Limited space for new sub build.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-08-2013, 11:02 AM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
Hey guys. I'm looking to replace my Def Tech supercube 4000 with a new DIY project.
This will be my second DIY sub, I have a sealed 15" in the opposite corner.
I have somewhat of a size restriction on the enclosure but its not too bad.
The biggest footprint the enclosure could have is 23" X 21". With NO height restriction.
I'm looking for a build that will dig down deep like my current 15".
I'm considering another 15" if you guys think I can build an enclosure within that footprint that will get low.
If not a high output 12" is always an option also.
I will most likely be powering the setup with a Crown XLS1000 amp.
Any suggestions guys? Thanks!
TenTonBass is offline
post #2 of 11 Old 10-08-2013, 11:50 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
large low tuned top firing slot ported tall boy with recessed 18" driver and square flush mount grill.
oh yeah!
Listen. It's All Good.
LTD02 is offline
post #3 of 11 Old 10-08-2013, 11:54 AM
LTD02's Avatar
Liked: 2576
stereo integrity d2 driver for 4 ohms in bridged mode to your amp. 17hz tuning on the cab which at about 60 inches tall would net out to about 11-12 cubic feet. 3" x 21" slot port 36" long. MARTY SUB! performance. :-)
LTD02 is offline
post #4 of 11 Old 10-08-2013, 12:36 PM
steve nn's Avatar
Liked: 433
rolleyes.gifbiggrin.gif I like it!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #5 of 11 Old 10-08-2013, 01:07 PM
LTD02's Avatar
Liked: 2576
not sure which 15" you have or are considering, but here is the comparo between the large ported 18" with 1000 watts and a medium sealed 15" (Dayton um in this case) also with 1000 watts.
LTD02 is offline
post #6 of 11 Old 10-11-2013, 05:53 AM
trancemitr's Avatar
Quoted: 17 Post(s)
LTD, could you do something like the box you've got up there but with a 8" or 10" round port? Some sonotube that size should be easy enough to find, and something that big should keep the chuffing down. Or is the slot port just a better/easier way to go? Just curious for my own build as I'm thinking of something similar. I was looking at the Marty Sub, but it'd be longer than I'd want to put behind a screen.
trancemitr is offline
post #7 of 11 Old 10-20-2013, 10:08 AM
LTD02's Avatar
Liked: 2576
sorry that I missed your post.
nothing particularly special about a slot port. it is easy to build and easy to brace.
a round port would work too. what did you have in mind?
LTD02 is offline
post #8 of 11 Old 10-20-2013, 02:51 PM
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
No height issues? Sonosub!
Anthony_Gomez is offline
post #9 of 11 Old 01-28-2014, 06:23 PM
superfrog01's Avatar
Quoted: 91 Post(s)
Liked: 94
oh yeah!
did you ever go any further with this box.  Would this perform the same as the marty sub?
I'm looking for a box 60 inches long 25 tall and 22 deep.
superfrog01 is offline
post #10 of 11 Old 01-28-2014, 06:29 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I thought about doing traditional round ports in my MartySub. Iirc it was going to require an 8" round port size. After buying the 8" pipe I just could not imagine how it wouldn't be too big for the cabinet as it was almost the size in diameter as a typical 12" subwoofer driver!
Martycool007 is offline
post #11 of 11 Old 01-29-2014, 09:32 AM
LTD02's Avatar
Liked: 2576
josh plopped a 10" port in his. it all just kind of scales the same. this was with a 21" driver.
LTD02 is offline
