Anyone know what material Precision Ports are made from - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-04-2013, 04:56 PM - Thread Starter
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
PVC? ABS?
I need to do some customizing involving bonding and need to know what kind of glue to use
Noah
noah katz is online now
post #2 of 5 Old 10-04-2013, 10:32 PM - Thread Starter
noah katz's Avatar
Liked: 387
I have extra connector pieces I can test with
Noah
post #3 of 5 Old 11-29-2013, 03:15 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
No answer?
my Precision Ports paper says this "ordinary ABS adhesive or similar type glue", I just read it preparing for my ported build
http://www.plumbing-geek.com/solvent-cement.html
http://www.oatey.com/products/plastic-pipe-cements-and-primers/oatey-specialty-cements/all-purpose-cement
All Purpose Cement
  • Medium-bodied milky-clear cement for use on all schedules and classes of ABS, PVC and CPVC* pipe and fittings up to 12” diameter with interference fit.
  • Lo-V.O.C. Solvent Cement meets California South Coast Air Quality Management District (SCAQMD) 1168/316A or BAAQMD Method 40 and various environmental requirements.
  • Recommended for potable water, pressure pipe, conduit and DWV.
  • Recommended application temperature 40°F to 110°F / 4°C to 43°C.
  • Meets performance requirements of ASTM D-2564, D-2235, F-493.
Always check local codes for acceptability of this product
mtbdudex is offline
post #4 of 5 Old 12-01-2013, 09:52 PM - Thread Starter
noah katz's Avatar
Liked: 387
I tried it using Purple Primer and ABS cement, which of course worked per your finding.
Noah
post #5 of 5 Old 12-02-2013, 06:06 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
I did mine "bare naked", ie just the red can cement, put it on, insert and twist slowly and they locked up around 35 - 40 degrees of twist.
Interesting, the guys at Home Depot showed me the can, it did NOT say ABS on it, yet the cardboard box a pack of many came in did, with same product ID #.
Looks like for whatever reason the ABS has been dropped from the actual can label, but it is same stuff.
mtbdudex is offline
