Woofer to equal TD12m - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 09-27-2013, 03:28 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
I am looking for a woofer to use in a future project and want TD12m quality without the 1 month+ wait.
I have looked on US Speaker and PE and there are many options out there. Would, for example purposes, the B&C 12 NDL76 or the FaitalPRO 12FH520 be equal replacements?
-I would be crossing to subs no lower than 80hz. and cross to the tweeters from 1000-1500.
-This would be an active W-T-W arrangement with a MiniDSP.
-Or are there advantages to a Tweeter on top with the 2 woofers side by side below. I can do either in my room.
Thanks for any help.
Moto
MX48 is offline
post #2 of 31 Old 09-27-2013, 03:52 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
LTD02 is offline
post #3 of 31 Old 09-27-2013, 03:53 AM
LTD02's Avatar
Liked: 2576
is it a full range project? what are you using for the top end?
Listen. It's All Good.
LTD02 is offline
post #4 of 31 Old 09-27-2013, 04:10 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Thanks for the link.
Don't you sleep?!
I usually don't put out all the info on an open forum as sooner or later (usually sooner) I show my ignorance.
However, this may help some other ignorant dufuss (sp?) so I will go ahead.
-I will cross to subs no lower than 80hz so no not full range.
-I have been wanting to try a ribbon tweeter and would love the TPL 150H but sadly it is out of my price range. Thinking about the CSS Planar 2.
-I have Deltalite 2512's now but have assumed that they were a step or 2 down from the TD's.
-Is it better to put the woofers side by side below the tweeter or W-T-W? I can do either in my room.
As always, thanks to you and everyone that has continued to help me and many others here.
Moto
MX48 is offline
post #5 of 31 Old 09-27-2013, 04:33 AM
LTD02's Avatar
Liked: 2576
"Thanks for the link.
Don't you sleep?!"
<-- sleep?
have you seen this?
http://www.avsforum.com/t/1484902/creative-sound-solutions-planar-2-tweeter
also, have you tried the 2512/seos/dna360/bwaslo crossover combo?
LTD02 is offline
post #6 of 31 Old 09-27-2013, 04:43 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
I am using a DNA 360/SEOS with two of the 2512's (active). I just am ready to try something different and was wondering what woofers were considered upgrades.
MX48 is offline
post #7 of 31 Old 09-27-2013, 05:28 AM
LTD02's Avatar
Liked: 2576
"I am using a DNA 360/SEOS with two of the 2512's (active). I just am ready to try something different and was wondering what woofers were considered upgrades."
i see.
have you taken a look at the 12nmb420 from 18sounds?
LTD02 is offline
post #8 of 31 Old 09-27-2013, 05:42 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
A quick search didn't show any place to buy it in the US.
Looks good tho.
MX48 is offline
post #9 of 31 Old 09-27-2013, 07:09 AM
servojohn's Avatar
Looks good tho.
18 Sound distribution is sketchy in the U.S., and I don't have a lot of confidence that it'll improve.
BMS, B&C, and Faital Pro are available, and make high quality products. It's a matter of seeing if they have one that suits your intended design.
Best regards,
John
servojohn is offline
post #10 of 31 Old 09-27-2013, 07:38 AM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
In the tests that are in the link in post 2 the Faital Pro 12PR300 was tested and found to be closest of the group to the TD12M. I'm using them in my LCR's in my theater now and they sound very clear and punchy.
tsloms is offline
post #11 of 31 Old 09-27-2013, 07:45 AM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1726
I've been eyeing the 10" Faital Pro 500 and 530 models since PE started carrying them. But they don't seem to offer a very good bass/sensitivity ratio. The 12" might be better.
I wouldn't do side by side woofers unless crossing VERY low. Like 600hz or something. I only have one experience with side by side drivers and the directivity was really strong.
I guess I should update my Planar 2 thread with my XO and photos. I keep forgetting redface.gif
Ryan
tuxedocivic is online now
post #12 of 31 Old 09-27-2013, 07:56 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Great, thanks for the help. Leading contender for now is the 12PR300, @ $215 it's not too bad. Good to know someone has used and liked them.
Will definitely go W-T-W which is what I have always done anyway.
Moto
MX48 is offline
post #13 of 31 Old 09-27-2013, 08:05 AM
LTD02's Avatar
Liked: 2576
just out of curiosity, is there some reason to believe that a superior driver to the 2512 or just different?
LTD02 is offline
post #14 of 31 Old 09-27-2013, 08:10 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Would really be great if someone with experience with the 2 can answer that question. I already have 6 of these.
MX48 is offline
post #15 of 31 Old 09-27-2013, 08:12 AM
LTD02's Avatar
Liked: 2576
faital likes to "smush" their plots which is fine, just makes them difficult to compare to the eyeball.
here is the 2512 and the 12pr300 on the same scale.
LTD02 is offline
post #16 of 31 Old 09-27-2013, 08:19 AM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
There was an old thread on here a while back that compared the Faital and 2512. They were very close to each other but it was deemed that the Faital was easier to design a XO for since it does not have the response rise like the 2512.
tsloms is offline
post #17 of 31 Old 09-27-2013, 08:41 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
IMO it's hardly better than an Eminence Basslite 2012, and pales compared to a Deltalite II 2512.
