3x SEOS Fusion 10 Pure Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 83 Old 09-23-2013, 05:33 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
This is my first DIY build, so I figured I would start a thread. After emailing Erich a bunch, I decided on the Fusion 10 Pure for my LCR in my theater. He was very helpful and answered all my questions. I received my order last Thursday, everything arrived safely, Erich has some, great packing skills. I was able to start Saturday night, things went smoothly, I thought for my first attempt at anything like this. I have to mention that i did watch Java's assembly video before I started, it was very helpful. A few pics:
I have finished two so far and just started on the third tonight. I hope to finish it tomorrow night. Then I will start filling and sanding, hopefully be done with that by the weekend. I'm sure I will have some stupid questions along the way, thanks in advance to those who will help me. I'll be updating with some pics as I make progress. Thanks again to Erich at DIY Sound Group, he's been very helpful and informative. If it wasn't for him, I wouldn't be attempting this.
Wish me luck!!
Matt
mmarki is offline
post #2 of 83 Old 09-23-2013, 08:53 PM
tuxedocivic's Avatar
Quoted: 1903 Post(s)
Liked: 1724
Hey, good luck with your build. Did you get the assembled XOers. ?
Ryan
tuxedocivic is online now
post #3 of 83 Old 09-23-2013, 09:02 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
I did. I chickened out this time, I felt this was a big enough step for me as it is, and I didn't want to screw anything up either. If things go well, so far they have, I will build some surrounds too. Either one of the 8" models or I heard there are some smaller designs in the works. I have NO woodworking skills, so I feel like I am limited to what flat packs are available. Unless I can talk a friend of mine into helping me with some baffles etc...
Tux, I thought I saw in another thread that you recommend soldering the speaker wire to the drivers over using clips, any reason why? Clips seemed like the easier way to me, (I think?)
mmarki is offline
post #4 of 83 Old 09-23-2013, 09:09 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
Matt
Thanks. But keep in mind, this is a group effort. Tux designed the speakers and others helped with the SEOS. I'm the one just trying to bring them together.....and package things with a lot of foam! biggrin.gif But without the designers, I'd just be shipping out pieces of wood surrounded by styrofoam!
As for the terminals. If you're not really good, I wouldn't solder the wires on the compression driver. If you have the heat setting high, and leave it on the terminal for too long, you can melt things.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #5 of 83 Old 09-23-2013, 09:17 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
That's one of the things I was worried about. I've never soldered anything in my life. I'll just go ahead with the clips then. I should have thanked everyone involved too, I'm sorry I didn't. I do understand there is a lot of effort put forth by numerous people. I think it's great things are consolidated for people like me.
And I forgot the, the assembled crossovers look great, no way I could have made them look that good, thanks MTG.
mmarki is offline
post #6 of 83 Old 09-23-2013, 10:28 PM
Liked: 1724
Nothing wrong with clips. Solder is more secure though. No sound difference.
Ryan
post #7 of 83 Old 09-23-2013, 10:39 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Thanks. I didn't think so, but it's always good to hear from a designer. Also, I was going to use speaker wire from the binding posts to crossover and crossover to driver. Is any gauge wire ok?
mmarki is offline
post #8 of 83 Old 09-24-2013, 07:40 AM
Liked: 1724
Any gauge is fine. It's quite a short run.
Ryan
post #9 of 83 Old 09-24-2013, 08:35 AM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Thanks Tux. Just a warning, the stupid questions will continue.
mmarki is offline
post #10 of 83 Old 09-24-2013, 09:10 AM
Liked: 1724
No problem!
Ryan
post #11 of 83 Old 09-24-2013, 08:28 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
I finished assembling all 3 tonight. I've been really busy at work, so I haven't had much time to work on the speakers and try to spend time with my family. 3 year old son and a wife that's about 8 months pregnant, so they both keep me busy too. It ended up being a little easier than I expected, although I didn't know what to expect. I should have some time tomorrow for wood filler and sanding. DuraTex should arrive Thursday too. Looking forward to completing them over the weekend I hope. I'm not sure what I should use to stuff the speakers, or how much?
mmarki is offline
post #13 of 83 Old 09-25-2013, 08:41 AM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Since I have no measuring equipment, and I will probably be building more SEOS speakers in the near future, I was thinking of ordering the Omimic from Parts Express. Seems like it's pretty easy to use.
