In-wall sub with these dimensions? - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2013, 01:58 AM - Thread Starter
VectorLabs's Avatar
Quoted: 71 Post(s)
Liked: 50
I was wondering if it is possible to do a DIY in-wall sub but instead of the normal volume there is a 36Lx36Lx18H hole behind the wall that I would like to use. I was thinking about building a sealed box with those dimensions I can slide into the wall with the subs and power it with an inuke 1000. Anyone think this would be ok?
VectorLabs is offline
Old 10-07-2013, 07:02 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
that would be just fine!
subs aren't very sensitive to the shape of the enclosure, more or less.
Listen. It's All Good.
LTD02 is offline
Old 10-07-2013, 07:26 AM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
Yep. The enclosure ALWAYS matters. The question is "how much". You will find some people that will swear you kicked a puppy if your enclosure doesn't meet some set of rules. You will find some people that will tweak an tweak their crossovers (DSP) to account for the enclosure in an open air environment. Then you find people who measure and measure and pretty much go "yep, it is better..but it really just doesn't matter since the room jacks up everything anyways and I should EQ for that".
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
Old 10-07-2013, 08:03 AM
LTD02's Avatar
Liked: 2576
have you got a driver in mind?
LTD02 is offline
Old 10-07-2013, 02:09 PM - Thread Starter
VectorLabs's Avatar
Quoted: 71 Post(s)
Liked: 50
Don't know what driver yet as I as trying to figure out if it was doable. I was thinking about dual Dayton Ref 15?
Sent from my XT926 using Tapatalk 4
Old 10-07-2013, 02:44 PM
LTD02's Avatar
Liked: 2576
that is something like up to 11 cubic feet or so net, so there are lots of drivers that could work in that space or smaller.
as a matter of fact, dual reference 15HF's would work quite well in there. they like the larger enclosure and wouldn't need but about 250 watts each or so of power.
the 15um's might be worth a look too.
LTD02 is offline
