Dual LMS 5400 Ultras - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 142 Old 04-08-2014, 09:09 PM
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
Congrats on the Ultras! Welcome to the club. The sound you are looking for comes from more power to these as the others have said. I started with the ep4000 bridged to each and then went to the clone fp14000, and the difference is huge. Pm me and we could work something out if you want to hear the Ultras powered with the fp since I think we live within 20 minutes from each other.
d_c is online now
post #122 of 142 Old 04-08-2014, 09:19 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1557 Post(s)
Liked: 1346
Originally Posted by kcnitro07 View Post
I purchased 2 20 amp circuit breakers for the amps, but they'll be installed in the basement where my home theater will hopefully be moved this summer. That would put 3 circuit breakers total biggrin.gif
David,
I understand exactly what you're saying. WHen I did research a while ago (I am a bit foggy on the details) the IPR7500 looked to not be bridgeable and thus I chose against it as its "rated" power was lower than the "rated" power of the EPX (not EP) I have. The EPX is "rated" at 3000 watts rms and 4000 watts peak and thus I figure its probably good for 2000 ish rms, though I haven't bench tested that. At the current moment if I turn it up I have power issues, so right now its more than enough for the room I'm in. plus...I have wood floors up here so I get plenty of shaking going on. I don't need it to hit 130 dB, my goal was to get bottom end which I have achieved so I'm happy. If, when I move to the basement, I feel my set up is underpowered because I have lost the vibrations from having a concrete floor, I might upgrade, but until then I'm happy with what I have.
I am not offended by your comments, I'm not as much of an audiophile as most of the visitors on this forum, for the most part I visit only when I buy something new...I come because I want opinions but mostly I just enjoy watching movies and I think my set up with the EPX4000s will satisfy plenty.
Very cool. It doesn't matter what sub or amp, it's the results that count, so I'm glad you are happy. Rock on!
And I know what you mean on the amps. I never did find the perfect amp(s) for my LMS 5400s, which is why I went with the SpeakerPower SP2-8000, and that still isn't enough to get the most out of them. Maybe the SP2-12000(240V) would have been good but I didn't want to be slave to a 240V circuit.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #123 of 142 Old 04-09-2014, 09:08 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
So for fun I did some testing. I set my volt meter up on my speaker inputs and cranked it with a 80 hz test tone. with the receiver maxed out and the amp gain all the way up my multimeter registered 87 volts. WHen I test ohms it was bouncing around from 4.1 to 4.4 which would make the watts between 1720 and 1840. The amp's lights were maxed out but not clipping. However, I can't go any louder than that as my receiver was at +18 with the subs at +15
kcnitro07 is offline
post #124 of 142 Old 04-09-2014, 09:12 PM
WVSyd's Avatar
Liked: 42
...WHen I test ohms it was bouncing around from 4.1 to 4.4 ...
A standard meter set to DC resistance will not give valid impedance
"Beware of Salesmen: They are the modern Svengali, immune to Science and Reality"
WVSyd is offline
post #125 of 142 Old 04-09-2014, 09:17 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
I'm using a multimeter with it set to 200 ohms (lowest setting) it registers anywhere from 4.1 - 4.6. it seemed to pause on 4.2 and 4.3 the most though. perhaps my multimeter is crap, its the only one I have.
post #126 of 142 Old 04-09-2014, 09:19 PM
WVSyd's Avatar
Liked: 42
A multimeter reads DC resistance - this is an ( AC ) reactive circuit
https://www.synaudcon.com/site/author/pat-brown/the-analog-impedance-meter-tools-of-the-trade/
WVSyd is offline
post #127 of 142 Old 04-09-2014, 09:30 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
My bad I didn't read your post correctly. Its 2 bridged in series which would be 2 + 2 or 4 ohms. 4 ohms makes 87 volts 1860 or so?
Here is a link to a guy that tested the epx4000, granted in stereo 8ohm
http://electronics.forumsee.com/a/m/s/p12-30660-084095--the-behringer-epx4000-amp.html
Does that makes sense?
He said it was 440watts with 100 hz test and its rated at 530 hz
post #128 of 142 Old 04-09-2014, 09:36 PM
WVSyd's Avatar
Liked: 42
After this inspection I took the first measurement of the amplifier using my setup built on 8 ARCOL 50W resistors mounted on a heatsink
Did you test this with a resistive dummy load in the same way?
