QSC Ref Monitor System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-20-2013, 11:55 AM - Thread Starter
Genelec Man's Avatar
Quoted: 13 Post(s)
QSC just came out with a new speaker. Wish we could get a hold of their new waveguides. Subs use Lab12's and the compression driver appears to be the coax BMS they use on their larger cinema horns. I really like the looks of the dual 12's underneath. 6 Lab12's (LCR) up front crossed over to an appropriate sub would work "pretty" good.
http://www.dcinematoday.com/dc/pr.aspx?newsID=3420
Genelec Man is offline
post #2 of 10 Old 10-20-2013, 06:01 PM
Aaron Smith's Avatar
Quoted: 139 Post(s)
Liked: 58
Interesting to see that they don't bring in the midrange compression driver until 1200 Hz....they actually call the BMS elements 'HF' and 'VHF'. smile.gif
Aaron Smith is offline
post #3 of 10 Old 10-20-2013, 06:17 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
that's funny. looks like a diy project. definimax midrange, lab12 (with upgrade to 3" voice coils)?
I wonder what it will cost. $500 for coax, $300 for other three drivers?, $200 for box? retail $4k?
Listen. It's All Good.
LTD02 is offline
post #4 of 10 Old 10-20-2013, 07:29 PM
BadmanSound's Avatar
port area looks low for a driver like the lab12... esp considering it should be an UPGRADED lab 12.
BadmanSound is offline
post #5 of 10 Old 10-21-2013, 03:39 AM
LTD02's Avatar
Liked: 2578
good observation. the small enclosure kind of dictates an undersized port though. seems like a marketing decision.
LTD02 is offline
post #6 of 10 Old 10-21-2013, 05:47 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
The sub is not really a subwoofer. Its more like a mid-woofer that extends the response of the top box a bit and give some more headroom.
SPECIFICATIONS
Rated Coverage Angle (-6 dB) Omnidirectional
Frequency Range1 (-10dB) 30 Hz to 120 Hz
Crossover Frequencies 80 to 120 Hz (selectable) up to 48 dB/oct using dedicated Q-Sys DSP
Rated Noise Power (Voltage)2 1000 W
Sensitivity3 96 dB
Maximum continuous SPL4 120.5 dB
Maximum peak SPL4 126.5 dB
Rated Impedance 3Ω
Recommended Amplifier Power 1000 W
Transducers 2 x 12 in. (305 mm) Kevlar-reinforced paper cones, 3 in. voice coils
http://qsc.com/products/Loudspeakers/Reference_Monitor_System/RSB-212/
splotten is offline
post #7 of 10 Old 10-21-2013, 06:29 AM
LTD02's Avatar
Liked: 2578
subwoofer means different things in the pro audio world.
here is a pair of lab12's in 4 cubic feet tuned to 38hz. sensitivity 94db (1 watt, probably 96db with 2.83v into 4 ohms), -10db point 30hz before eq.
seems tuned a little high for a "studio subwoofer" though. that much is a little weird.
LTD02 is offline
post #8 of 10 Old 10-21-2013, 09:47 AM
And the enclosure is ven smaller than that, like less 3 cubic feet internal...
post #9 of 10 Old 10-24-2013, 11:13 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Not just the linked product, but throughout their current lines .... IMO it's nice to see QSC approach such offerings with such design choices, I'm all for 'em.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #10 of 10 Old 10-24-2013, 11:17 AM
LTD02's Avatar
Liked: 2578
says the guy with 4350's in his avatar. :-)~
the sheer scale of those things is in part what made them...both great and extinct?
LTD02 is offline
