Best tweeter for soffit mounting: SEOS, TPL or RAAL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 10-10-2013, 10:26 AM - Thread Starter
NiToNi's Avatar
I'm building a HT in a small room (16' x 11') with a new 'false' front wall with soffit mounted speakers, subs, equipment, OC 703 and AT screen.
The L+R will very much be towards the corners and toed-in towards a single row 3-seat sofa about 11' out from the front wall.
I'm interested in views on which tweeters that would work best in this setup:
(1) SEOS15 with DE250 or equivalent;
(2) Beyma TPL-150H
(3) RAAL 70-20X
First I was going to go for (1) because of constant directivity and cost. Then I convinced myself that the TPL is better and worth the upgrade. But then again, I thought perhaps I should disregard this whole constant directivty business and just use the RAAL's that I already have lying around; I mean, they are considered to be one of the best tweeters around after all, but lack of course in beam pattern control, power handling and maybe dynamics compared to the other two. However I would never have to wish for a super tweeter wink.gif
Difference in cost is not a determining factor and the rest of the design will follow the choice of tweeter, so please disregard both those factors - focus is solely on in-room tweeter performance.
NiToNi is offline
post #2 of 15 Old 10-10-2013, 10:37 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
If you are capable of doing a custom crossover, measurements and speaker design, then I would go with the RAAL in that small room as you could reach high levels of spl easily in that small room. The Seos/15 is a bit overkill, and while that Beyma is a great tweeter, the RAAL is just something special. I have the RAAL 70-20xr in my LCR's and they are the best out there, plus it can be crossed lower than what people think, crossing around 1400hz to a great mid would make that a giant killer!
Martycool007 is offline
post #3 of 15 Old 10-10-2013, 10:49 AM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
(2) Beyma TPL-150H
(3) RAAL 70-20X
How about the SEOS RAAL? However, I'm not sure that this would fit the RAAL 70-20X. The RAAL is supposed to be cat's meow. It would be interesting if someone had the $$ to build a no compromise SEOS RAAL/TD12M.
rajacat is offline
post #4 of 15 Old 10-10-2013, 03:43 PM
pnw
pnw's Avatar
Quoted: 47 Post(s)
Liked: 76
The RAAL should be the most nuanced of the three but, personally, I wouldn't use it in a HT because ribbons do not like significant excursion. Think about that ultra-light diaphragm on the same baffle as your subs.
The Beyma would be my choice for a very substantial 3-way.
The SEOS 15/CD would be my choice if limited to a 2-way as it can handle more LF SPL.
pnw is offline
post #5 of 15 Old 10-11-2013, 04:56 PM
gbegland's Avatar
Vote for Raal for pure sound quality. TPL for overall best compromise between sound and durability/SPL. I have years of experience with both.
Greg
gbegland is offline
post #6 of 15 Old 11-11-2013, 06:56 AM - Thread Starter
NiToNi's Avatar
Thanks for all the inputs so far. I will probably go down the route of the 70-20XR together with Neo10 for LCR and 70-10D together with Neo8 for the surrounds.
Greg: Have you heard the SEOS waveguide and if so with what CD?
NiToNi is offline
post #7 of 15 Old 11-11-2013, 07:02 AM
Quoted: 280 Post(s)
Liked: 176
I have RAAL's in my small theater room, and they fill the room with plenty of SPL no problem, they sound great! I have tried my buddies Fusion-12's and in my small room, I much preferred the RAAL's.
The RAAL 70-20Xr can actually be crossed quite low, especially for a ribbon. I believe that mine are crossed at 1,200hz. If it were me, I would go with the RAAL, Neo-8, and a high quality woofer such as the TD12 or possibly even something from the likes of ScanSpeak or Seas.
Keep us posted!
post #8 of 15 Old 11-13-2013, 02:54 PM
Looneybomber's Avatar
Liked: 25
No love for the Fountek Neopro5i?
YID DIY
Looneybomber is offline
post #9 of 15 Old 11-13-2013, 04:05 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
I am about to start a similar sized room, using a Mundorf AMT, so if you asked me about the above 3 I'd say the Beyma. Especially given the location (near the corner, as you mentioned the directivity). I think its the best balance between high SPL and quality. I personally prefer the Mundorf, but thats just me (to me they sound better than the Beyma)
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #10 of 15 Old 11-13-2013, 04:08 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
(2) Beyma TPL-150H
(3) RAAL 70-20X
It would really depend on the rest of the speaker. Do you mind building a three or four way? Are dynamics or detail your top priority?
That wouldn't fit your RAAL, but this would: http://www.diysoundgroup.com/waveguides/ha25.html
Without WG: http://i.imgur.com/aR1bJgF.jpg With WG: http://i.imgur.com/6kcnrVJ.jpg
I would tend to agree, but in a 3 or 4 way, with the RAAL crossed high enough(min 4K), it would still hold it's own. But to prevent a directivity mismatch, be prepared to use a small midrange.
Keep us posted!
Although there are a few slightly different versions of the 70-20XR, I wouldn't recommend crossing under 2K for a HT application.
Face2 is offline
post #11 of 15 Old 11-13-2013, 05:35 PM
noah katz's Avatar
Quoted: 879 Post(s)
Liked: 304
Are there any polars for those ribbons on SEOS'?
Noah
noah katz is online now
post #12 of 15 Old 11-13-2013, 05:42 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
No polar, but 45 deg off axis with the WG in place: http://i.imgur.com/gCmoYPAh.jpg
FYI, if you speak to the owner of RAAL, he does not recommend the use of waveguides with his tweeters.
A friend of mine is working on a Fountek based waveguide loaded ribbon, I'll post up the results when he's done.
Face2 is offline
post #13 of 15 Old 11-13-2013, 06:06 PM
gbegland's Avatar
Tried those too. Nope, no love. Returned them.
gbegland is offline
post #14 of 15 Old 11-13-2013, 06:25 PM
noah katz's Avatar
Quoted: 879 Post(s)
Liked: 304
Thanks; I presume that's for the horizontal axis with the ribbon vertical; I'm interested in what the WG does in the vertical axis.
Noah
post #15 of 15 Old 06-09-2016, 07:51 AM
J-Pak's Avatar
Has anyone else tried the SEOS waveguide with RAAL?
Looking on their website they say 70-20x is only sold to manufacturers.
J-Pak is offline
