Doug's dual Gjallarhorn build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #91 of 213 Old 11-22-2013, 10:44 PM
Archaea's Avatar
Quoted: 2826 Post(s)
Liked: 2413
HA!
My pleasure man. If you have any trouble with the vid card install/setup - just shoot me a pm and I'll swing back by.
Archaea is online now
post #92 of 213 Old 11-22-2013, 11:00 PM
lukeamdman's Avatar
Quoted: 1071 Post(s)
Liked: 1187
Originally Posted by d_c View Post
The server room scene from Pulse knocked the snot out of my nose. I thought that was pretty good!
Perfect! That scene was made for the Ghorns!
lukeamdman is offline
post #93 of 213 Old 11-25-2013, 09:33 AM
Archaea's Avatar
Liked: 2413
Could gjallarhorn's be built with MDF? Or does it need to be birch void free plywood?
Does anyone know if Erik is planning to build a flatpak for gjallarhorns?
post #94 of 213 Old 11-25-2013, 09:55 AM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
MDF would be extremely heavy and from what I understand the ply is greater in strength to withstand the extreme pressure the horn generates. Flat pack would indeed be awesome.
gpmbc is online now
post #95 of 213 Old 11-25-2013, 10:02 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I would guess that there is <1% chance that there would ever be a flatpack.
There is simply too much wood involved. The wood alone in this build weighs more than 200lbs. (and that is with plywood, add significantly more lbs for MDF which I would not recommend using anyway)
In addition, there are only a handful of people building them. It would not be worth the machine time to make a kit.
Plus MDF is too fragile in something this heavy.
If you can't get it done, it would be better to have your local wood shop/cabinet shop build them for you.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is online now
post #96 of 213 Old 11-25-2013, 10:40 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
You would only be saving around $225 for two going with mdf and it would be about 60# more each. Neither is that big of a deal in the end. The problem with mdf in these are the reasons listed in the above posts, which are pretty important reasons, but also that mdf would not take the dings and bumps as well as the bb when they get moved around. You have seen my collection of giant horns, trust me, you don't want a giant horn made from mdf. Also, there is a lot of cutting. That much mdf dust could give a small city mesothelioma!
d_c is offline
post #97 of 213 Old 11-25-2013, 11:10 AM
Whatever1's Avatar
Quoted: 27 Post(s)
If you can't get it done, it would be better to have your local wood shop/cabinet shop build them for you.[/quote
Where can one find a set of plans ?
Whatever1 is offline
post #98 of 213 Old 11-25-2013, 11:13 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I am sure Ricci would be willing to send you the plans if you contact him directly. Some of us have them but I would not want to share them without his permission.
Joe = LFE Addict
post #99 of 213 Old 11-25-2013, 11:20 AM
lukeamdman's Avatar
Liked: 1187
Agreed. These are so heavy that their own weight could crush a corner or something if they were made out of MDF. I'd say just the empty cabinet would weigh somewhere around 250lb's when made out of BB, possibly more.
post #100 of 213 Old 12-22-2013, 08:38 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
I have the first couple of coats of Kilz on, now I have some sanding on the horn mouth, and a couple of coats of finish. I'm not a fan of MH Patch at all. I chipped most of it off and repatched with Bondo. MUCH stronger and doesn't chip.
LTD02 likes this.
d_c is offline
post #101 of 213 Old 12-22-2013, 08:44 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Awesome twins you have there!
I am quite sure you will be a happy camper!
Joe = LFE Addict
post #102 of 213 Old 12-22-2013, 08:45 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5278 Post(s)
Liked: 4163
Woah! Dual Ghorns, yeah!
Scott Simonian is offline
post #103 of 213 Old 01-02-2014, 12:08 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
Gasket tape vexes me, so I came up with this so I don't have to avoid running a bolt through the middle of it and finding it all wadded up next time I remove a driver or hatch.
These photos don't look much different than the last ones, but the difference is huge. They have the final coat of paint, wiring soldered in, drivers cleaned and installed, and are going to their final resting place in to the ceiling tomorrow. You will notice some bolts on the inside of the horn mouth: 1/2" bolts are replacing those, so I guess they aren't COMPLETELY finished. Don't judge me.
Scott Simonian and LTD02 like this.
d_c is offline
post #104 of 213 Old 01-02-2014, 07:04 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
You are going to be in another dimension with two of those bad boys!
Joe = LFE Addict
post #105 of 213 Old 01-03-2014, 03:27 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
d_c is offline
post #106 of 213 Old 01-03-2014, 03:29 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yowsers!
That is no small chore getting two of those monsters into that space. eek.gif
Best of luck, don't get hurt.
Joe = LFE Addict
post #107 of 213 Old 01-03-2014, 03:33 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
d_c is offline
post #108 of 213 Old 01-03-2014, 03:35 PM
lukeamdman's Avatar
Liked: 1187
post #109 of 213 Old 01-03-2014, 03:35 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
d_c is offline
post #110 of 213 Old 01-03-2014, 03:42 PM
Archaea's Avatar
Liked: 2413
you played them yet in their home position?
post #111 of 213 Old 01-03-2014, 03:53 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Damn, I wish I had a space like that above my HT!
Scott Simonian likes this.
Joe = LFE Addict
post #112 of 213 Old 01-03-2014, 04:23 PM
Bass Enabler
Liked: 4163
post #113 of 213 Old 01-03-2014, 05:46 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
That is awesome and scary.
gpmbc is online now
post #114 of 213 Old 01-03-2014, 06:22 PM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 471
Ricci is offline
post #115 of 213 Old 01-03-2014, 08:50 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
It was really easy getting them in to place using the winch and ramp. I hooked the one on the right up for a quick listen and can tell already that they will need to be moved. I won't be able to get the mic to them for a few days. Most of the sound goes right through the roof since they pretty much open air with the drywall and insulation out. The neighbor called and thanked me for knocking the dust off the ceiling for them as I blasted a few tracks by Excision. That was just one at medium volume.
d_c is offline
post #116 of 213 Old 01-03-2014, 08:52 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
Originally Posted by Ricci View Post
Too late, already braced up the ceiling so I wouldn't have any bad thoughts like that!
d_c is offline
post #117 of 213 Old 01-03-2014, 09:15 PM
Archaea's Avatar
Liked: 2413
ha. The entire surface area of the roof of your house is probably broadcasting sound like an exciter
post #118 of 213 Old 01-04-2014, 12:45 AM
BadmanSound's Avatar
give this one a play at some point, would love to hear your thoughts smile.gif
BadmanSound is offline
post #119 of 213 Old 01-04-2014, 06:46 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
That was my only concern as I pondered what would happen at my place if that were even possible here.
I have an outdoor system with two 10" horns and it rocks the neighborhood with only 150w applied. I can't imagine two ghorns with any kind of power having a route to the outside. eek.gif
You might see some for sale signs popup after movie night at your place.biggrin.gif
Joe = LFE Addict
post #120 of 213 Old 01-04-2014, 07:21 AM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
If there was ever a time where audio nirvana could shine its favorable light on you and allow you to put the subs in the right place on the first try, this would have been it. I guess there is no audio nirvana.
Thank you for allowing me a place to point my Wife when she thinks I am "Crazy".
Well done.
Stereodude likes this.
btinindy is offline
