12 volt trigger for PA amp - AVS Forum | Home Theater Discussions And Reviews
Old 10-15-2013, 04:52 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
My receiver has a 12 volt trigger out x2. I have run RCA wire in my walls to where my amp will be.
Can I use a headphone to RCA for my 12v trigger?
pdxrealtor is offline
Old 10-15-2013, 04:54 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yes, that is a common way of wiring it. The trigger typically is an 1/8" mono jack but can be adapted to any two-pole wire.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
Old 10-15-2013, 04:57 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
so a mono or stereo 3.5 plug will work?
any suggestions on a 20 amp power strip or other device that will accept a trigger input?
Old 10-15-2013, 05:12 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yep.
I am using mono 1/8" jacks to bare wire with a Niles switcher.
http://www.smarthome.com/6729/Niles-Audio-AC-3-Voltage-Triggered-AC-Power-Strip/p.aspx
I don't believe it is rated for 20 amps, but I have used several of these with various pro-amps and have never had an issue. I think they are 15 amp units.
You can buy something or build your own:
http://www.avsforum.com/t/1303723/automatically-powering-on-pro-amps-via-relay-guide-w-pics
https://www.sparkfun.com/tutorials/119
http://www.htguide.com/forum/showthread.php?22378-A-12-or-120-volt-trigger-for-your-pro-amp&highlight=trigger
Joe = LFE Addict
jpmst3 is offline
Old 10-15-2013, 08:25 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Originally Posted by jpmst3 View Post
Yep.
WOW- thanks a ton! I just got my balanced mini wired up for power and RCAs on the input side. Ordered some XLR plugs for my amp etc.....
Thanks, again! I will investigate this and go with what works best for me!!cool.gif
Old 10-15-2013, 09:25 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
noah mentioned smartstrip as another option.
http://catalog.bitsltd.us/power_strips/
of course, sold many places.
Listen. It's All Good.
LTD02 is offline
Old 01-03-2014, 04:46 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Would something like this be good for the relay end of this thing?
I know I know.... I could simply buy the relay and wires and etc etc..... but I am tired. So tired. I just want my amp to turn off with my receiver.
IF I can buy this and splice it into one of my 3-5 20 amp receptacle boxes and be done well..... all the better.
Seems this box would also fit right inside the big honkin' empty space I have compliments of class D tech. Might be able to just snip, wire, and add a 1/8" jack to my amp.
https://www.platt.com/CutSheets/Functional%20Devices/RIB12P.pdf
