Woofer surround - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2013, 10:30 PM - Thread Starter
BrickTop's Avatar
Quoted: 47 Post(s)
Liked: 31
I am in the process of mounting my subs to the baffle and noticed the foam surround covers more than half of the mounting holes in the frame on one side. Should I slit the surround where it covers to make it easier to put the bolts through, or just push the bolts through?
Bricktop
Sent from my Rezound using Tapatalk 4
BrickTop is offline
Old 10-07-2013, 10:59 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Its not the surround, its the gasket. I would push the bolts through if possible.
Mrkazador is offline
Old 10-08-2013, 06:02 AM - Thread Starter
BrickTop's Avatar
Quoted: 47 Post(s)
Liked: 31
This is definitely part of the surround...the woofers have no gasket.
BrickTop is offline
Old 10-08-2013, 08:32 AM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 124
Bricktop
Pushing the bolt through may separate more of the surround from the glue.
I'd make a small slit with a knife, staying within the confines of the hole.
koturban is offline
