Speaker stuffing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-09-2013, 07:21 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
In the past when I built my sealed subs I just stuffed them with fluffy fiberglass.
Now that I am building LCR and surrounds what is the proper procedure for inside of the cabs.
If it makes a difference I am building the deltalite kits.
Moto
MX48 is offline
post #2 of 8 Old 10-09-2013, 07:36 AM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
Moto
same stuff wiill work. fiberglass, memory foam, polyfill...walmart pillows cut open etc
wormraper is online now
post #3 of 8 Old 10-09-2013, 07:48 AM
Bill Fitzmaurice's Avatar
Liked: 4667
Originally Posted by wormraper View Post
memory foam
Don't use memory foam, the density is too high.
What does the kit instructions say?
Bill Fitzmaurice is offline
post #4 of 8 Old 10-12-2013, 07:07 PM
vinodk's Avatar
Quoted: 84 Post(s)
Liked: 33
Got cheap Walmart pillows to stuff my sub cabs from Erich's 4 cuft flat packs for SI HT18D4. Will try to stuff them in the back of the cabs between braces. Do I need to open the pillows or can I just place them in the back of the cab with cloth cover intact so that nothing loose is flying around?
Vinod
vinodk is offline
post #5 of 8 Old 10-12-2013, 08:18 PM
Quoted: 911 Post(s)
Liked: 490
I really like the Bonded Logic recycled denim insulation. Works about as well as fiberglass, but no itch.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #6 of 8 Old 10-12-2013, 08:19 PM
mhutchins's Avatar
Quoted: 82 Post(s)
Liked: 95
What is the impact of using memory foam for a sealed woofer design?
mhutchins is offline
post #7 of 8 Old 10-12-2013, 08:39 PM
Liked: 4667
It would probably be over damped. It also could end up with a higher Q despite being overdamped, because the density of memory foam is so high that the cabinet volume might actually be reduced.
post #8 of 8 Old 10-13-2013, 03:24 AM - Thread Starter
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Thanks guys.
MX48 is offline
