Anyone building with Seos15, TD15M and BMS 4550? - AVS Forum | Home Theater Discussions And Reviews
Old 10-14-2013, 02:15 PM - Thread Starter
madlim's Avatar
As the title says, has this been done or is in the doing? I'm sitting on all the parts but none of the knowledge needed...
madlim is offline
Old 10-15-2013, 01:21 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
have you considered doing a semi-active setup?
horn compensation and high pass on top run off the avr.
active control dsp/big amp on bottom.
this way there is no choke on the woofer and you can get a big amp for not much money.
crazy, but built in dsp costs about the same as crossover components...and you can build in "baffle step correction" without losing any sensitivity.
it will all still be balanced because spectral content is such that the woofer will be sucking up 10x the power as the compression driver.
active for the win.
btw, looked around again and am not familiar with the combo that you have, though i'm sure that it will get worked up at some point.
Listen. It's All Good.
LTD02 is offline
Old 10-15-2013, 02:47 AM - Thread Starter
madlim's Avatar
Actually I was thinking about going with two of the PWR-ICE125 from MiniDSP, https://www.minidsp.com/products/plate-amplifiers/pwr-ice125 or maybe even better the AS2.100 from Hypex, http://www.hypex.nl/product/2012-11-23-13-44-01/2012-11-23-13-46-04/as2-100.html which has a filtered sub out as well. Seeing the TD15M has such a high sensitivity I wont be needing my two heavy Bryston 14BSST I have today. Less boxes, happier wife!
I'm guessing there will be builds with this combo considering the recent group buys from AE and BMS, and the ongoing SEOS15.
madlim is offline
Old 10-15-2013, 03:00 AM
LTD02's Avatar
Liked: 2576
well...hang on to your amps. might find a use for them in the future. :-)
LTD02 is offline
Old 10-15-2013, 05:14 AM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
sorry, just realized it was seos15 not seos12.....
ChopShop1 is offline
