Help with speaker subwoofer design - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 12-03-2013, 05:35 AM - Thread Starter
316
316's Avatar
Liked: 27
Why settle for plain and ordinary right? Lol... Joel did a fantastic job and this is the big brother to LTD02's "Marty sub" smile.gif
Its actually quite interesting how this project developed, LTD02 & Joel really made it come alive. I can't wait to demo the canon shots from the HMS Victory video biggrin.gif
316 is offline
Old 12-03-2013, 04:15 PM
NWCgrad's Avatar
Quoted: 1234 Post(s)
Liked: 1228
Wow...now that makes the old VMPS subs I drooled over when I was in college look small. Go big once, cheaper than constant upgrades. Awesome custom panels. Cant wait to see how yiu like them once they are up and running.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
Old 12-03-2013, 06:00 PM - Thread Starter
316
316's Avatar
Liked: 27
NWCgrad,
The VMPS has always been my dream speaker but I could never find a pair used at the right price, but yeah, why not get it done and out of the way now!
There still remains a very slight chance I go with the JBL 2242 ( I have two EP4000's begging me for use) and if that's the case Joel will be busy with another pair of cabinets. I will have to see how my mid-bass is but I think the bottom end is done for life, for me anyway's smile.gif
As an update, I plan on picking them up this weekend. urapnes1 will be posting some pics tonight.
316 is offline
Old 12-03-2013, 06:26 PM - Thread Starter
316
316's Avatar
Liked: 27
Does anybody know where to get that paint that looks like bedliner paint for the cabinets? With the nice texture to it.
316 is offline
Old 12-03-2013, 06:42 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Just google search duratex
gpmbc is offline
Old 12-03-2013, 07:19 PM - Thread Starter
316
316's Avatar
Liked: 27
Got it, thanks!!
316 is offline
Old 12-03-2013, 09:21 PM - Thread Starter
316
316's Avatar
Liked: 27
IMG_8869.jpg 319k .jpg file
316 is offline
Old 12-04-2013, 11:12 PM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 36
Progress! Cabinet #1 is just about complete and # 2 is gluing up as I type this. I was successfully able to lift one of the cabinets into upright position to give me a bit more working room...going to take some advil after doing that!
Lots of glue - about a gallon will go into both of these, and lots of clamps...I have all of my clamps in use with these...lets me get a nice even pressure on everything, and really helps pull panels around and into place with about 1500 pounds of pressure each. At one point I had 18 clamps on 1 cabinet all really nice and snug (18*1250 = roughly 22,500 pounds of pressure!!!)eek.gif
Anyhow...here are some more pics from tonight:
Reddig likes this.
urapnes1 is offline
Old 12-04-2013, 11:21 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
How much does that beast weigh ?
Damn that things huge:eek:
chalugadp is offline
Old 12-05-2013, 02:02 AM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2580
that's probably about 325 pounds of mdf in the picture.
another 125 pounds or so from the drivers.
450+ pounds in place.
Listen. It's All Good.
LTD02 is offline
Old 12-05-2013, 05:45 AM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Would plywood in this instance not have been ideal?
gpmbc is offline
Old 12-05-2013, 09:50 AM - Thread Starter
316
316's Avatar
Liked: 27
the cabs being so long will benefit from stuffing (pillows) or resonances could end up in the passband.
here is some good info:
http://www.data-bass.com/data?page=content&id=79
and
http://www.avsforum.com/t/1153089/700-playhouse-sub-ported-fi-q18/60#post_16709957
LTD02,
How many pillows do you think just by the looks of it or can you tell?
316 is offline
Old 12-05-2013, 01:01 PM
LTD02's Avatar
Liked: 2580
4-6 pillows behind the middle drivers would be a good start.
LTD02 is offline
Old 12-05-2013, 01:04 PM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 36
I tilted the one up by myself. Very heavy!
As far as MDF vs plywood. MDF machines better on the CNC, doesn't measure .717 inches thick which plays hell on designing, and is a bit cheaper. These cabinets have a lot of bracing in them so there shouldn't be much of an issue. I feel that both materials have their merits.
urapnes1 is offline
Old 12-05-2013, 03:49 PM
chalugadp's Avatar
Liked: 1505
Old 12-05-2013, 05:19 PM - Thread Starter
316
316's Avatar
Liked: 27
Without the drivers they are manageble by myself and either of my sons.
Before I bring them in I will paint them and once they are painted I will stand them up and load the drivers in the HT. Any moving outside the HT will be done without the drivers, my biggest concern is wether to spray or roll the duratex. I like the way urapnes1 built the cabinets so I do not have seems to worry about with the paint. Very nicely done. smile.gif
316 is offline
Old 12-05-2013, 07:00 PM - Thread Starter
316
316's Avatar
Liked: 27
316 is offline
Old 12-13-2013, 09:09 PM - Thread Starter
316
316's Avatar
Liked: 27
I want to run this by you all and get some feedback. As you know from following the post my LCR 's are the 3722 which I have been playing with and breaking in the last week or so and I am pleased with them BUT...they are limited on the top end...so..here is what I'm thinking.....
