IPR7500 vs Crown XLS1500 - Graphed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-17-2013, 07:59 AM - Thread Starter
subyguy's Avatar
Liked: 26
Here's a comparison between these two amps running on my two sealed url-18's. The red curve is when I had an xls1500 bridged on each url with huge amounts of boost down low. Using my miniDSP I had a heavy low shelf with about 8db boost plus a big peak at about 15hz with 8db boost on each sub just to get things flat to 20. I also tried running a second shelf but it didn't gain much more. I then swapped out the amps for an IPR7500 with one sub on each channel and no changes to the dsp which resulted in the orange curve. I was then able to remove all boost and get pretty much the exact same curve I had before with boost. Pretty clearly shows the rolloff on the xls series amps. I still run 5 of them on all my speakers as they are great amps for full range or upper bass but not deep bass. Just for clarity these sealed subs only cover from 25Hz down while I have a JTR Orbit Shifter covering 25-90 Hz.
The IPR is a beast. I'm not going past one light and I get the feeling I could destroy the uxl's without any trouble. The fan is louder and the lights are annoying as hell but it works.
(3) JTR Noesis 212HT (LCR)
(2) JTR Single 8 (wides)
(2) JTR Slanted 8 (sides)
(2) DIY Eminence 10" coax (rear Surrounds)
(2) JTR Orbit Shifters
(2) Mach5 UXL-18's sealed
(2) Soundsplinter 15's sealed
Speakers powered by 6 crown xls 1500's
UXL's powered by Peavey IPR-7500
My theater:
http://www.avs...
subyguy is offline
post #2 of 16 Old 10-17-2013, 11:21 AM
SXRDork's Avatar
Quoted: 22 Post(s)
Liked: 42
10 dB increase from 8-10 Hz! How much do you actually realize that increase? I see that you removed the 8 dB boost later to achieve the same curve as before with the XLS so what was the point? I appreciate the measurement though. I may want to swap amps in my IB system sometime...
SXRDork: SXRD is a technology. My name is Vann. Usernames are for life...
SXRDork is offline
post #3 of 16 Old 10-17-2013, 11:34 AM - Thread Starter
subyguy's Avatar
Liked: 26
I removed all the boosts and got the same curve then added a bit back in to get a smoother curve that extends deeper. I am now able to increase the level of the subs to get more of a house curve without running into power limits. Before with over 20db of boost things weren't happy when run hot. Now I can go until I'm in pain or I mealy the voicecoils without the amp complaining.
My theater:
http://www.avs...
subyguy is offline
post #4 of 16 Old 10-17-2013, 11:58 AM
SXRDork's Avatar
Quoted: 22 Post(s)
Liked: 42
SXRDork is offline
post #5 of 16 Old 10-17-2013, 01:07 PM
beastaudio's Avatar
Quoted: 4122 Post(s)
Liked: 3459
What I did for the lights was tape a little bit of left-over black velvet from my old DIY screen to the top of the 7500. I just let it drape over the front of the amp so when the fans are running it blows up a shade, but not enough to see any of the lights. ventilation is still good enough that I have yet to see it get hot at all. I want to start working on a fan mod but I have no idea what type of replacement fans could/would work with it. If I knew I would get started yesterday.
beastaudio is offline
post #6 of 16 Old 10-17-2013, 01:24 PM - Thread Starter
subyguy's Avatar
Liked: 26
Good idea on the fabric. I have plenty if black velvet left from bat caving the room. As for fans there are 3 in the ipr. I had it opened up to wire in a relay to trigger. I should have written down the specs but didn't and now it's mounted in my rack. I have a glass door on my rack and with it closed the fan noise is acceptable and only noticeable when nothing is playing. Unfortunately it is the only piece of year that's at all audible.
My theater:
http://www.avs...
subyguy is offline
post #7 of 16 Old 10-18-2013, 04:47 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 356
Thank you so much for the info. I've never liked bridging low wattage amps. Always gotten much better performance using higher watt amps in stereo mode.
Swolephile is offline
post #8 of 16 Old 10-18-2013, 07:22 AM - Thread Starter
subyguy's Avatar
Liked: 26
The XLS isn't really a low wattage amp (at 1500w bridged same as ep4000) but it's more the built-in 20Hz filter that is the issue. I never truely believed there was one in it until now lol.
My theater:
http://www.avs...
subyguy is offline
post #9 of 16 Old 10-18-2013, 11:11 PM
notnyt's Avatar
Quoted: 2773 Post(s)
Liked: 2561
If you EQ differently, overlaying the curves is kind of worthless. How about graphs without any EQ? Or at least use the same EQ.
notnyt is offline
post #10 of 16 Old 10-19-2013, 07:21 AM - Thread Starter
subyguy's Avatar
Liked: 26
Reading comprehension LOL...
"I then swapped out the amps for an IPR7500 with one sub on each channel and no changes to the dsp which resulted in the orange curve."
My theater:
http://www.avs...
subyguy is offline
post #11 of 16 Old 09-10-2014, 08:49 AM
MKtheater's Avatar
Quoted: 1736 Post(s)
Liked: 1306
Do you have any IPR 7500's?
MKtheater is offline
post #12 of 16 Old 09-10-2014, 09:16 AM
DevonDeyholos's Avatar
Quoted: 187 Post(s)
Liked: 181
I hope he doesnt mind me answering for him... But I was at his house a few weeks ago and no, he doesnt have any of the original IPR's. He has the newer IPR-2 7500
DevonDeyholos is offline
post #13 of 16 Old 09-10-2014, 01:09 PM
MKtheater's Avatar
Liked: 1306
I may be in the market to buy one.
post #14 of 16 Old 09-10-2014, 01:15 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
You just missed out...amazon had the ipr2-7500 for 549.00 over labor day.
basshead81 is offline
post #15 of 16 Old 09-10-2014, 01:21 PM
MKtheater's Avatar
Liked: 1306
That is OK, I accept my slowness.
post #16 of 16 Old 09-11-2014, 08:08 AM - Thread Starter
subyguy's Avatar
Liked: 26
As Devon mentioned, I just have the IPR2. I actually have another one that failed and is in for repair right now. If they manage to get it working I will run it on my LR and really be able to EQ the Noesis 212's with all that extra power.
My theater:
http://www.avs...
subyguy is offline
Crown Xls 1500 Power Amplifier 2 Channel 525w 4 Ohms Per Ch
