I need help with my 2 Behringer iNukes (DSP) - AVS Forum
post #1 of 4 Old 10-16-2013, 10:31 AM - Thread Starter
Dala's Avatar
Hello everyone. I´m a new member but I have frequently visited this forum before I registered.
I have 2-way speakers.
I have received 1 iNuke 1000DSP and 1 inuke 3000DSP in the mail today. My goal is to use the 1000DSP for my tweeters and the 3000DSP for the 7" middle/bass woofers. The tweeters are 8 Ohm, 50W RMS and the woofers are 8 Ohm 60W RMS.
Is it as simple as using the DSP´s High Pass for the tweeters on the 1000DSP and the Low Pass for the woofers on the 3000DSP?
Of course, I will experiment how "hard" the cut will be (6dB,12dB etc) and also set correct volume levels. The split will be at 3000Hz
Is it something more I should do?
Atb, David, Sweden
Dala is offline
post #2 of 4 Old 10-19-2013, 07:22 AM
LTD02's Avatar
Quoted: 109 Post(s)
Liked: 831
wow, that's a lot of power for those little guys.
try to find a frequency response measurement of the drivers and folks here will be in a better position to help you out assuming that you can't measure them yourself.
Listen. It's All Good.
LTD02 is online now
post #3 of 4 Old 10-19-2013, 07:23 AM
LTD02's Avatar
Quoted: 109 Post(s)
Liked: 831
"Is it something more I should do?"
depending on how expensive your tweeters are, a protective high pass filter (a simple capacitor) wired in series with the tweeter is always a good idea on an active system.
just in case you get a little "thump" through the system, the tweeter will stand a chance at surviving it.
LTD02 is online now
post #4 of 4 Old 10-19-2013, 07:25 AM
LTD02's Avatar
Quoted: 109 Post(s)
Liked: 831
if you need a search term "protective capacitor active speaker" should pull up some hits.
LTD02 is online now
User Tag List