mmarki is offline
post #14 of 83 Old 09-25-2013, 09:16 AM
cogeng182's Avatar
The High loft stuff from walmart was exactly what I used. I just unrolled it but kept it folded up, then hacked nice thick pieces off. Seems to work okay.
cogeng182 is offline
post #15 of 83 Old 09-25-2013, 10:19 AM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Thanks, I thought the high loft stuff would be better. I feel stupid for asking lots of questions, but I don't want to make a mistake either.
mmarki is offline
post #16 of 83 Old 09-26-2013, 02:04 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Another question, I was told it would be possible to put the crossover in the vertical brace, is there is enough room. I took a pic before I assembled the cabinets. Does this look like enough room between crossover and driver? I think it's 2-3 inches maybe a shade more, of course I didn't measure. Thanks
mmarki is offline
post #17 of 83 Old 09-26-2013, 02:22 PM
mtg90's Avatar
Quoted: 412 Post(s)
Liked: 778
Yeah that should be enough room between the driver and crossover.
mtg90 is offline
post #18 of 83 Old 09-26-2013, 02:24 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Thanks for the response. What would the problem be if they were too close together? Also, I bought the preassembled crossovers, you did a beautiful job on those.
Thanks, Matt
mmarki is offline
post #19 of 83 Old 09-26-2013, 02:27 PM
Liked: 1724
To close to the magnet/coil you'll get electromagnetic intereference with the inductors. = Bad.
Ryan
post #20 of 83 Old 09-26-2013, 02:33 PM
cogeng182's Avatar
I ended up velcro-ing mine in the top half on the side, hopefully it stays attached.
post #21 of 83 Old 09-26-2013, 02:33 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Ok. Maybe I'll just put it on the back panel to be safe. But I was also worried about not being able to put polyfill in the section where the crossover would be too. Would that cause a problem?
Also I know I need a 1/4 inch bit to drill for the binding posts, but what size bit do I need to the screws to mount the driver/waveguide? Again sorry for the stupid questions I just don't want to make a mistake.
mmarki is offline
post #22 of 83 Old 09-26-2013, 02:34 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
I thought about that too. Did you put polybatting around it or leave that area unstuffed?
mmarki is offline
post #23 of 83 Old 09-26-2013, 02:37 PM
cogeng182's Avatar
I left that area and the area where the binding posts come through unlined. Don't know if that is ideal.
Edit: the general area where the binding posts are at is lined, just left a small bit unlined where they come through.
post #24 of 83 Old 09-26-2013, 02:46 PM
Liked: 1724
XO'ers don't relaly get hot. The resistors can build up some heat if you're really given 'er. But unlikley to cause any problem. I wouldn't worry about it. Unless someone knows better than me.
I'm not sure what you mean by the screws. You wanna drill a pilot hole? Maybe 3/64ths.
Ryan
post #25 of 83 Old 09-26-2013, 03:15 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
That's what my plan was, but again, just wanted to make sure before I start. Thanks again
mmarki is offline
post #26 of 83 Old 09-26-2013, 03:16 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
That's what I meant, I was typing on my phone and my brain got ahead of my fingers. Thanks.
mmarki is offline
post #27 of 83 Old 09-26-2013, 04:24 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
I got busy at work again, so I won't have much time tonight or tomorrow to do anything with the speakers. I'll post a few more pics of my progress later. My plan is to drill pilot holes for the waveguide/drivers. Spray paint the area around both (black), then apply 2 coats of duratex. After that, drill and mount binding posts, mount crossover, stuff/fill the walls of the cabinet, hook up/install drivers. Hope to get all that done on the weekend between family things too. Is there anything I'm missing/forgetting about?
mmarki is offline
post #28 of 83 Old 09-26-2013, 04:39 PM
cogeng182's Avatar
Sanding/filling/sanding again? I did this and I could still see some seams after one coat of duratex, after two coats I didn't notice any seams.
post #29 of 83 Old 09-26-2013, 04:54 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
I thought about that too. I'll check again and see what it looks like when I get home, but like you, I plan on 2 coats of duratex so I might be ok. Thanks for all your help, I appreciate it.
mmarki is offline
post #30 of 83 Old 09-26-2013, 07:40 PM - Thread Starter
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
Got a little sloppy with the wood filler. Did that last night while the wife and kid were gone.
Sanded this morning before work. Happy with the results, although some seams are still visible. Don't know if I'll fill and sand again over the weekend or not. I might just start with the duraTex.
mmarki is offline