.... If you look at the horn it has plugs on the sides. I'm thinking of making a baffle plate that will bolt directly above it with dome tweeters and since the emotiva has a biamp option I will run the 3722's as full range and cross the tweeters over at 12-14k so that they will pick up the top end where the JBL horns drop off.
I have seen speakers with horns and dome tweeters. The current JBL horn can almost be looked at as a mid/upper mid horn and the dome tweeters would carry the highs that the 3722 is incapable of playing. Why do I want to do this? Because I want to have the best of both worlds if possible by playing music and video. Will it be for critical listening? No, its more for movies that have music in them so I can reproduce that music.
Now from a purist perspective there is going to be timing issues and I'm sure other things I'm missing but this is not a purist system, its a bone crunching flatten you to the wall if I want too and make your nose bleed...get it? biggrin.gif
So for starters I think a baffle plate with 12 1/2" mylar tweeters per horn...I need something to match the output of the horns (if possible or close to it).... I'm brainstorming here guys so just roll with it...... wink.gif
I really prefer the sound of dome tweeters on the top or electrostatic which is not an option but not horns. They just don't do cymbals justice in my opinion, likewise dome tweeters can't reproduce the sound of a horn section the way horns do...(think salsa music or old school tower of power). I may not be accurate in my description but you get my point...right? smile.gif
316 is offline
Old 12-13-2013, 11:06 PM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 36
Check these out. Perhaps 3 or 4 per side in a line array
http://www.parts-express.com/peavey-rd-16-versarray-ribbon-tweeter-7-ohm--299-465
urapnes1 is offline
Old 12-14-2013, 12:11 AM
LTD02's Avatar
Liked: 2580
jbl has some that will cover that region and keep up with your mains. there are several discussions around about them.
http://www.audiokarma.org/forums/showthread.php?t=367065
some more here:
http://www.jblpro.com/pages/components/uhf_drvs.htm
LTD02 is offline
Old 12-14-2013, 03:42 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I would recommend adding a JBL-2404H as a super type tweeter,or perhaps you might be able to find some Be diaphragms for your current mids/high frequency drivers on those 3722's without adding a super tweeter, as the Be diaphragms will make the mids & highs have more detail, clarity, and sound smoother as well.
Even if you do end up adding a super tweeter, such as the 2404H or 2402 ect...how would you integrate it within the crossover and how can you make it blend and play well enough with the existing drivers?
Subwoofer discussion is getting boring! Seems like that's all that has been going on lately! So let's talk more about actual speaker building! LoL!
Martycool007 is offline
Old 12-14-2013, 05:50 AM - Thread Starter
316
316's Avatar
Liked: 27
Knowing JBL they may already have this figured out for me. I will have to verify and if it is what I think it is my cure will be pretty simple and straight forward. If you look at the crossover, it appears to have an output for another horn. I just have to find out if this is a pass through or if it is active and tie my horn into it and done. Assuming I decide to go JBL horn/tweeter smile.gif
316 is offline
Old 12-14-2013, 05:51 AM - Thread Starter
316
316's Avatar
Liked: 27
if pass through I will need a network either way I should not have to biamp through the Emotiva so this will keep it simple
http://www.jblpro.com/catalog/general/ProductFamily.aspx?FId=29&MID=1
http://www.jblpro.com/products/cinema/index.html
What gets me is I was at a liquidation sale in Oakland where I bought my surrounds and passed on a dozen 2404's and other horns they had there and if I am not mistaken even the 2405's....UGH!!!!
Well guys...off to pick up the Cannon's........Will report back later this afternoon...Joel has those bad boys ready to rock!!!!!!
316 is offline
Old 12-14-2013, 07:07 PM - Thread Starter
316
316's Avatar
Liked: 27
The eagle has landed! Many thanks to Joel...speakers fit, a little prep work and ready for paint!
316 is offline
Old 12-14-2013, 07:45 PM
auburnu008's Avatar
Quoted: 438 Post(s)
Liked: 596
auburnu008 is offline
Old 12-14-2013, 07:46 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Boom!!
gpmbc is offline
Old 12-15-2013, 09:31 AM - Thread Starter
316
316's Avatar
Liked: 27
Well I got a double Boom!
As I was searching for JBL tweeters last night I remember something that Joel mentioned in a phone conversation and CLICK a light went off....I calibrated my speakers using emo-q in the Emotiva and BOOM!!! Speakers came alive and are now kickin some serious highs!! I can hear the little bells in a certain song in particular that I am familiar with and other sounds in the higher region that I am used to hearing. fantastic!
So I think for now I'm good and happy and ready to move onto the bass cannon's.
BTW, my freq on the 3722's is 18k according to the specs ( I checked them last night) so I knew there was no way I was hitting that high and it had to be something else...and it was... great news and what a difference in sound!!! So strange because I tried using my eq manually and could not get the top end up...must be that they needed calibration first, don't know don't care, its settled so that's good!! biggrin.gif
Now for the other BOOM!!!!
316 is offline
Old 12-15-2013, 09:37 AM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 36
Fantastic. Sometimes it is the little things we overlook !
urapnes1 is offline
Old 12-15-2013, 11:02 AM - Thread Starter
316
316's Avatar
Liked: 27
316 is offline
Old 12-21-2013, 05:53 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
I think I might hear about the Boom when I see sasquatch. Both are very elusive.
gpmbc is offline
