decisions on diy speakers - Page 2 - AVS Forum
post #31 of 34 Old 10-06-2013, 06:30 AM - Thread Starter
jaybob1807's Avatar
Ummmm, while I would love to have a setup like this, I simply cannot. Those speakers look like they could just blow you away. One thing I have noticed with the eq on the HK is that with it on my bass is full and I usually set it to 0. Without the eq I cannot turn the bass up enough to replace what is lost. My speakers also sound much brighter with the eq off and muddier with it on. So I feel like it is a trade off and with my room shaped the way it is I can have a totally different sound on the sofa(too much bass) than say the chair in the middle(just right) than the far left of the room(not much bass at all). Do you think it is the eq, my ears, my tatstes? I just cant get comfortable with this setup anymore. Do you guys use eq's, receivers, pre/pro? What is a popular choice for a receiver these days? I have to imagine with the sensitivity of some of hte diysoundgroup options that you really wouldn't need much power?
http://www.avsforum.com/content/type/61/id/287805/
jaybob1807 is offline
post #32 of 34 Old 10-08-2013, 06:10 PM - Thread Starter
jaybob1807's Avatar
anybody
post #33 of 34 Old 10-08-2013, 08:09 PM
wvu80's Avatar
Quoted: 26 Post(s)
Liked: 99
anybody
It depends on a couple of things, starting with who you are as a person (long term thinker vs short term) and your budget.
I started about 9 months ago to upgrade from old school 2.0 speakers with receiver from the 1990's, to all the neat stuff that will attach with HDMI cables to my HDTV. I wanted something that was mainstream, mature technology, and I was wasn't worried about 4K passthrough and 11.1 speakers. I essentially wanted a 5.1 system and some other features I thought I wanted, specifically bi-amp capability (a 7.1 AVR which uses 5.1 system and the other two channels for bi-amp) and I wanted something that might be used for a pre-amp if I wanted to add power later on. The Onkyo NR-717 was a great choice for me, and I can recommend it, and other HIGHER rated Onkyo's. I would not recommend the lower Onkyo models due to numerous complaints about the HDMI circuits failing, read all about it via Google.
The OTHER way to go is to get EXACTLY what you want, and don't pay extra for features you will not use. For instance I just picked up an AVR for my son for his entry level 5.1 system, a refurb Denon AVR 1513 for $150. The electronics sound great, at 75 wpc it is plenty of power, and you are not paying for wireless radio, or 3D capability, or any of the features found on "hi end" AVRs. This was a GREAT CHOICE for him. I have the fancy internet radio on mine, but I don't plan on using it, so why pay extra?
You asked what is the "popular choice." I would suggest you peruse the AVR section of AVS to find out, because that is a moving target as new models are introduced, and older closeout models go on sale. I know many people here suggest the model above mine, the Onkyo NR818 for a variety of good reasons, and it runs another $150 above my NR717 right now (about $650).
Edit: BTW I think the NR717 runs about 135 wpc to each channel. Right now it is powering my DIY SEOS Fusion Pure 10's, and the sound is pure and clean from very LOW power (which my wife likes, it is very clear at low volumes) to VERY loud, which I like for some types of music (jazz, horns and drums). I think the speakers would take more power if I had it, but if I had it, I wouldn't use it, as I already don't use everything the Onkyo has to offer and the sound is coming close to ear damage loud, with volume level set to about 77, with 100 max. 82 is reference level on the Onkyo.
Symmetry pleases the eye, but it usually offends the ears where low frequencies are concerned. -Yoda Fitzmaurice
wvu80 is offline
post #34 of 34 Old 10-09-2013, 07:04 PM - Thread Starter
jaybob1807's Avatar
Cool, thanks for the reply. Do you use audyssey eq with your SEOS Fusion Pure 10's?
User Tag List
