what I've seen so far, matt's new crossover looks to be bees knees.
for folks who haven't seen it, go here: http://www.avsforum.com/t/1457166/s-e-o-s-r-mega-build/1110#post_23796258
then go buy a set. :-) (not sure what nominal impedance is on that one...4 or 8)
LTD02 is offline
post #13 of 30 Old 10-05-2013, 02:26 PM
ChopShop1's Avatar
Quoted: 323 Post(s)
Liked: 319
I will pm you the parts list and schematic this evening. It's about a hundred bucks per unit.
post #14 of 30 Old 10-05-2013, 02:31 PM
ChopShop1's Avatar
Quoted: 323 Post(s)
Liked: 319
Scratch that pm, here it is....
post #15 of 30 Old 10-05-2013, 02:36 PM - Thread Starter
Willie's Avatar
Quoted: 78 Post(s)
Liked: 110
You guys rock!
Willie is offline
post #16 of 30 Old 10-05-2013, 02:54 PM
LTD02's Avatar
Liked: 2781
that's a 4 ohm nominal speaker though, correct?
LTD02 is offline
post #17 of 30 Old 10-05-2013, 02:58 PM
ChopShop1's Avatar
Quoted: 323 Post(s)
Liked: 319
Yep
Willie, I'll have two of these up and running very soon (hopefully in the next week). While I don't have any time in front of the cheap thrill, I have plenty in front of the Sentinel, Tempest and some of the smaller ones. I'll give you my best subjective comparos as soon as I get them done.
post #18 of 30 Old 10-05-2013, 03:10 PM
mtg90's Avatar
Quoted: 462 Post(s)
Liked: 885
It's a fairly easy 4 ohm load, iirc it stays above 5 ohms above 80hz so most amps or avrs will have no trouble driving it. I'll run an impeadance sweep tonight to double check that figure. I am also going to try and get crossovers worked up for both the 8 ohm td15m and bms 4550 (16 ohm) designs based off the current design so there should be quite a few options to choose from.
mtg90 is offline
post #19 of 30 Old 10-05-2013, 03:47 PM - Thread Starter
Willie's Avatar
Quoted: 78 Post(s)
Liked: 110
Currently I am driving LCR with a Denon 4311, 4 ohms will be fine.
Willie is offline
post #20 of 30 Old 10-05-2013, 04:30 PM
Erich H's Avatar
Liked: 1868
The Celestion buy-out was a freak of nature woofer. Don't let it's low price worry you.
Erich H is offline
post #21 of 30 Old 10-05-2013, 04:40 PM - Thread Starter
Willie's Avatar
Quoted: 78 Post(s)
Liked: 110
The voice of reason crying from the wilderness.
In other words, if you want to spend 1200 bucks, spend it on something that will give you more return on your investment. Geez, when you put it that way . . .
Willie is offline
post #22 of 30 Old 10-05-2013, 05:30 PM
LTD02's Avatar
Liked: 2781
"Currently I am driving LCR with a Denon 4311, 4 ohms will be fine."
i'm not concerned about the guys who know what they are doing...i'm concerned about the guy who reads how awesome the speakers are, builds a set, cooks his avr and starts thread: td15m/seos kit killed my avr!?! help?!? :-)
LTD02 is offline
post #23 of 30 Old 10-05-2013, 06:24 PM
mtg90's Avatar
Quoted: 462 Post(s)
Liked: 885
Here is the measured impedance for the new TD15M design, not quite as high as I first thought but most amps will still drive them with no trouble unless you like running them at high volumes for long periods of time in which case using an amp rated for 4 ohms would be the safest bet.
mtg90 is offline
post #24 of 30 Old 10-05-2013, 07:40 PM
LTD02's Avatar
Liked: 2781
that looks quite amp friendly actually only a couple dips down to 4. i agree completely with your assessment.
LTD02 is offline
post #25 of 30 Old 09-28-2014, 03:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Stupid question but this would work with the SEOS 15 instead of coarse right ?
Mfusick is offline
post #26 of 30 Old 09-28-2014, 03:49 PM
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 174
If you're getting rid of your celestions I wouldn't mind getting one or two off of you. One of mine went the way of the buffalo and I need a replacement
wormraper is online now
post #27 of 30 Old 09-28-2014, 05:24 PM
tuxedocivic's Avatar
Quoted: 2135 Post(s)
Liked: 1996
[QUOTE=Mfusick;40762]
No
tuxedocivic is offline
post #28 of 30 Old 09-28-2014, 05:56 PM
Erich H's Avatar
Liked: 1868
I kept some extras just in case.
Erich H is offline
post #29 of 30 Old 09-28-2014, 06:13 PM
wormraper's Avatar
Quoted: 321 Post(s)
Liked: 174
That would be awesome! It was that one that I accidentally punched through the surround when I built my trio and ended up gluing. It held for a while but the tear also had nicked the cone and the vibrations were causing the paper to tear little by little....do you want me to pm you to work out the details?
post #30 of 30 Old 11-05-2014, 06:08 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Did you get your driver ok ? How does the cheap thrill compare to other speakers ?
Mfusick is offline