WVSyd is offline
post #129 of 142 Old 04-09-2014, 09:46 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
NO, I had it plugged In to my subs, since I'm not going to hurt them with these amps lol
post #130 of 142 Old 04-09-2014, 09:49 PM
WVSyd's Avatar
Liked: 42
A dummy load is just resistors,
A speaker load is reactive - it has a fixed dc resistive component and a reactive component that varies with frequency - together they make up impedance.
http://www.physlink.com/education/askexperts/ae517.cfm
http://www.ko4bb.com/e102/e102-9.php
WVSyd is offline
post #131 of 142 Old 04-10-2014, 02:08 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
I think for my purposes, I'll just use the 2 + 2 = 4 method for testing impedance biggrin.gif. I don't need exact.
more to the point,
if I can get 1800 watts out of my EPX, and the $3k SP28000 is only 2400 what is the point of spending 10x as much money? to gain 600 watts or the equivolant of another 1 dB?
post #132 of 142 Old 04-10-2014, 02:57 PM
Deep Sea Sound
dgage's Avatar
Liked: 1346
more to the point,
Down at 10-15Hz, I doubt the EPX is putting near that. Also, as much as I'm happy with the SpeakerPower, now that the IPR 7500 and iNukes are put and getting good reviews, I'd recommend starting there. I would definitely consider the IPR 7500 a huge improvement after hearing it last weekend at Beast's. But his IPR 7500, even though rated the same watts, couldn't keep up with my SpeakerPower SP2-8000 when pushing the SI HS24.
But again, if you are happy with the sound you are getting, save your money. The goal is a nice system, not the best of everything. The room treatments probably make more of a difference once you get to a certain level of equipment.
David Gage
Deep Sea Sound
dgage is offline
post #133 of 142 Old 04-11-2014, 11:32 AM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
It would cost a few hundred $ to build a 4 ohm dummy load that could withstand 2000 watts...not sure I care enough to spend that
post #134 of 142 Old 04-11-2014, 11:41 AM
Deep Sea Sound
dgage's Avatar
Liked: 1346
Dude, go enjoy yours subs. I have a SpeakerPower SP2-8000 and while it is a very solid amp, in all likelihood I should have bought a SP2-12000 instead to get more out of the LMS-5400s but I'm not sure I will or won't do that. I may have a SP2-8000 for sale in the future or I may not.
In the meantime, I'm going to enjoy the system as it is as it is still kick ass. I recommend you do the same and if you do get an itch later, you can scratch it but I would just go enjoy the system. Oh yeah, stay off AVS...it has a way of distorting normalcy and will result in a reduced bank account. smile.gif
David Gage
Deep Sea Sound
dgage is offline
post #135 of 142 Old 04-11-2014, 11:57 AM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
I'm real good at that, but I'm coming for the advice for my build in the basement over in the theater threads lol
post #136 of 142 Old 04-13-2014, 07:53 PM - Thread Starter
kcnitro07's Avatar
Quoted: 12 Post(s)
I found a new way to cause a heart to skip a beat....
Listen to music on your new $2k subs....hear a loud pop and everything shuts off.....
stupid cat flipped the switch off that goes to the outlet the amps are currently plugged in to. stupid cat
post #137 of 142 Old 04-13-2014, 07:56 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
Frick'n hate cats
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #138 of 142 Old 04-14-2014, 06:38 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
biggrin.gif I forgot about the crazy stuff cats do.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #139 of 142 Old 12-14-2014, 11:01 AM
Quoted: 70 Post(s)
Liked: 7
Anyone know if parts-express if they sell the whole sub or is that grey area mentioning basket and motor the only this you get purchasing. As will I have to get a cone and spyders for this purchase? And thinking a crown xls2500 to power it
MagnumMafia05 is offline
post #140 of 142 Old 12-14-2014, 11:09 AM
Deep Sea Sound
dgage's Avatar
Liked: 1346
I ordered the LMS-5400 from Parts-Express and that's the way the whole subwoofer is listed on the invoice and shipped. The HEAVY magnet is in one box and the big cone is in a separate box. You attach them with six bolts and a hex wrench. So if you order the ~$925 LMS-5400 you are getting the entire product that all you need to do is assemble and hook up to an amp. And if you want the max output, get closer to a REAL 4,000w as it is significantly better than 2,400w that I initially used. I ran mine with a channel from a SpeakerPower SP2-8000, initially at 4 ohms and then wired down to 1 ohms to get the 4,000w. As long as you are using this in a home theater living room, the SpeakerPower appears to handle it but I wouldn't wire any other amps down to 1 ohm, without getting some sort of recommendation.
dgage is offline
post #141 of 142 Old 12-14-2014, 11:48 AM
Quoted: 70 Post(s)
Liked: 7
So it comes with cone then? I only have a 15amp circuit breaker for where its setup
Edit.. I just ordered the ep4000 and lms 5400 on parts express. Now just need to find box measurments for my friend.. I always wanted this sub in my car... now ill have it in my home!!!
post #142 of 142 Old 12-14-2014, 12:46 PM
Deep Sea Sound
dgage's Avatar
Liked: 1346
In this case Cone = Basket. 4 cu.ft. is close to 22" cube. And I'd recommend you triple up on the baffle (mount) and if you can find it for a decent price, use Baltic Birch plywood or similar such as ApplePly. Essentially it is void free plywood and worth it for an expensive project such as this that you'll keep for a long time.
dgage is offline
Tc Sounds Lms Ultra 5400
