Crown XLS 2000 and RE Audio XXX - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-09-2013, 05:07 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
Hello all, quick question.
Will a Crown XLS 2000 drive either an RE XXX 15" or 18".
Whichever sub I decide on will be in a sealed enclosure. 5-6 cube for the 15 and I don't even know what for the 18". Any suggestions?
Thanks guys!
TenTonBass is offline
post #2 of 4 Old 10-09-2013, 09:28 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
You'll want way more than that. I had a pair of the 18's on an LG clone and they needed every bit of it. For the coin you would drop on the xls2000, take a look at the clones, or a peavey ipr7500. Those should do the trick smile.gif For space on the 18, I would recommend no less than 6 cuft, and probably more like 8 if you can manage.
beastaudio is offline
post #3 of 4 Old 10-09-2013, 10:45 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1547
The beauty of the re's is that you will never kill the sub by bottoming it out. (well, never say never).
You are more likely to thermal it well before that happens.
and if you do, then you are a serious bass-addict my friend in need of more woofery woofer things.
Now if you want to play with pure dynamite you could even bridge the clone into 4-ohm, but it's only for the MOST fool hardy / hardcore... or so
BassThatHz is online now
post #4 of 4 Old 10-10-2013, 06:41 AM
subyguy's Avatar
Liked: 26
I'd go for the IPR-7500. I was running a bridged xls1500 into each of my uxl18's and it rolled off pretty hard on the bottom end. The IPR seems like endless power now and I gained a lot of bottom end. I'll post up a comparison chart sometime.
(3) JTR Noesis 212HT (LCR)
(2) JTR Single 8 (wides)
(2) JTR Slanted 8 (sides)
(2) DIY Eminence 10" coax (rear Surrounds)
(2) JTR Orbit Shifters
(2) Mach5 UXL-18's sealed
(2) Soundsplinter 15's sealed
Speakers powered by 6 crown xls 1500's
UXL's powered by Peavey IPR-7500
My theater:
http://www.avs...
subyguy is offline