This is a quote from a speaker designer on another forum discussing the Faital Pro PR300.
MX48 is offline
post #18 of 31 Old 09-27-2013, 09:20 AM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
Did he perform testing to verify that the faital wasn't good? The link in that 2nd post does have several measurements to compare between the 2. I actually am using the exact 12pr300 that was tested back then. I have a pair of the 2512's in my garage speakers as well. The 2512 and 12pr300 are much more similar than different. For me as I said previously it was a matter of making for a simpler xo design which swayed my decision.
I'm putting 300 watts into the faitals and they sound great.
tsloms is offline
post #19 of 31 Old 09-27-2013, 09:37 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
I really don't know how he came to that conclusion. I think the important part there is the IMO part.
I probably shouldn't have posted that without some sort of explanation.
MX48 is offline
post #20 of 31 Old 09-27-2013, 11:43 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
How about the 2206H's.
They can be had on Ebay at reasonable prices.
MX48 is offline
post #21 of 31 Old 09-27-2013, 11:57 AM
LTD02's Avatar
Liked: 2576
it's not quite as delicate as some of the others, which is good and bad.
LTD02 is offline
post #22 of 31 Old 09-27-2013, 12:08 PM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
How do you mean?
MX48 is offline
post #23 of 31 Old 09-27-2013, 12:12 PM
LTD02's Avatar
Liked: 2576
the beefier coil leads to higher normalized inductance. the more rugged suspension is tighter. i mean it to be a great mid-woofer, but maybe not the first choice if that last bit of sound quality is what someone is shooting for.
LTD02 is offline
post #24 of 31 Old 09-27-2013, 12:13 PM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
OK, thanks.
MX48 is offline
post #25 of 31 Old 09-27-2013, 03:32 PM
John_E_Janowitz's Avatar
Quoted: 26 Post(s)
Liked: 81
Parameter wise, there are similarities with the 12PR300. They can work in the same size enclosure and have similar response curve. The Faital is really not a replacement though if you look at the measurements. It is a good driver as are many others. Once someone listens to the TD woofers though then tries to go back, they notice the huge differences. Quite simply there is no driver available that can do everything the TD12M can do from the low distortion, linearity, and high bandwidth without resonance. Unfortunately lead times are long because of the extensive process we go through here and the care we put into building them here in the US. It is hard to keep up with the demand when I am personally building most every driver.
As far as the comparison of the Faital goes, take a look through the measurements on drivervault and you will find the following:
The Faital has over 20dB more 3rd Harmonic Distortion than the TD12M everywhere in the midrange band.
There is nothing to linearize inductance in the Faital as evident in comparing the Le(x) curves between the two.
If you look at the CSD plot of the Faital there is a massive resonance at 2KHz due to the dustcap breakup
The multi tone distortions show huge increases in distortion in the Faital
https://sites.google.com/site/drivervault/driver-measurements/tang-band-75-1558se/ae-speakers-td12m/
https://sites.google.com/site/drivervault/driver-measurements/tang-band-75-1558se/faitalpro-12pr300
For an inexpensive ribbon to use, the Dayton AMTPRO-4 looks to be a good option and very reasonably priced. I haven't used one yet, but they look very promising. I intend to get a few soon to experiment with.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=275-094
John E. Janowitz
Acoustic Elegance, LLC
"Learn from the mistakes of others... you can't possibly live long enough to make them all yourself"
John_E_Janowitz is offline
post #26 of 31 Old 09-27-2013, 03:41 PM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Thanks John,
If it weren't for the long lead times I would undoubtedly go with the TD's.
Thanks for the response.
MX48 is offline
post #27 of 31 Old 09-27-2013, 04:20 PM
Quoted: 26 Post(s)
Liked: 81
Just FYI, the last of the current DIY retail orders on our build list are in process and are expected to be finished next week. We had been waiting on steel parts that arrived back earlier this week. As those are finished up, I then have some room to be building over the next two weeks. An order placed now I would expect to ship by Oct 11 as long as a large amount of orders don't come in first.
John E. Janowitz
post #28 of 31 Old 07-02-2015, 12:42 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is offline
post #29 of 31 Old 07-02-2015, 01:23 PM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
I went thru several iterations. I had Deltalite 2512's (still have 6 of them not being used) with B&C 8CXT's. Then with some of the CSS Planar 2 ribbon tweeters. Then I went back to the 8CXT's. Then I found some TD15m's used and am now using them with the B&C's. All these were M-T-M.
I would like to get some of the BMS4594's but they are so expensive. Plus I don't listen to that much music anymore, especially since grooveshark went down. I don't think I have that discerning of an ear either, maybe cause I am old. Also I have a very well treated room and the speakers are calibrated and in a baffle wall. IMO all these things contribute to many of the good quality speakers sounding more alike than not.
As always YMMV.
Moto
MX48 is offline
post #30 of 31 Old 07-04-2015, 08:09 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
...B&C 8CXT's. Then with some of the CSS Planar 2 ribbon tweeters. Then I went back to the 8CXT's. ...
Curious what you thougt of the 8CXT's (I have eight of them for surrounds in an Atmos system) compared with the planars.
Noah
noah katz is online now
