Do i have a subwoofer or a speaker? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-06-2013, 06:21 PM - Thread Starter
lupus1203's Avatar
I have an OLD speaker i found (JL audio) 10".  It has no writing on it.  I hooked it up to a CD player i have with some speaker wire and held it over a bucket, it sounds pretty good, maybe a little dull but that could easily be the bucket.  My question is... How do i know if it is a subwoofer, or just a speaker?  or is there even a difference.  I offered it to a friend to use as a sub in her truck (she has an amp of her own) will this work, or should i just scrap it?
Josh
lupus1203 is offline
post #2 of 8 Old 10-06-2013, 06:24 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2575
subs in the bucket...sounds like a country song.
take a couple of pictures and we might be able to spot a thing or two that will help answer your question.
Listen. It's All Good.
LTD02 is offline
post #3 of 8 Old 10-06-2013, 06:50 PM - Thread Starter
lupus1203's Avatar
i cant get a photo to attach to this forum
post #4 of 8 Old 10-06-2013, 06:58 PM
LTD02's Avatar
Liked: 2575
the dust cap looks a little rough, but that cover does what it says (keeps dust out of the coil).
looks like a medium throw subwoofer, probably 10mm xmax ballpark i'm just total guessing.
if you have a multi-meter and can check the resistance that might give a clue as to the status of the voice coil. otherwise, i don't see any reason not to fire it up. most car subs were designed to work in smallish enclosures and sealed is much more forgiving than ported, so...
maybe a 1.0-2.0 cubic foot sealed enclosure and see how it goes? probably a 100-200 watt amp would be safe and fine. i don't know...something like that probably isn't too far off the mark.
LTD02 is offline
post #5 of 8 Old 10-06-2013, 07:03 PM - Thread Starter
lupus1203's Avatar
awesome!  i'll check it with a meter.  Am i wanting something lower like 2 ohms?  or why would i need to know that?
post #6 of 8 Old 10-06-2013, 07:05 PM
LTD02's Avatar
Liked: 2575
also, i don't think that is the real jl audio, but i'm not sure. their current logo seems to have been in use for at least 15 years.
LTD02 is offline
post #7 of 8 Old 10-06-2013, 07:05 PM
LTD02's Avatar
Liked: 2575
if it reads something way off, it could have a damaged coil.
LTD02 is offline
post #8 of 8 Old 10-06-2013, 07:07 PM
LTD02's Avatar
Liked: 2575
btw, you can get a half decent new 12" subwoofer for $65 to your door.
http://www.amazon.com/Infinity-Reference-1262w-1200-Watt-High-Performance/dp/B0028AYIXK
LTD02 is offline
