Boston Acoustic sub/sat6 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-20-2013, 08:35 AM - Thread Starter
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Hey guys. I have avfriend who has a Boston sub/sat6 system. Because the design of combining the main and subwoofers with the main L&R there is no way to raise and lower the subs independant of the mains.
My solution is a smallish plate amp for the sub woofers and then he can use the LFE out on his receiver and the plate amp volume to tune it better.
The solution will cost him a mere $99 for a http://www.parts-express.com/pe/showdetl.cfm?partnumber=301-506
Here's the big question, the sub has two speaker binding post, implying two drivers ok. Do i wire them in series or parallel, i dont know their independant resistance....... Can i simply measure each binding post for impedence ????
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #2 of 5 Old 10-20-2013, 09:22 AM
tuxedocivic's Avatar
Quoted: 1905 Post(s)
Liked: 1725
I'd just put a multimeter on the posts and get a DC reading, assuming there isn't any circuit in the path that would affect the reading. They should be similar. If DC resistance is about 7ohms then you have two 8 ohm drivers and can wire in parallel.
Ryan
tuxedocivic is online now
post #3 of 5 Old 10-20-2013, 07:33 PM
Looneybomber's Avatar
Liked: 25
Is there a way to incorporate an EQ instead of having to put a new amp in?
YID DIY
Looneybomber is offline
post #4 of 5 Old 10-21-2013, 08:40 AM - Thread Starter
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Very interesting...... I will check the owners manual for an onboard EQ.... Nice call Looney, nice call....
post #5 of 5 Old 10-22-2013, 05:36 AM - Thread Starter
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Looks like the bass tone control is centered at 50hz, an increase of about +4db did the trick ! Its probably wide enough to add a little more rumble down low.
Problem solved !
