Some Sonotube Help - Speaker Terminals Polyfill - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-03-2013, 04:35 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
I need some suggestions for speaker terminals. I prefer to have the terminal on the side of the sonotube itself, vs. on one of the baffles.
I'm tempted to just drill a hole in the tube, run the wire through, and silicone it up. But that seems a bit sloppy to me. Would a standard circular terminal cup seal well enough on a 24" diameter sonotube?
AND
How much polyfill should I use? Should I dump it in or nicely line the walls? I've always just dumped it in the past.
I have 4^3 of space per woofer. 18" Stereo Integrity.
pdxrealtor is offline
post #2 of 8 Old 10-03-2013, 04:40 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Would something like this work for binding posts?
http://www.parts-express.com/pe/showdetl.cfm?partnumber=091-1250
I'm not sure I trust the 'cardboard' to not compress from securing these.
post #3 of 8 Old 10-03-2013, 05:23 PM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1123
Yes that will work. I would just line the inside the tube. Just make sure there are no air leaks at the end caps and binding posts.
Marantz 7702 Atmos
MKtheater is online now
post #4 of 8 Old 10-03-2013, 07:10 PM
steve nn's Avatar
Liked: 433
I would glue a small pre drilled piece of wood on the sono where you want the terminals to go.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #5 of 8 Old 10-03-2013, 07:12 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
For what purpose?
I was thinking fender washers to spread the load and stop compression..... are you thinking the same with your wood idea?
post #6 of 8 Old 10-03-2013, 07:18 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Thanks for bringing that up. I think that is an important point and one which I will be highlighting in my build thread. Sealing up the baffle joints even though you glued the baffles in.
I would like some more input on lining vs. stuffing the tube with polyfill. It's always been my understanding that filling the enclosure with poly fill will make the box act bigger. I forget the oz per cubic foot. ( I can look it up easily) but it seems that 4^3 is the minimum size for these SI 18's and adding polyfill to make the enclosure seem bigger might be a benefit.
post #7 of 8 Old 10-04-2013, 06:27 AM
steve nn's Avatar
Liked: 433
Yes washers would work fine, just so they are big enough to dissipate the load.
EDIT/PS> I was just thinking custom PDX thermalnecular terminals is all. smile.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #8 of 8 Old 10-04-2013, 02:56 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
I went out to my loudspeaker supply shop locally and ended up getting speakon terminals for the sonotube.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=092-339
I also got all the other speakon connectors for the amps. and tubes.
If anyone else has any input on how much polyfill to use I'd love to hear it. smile.gif
