Doug's dual Gjallarhorn build - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #181 of 213 Old 04-14-2014, 06:23 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
I can't feel any air at all. I can feel energy, ie clothes shaking, nose itch, floor vibrates. There is not much air that you can feel that comes out anyways with the huge horn mouth.
d_c is offline
post #182 of 213 Old 04-14-2014, 08:03 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
No, you wouldn't.
It's just like the reverse. If you put you your hand on the end of the shop vac hose it sucks your hand up violently...a few inches away and nothing.
The air is pushed around right at the mouth in close proximity. Beyond that range there are pressure waves.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #183 of 213 Old 04-15-2014, 01:54 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
I forgot how loud the fans are on the clone. What's the consensus on swapping them out? Does this mod relate to failure of the amp or no?
d_c is offline
post #184 of 213 Old 04-15-2014, 06:06 AM
blazar's Avatar
Quoted: 730 Post(s)
Liked: 532
Just find some Nexus computer fans and be sure the resistance matches or get a speed control
Blazar!
blazar is offline
post #185 of 213 Old 06-05-2014, 09:25 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
Done
Couch and stuff to deliver next week and the rest of the gear to install and I'll post up some measurements soon. I have some mains to build too.
When I sit at the LP, my vision blurs nicely with my new favorite demo track - buy the flac file, it's worth the $2:
http://youtu.be/3UlUji6Qp7A
d_c is offline
post #186 of 213 Old 06-06-2014, 05:42 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Nice! Did you ever get a chance to tune your subs?
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #187 of 213 Old 06-06-2014, 06:18 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Done
Great job on the fit and finish! That really looks cool!
Joe = LFE Addict
jpmst3 is offline
post #188 of 213 Old 06-06-2014, 08:01 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
I will set up the mic and get things dialed in hopefully next week
Thanks man - the LEDs really showcase the driver that has been hidden up there. The plan is to make grills with white grill cloths for the subs and surrounds. I sure like looking at the drivers for now though.
d_c is offline
post #189 of 213 Old 06-06-2014, 08:23 AM
robotbunny's Avatar
Wow Doug! Great job, can't wait to hear this rig. ;-)
Nate
robotbunny is offline
post #190 of 213 Old 06-06-2014, 09:52 AM
Ricci's Avatar
Quoted: 240 Post(s)
Liked: 566
Excellent finishing work. Bravo.
Ricci is offline
post #191 of 213 Old 06-06-2014, 09:52 AM
Archaea's Avatar
Quoted: 3071 Post(s)
Liked: 2680
Looking good Doug!
Archaea is offline
post #192 of 213 Old 06-06-2014, 10:49 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5832 Post(s)
Liked: 4833
Oh sweet!
Nice finish, Doug. Looks great and I bet it sounds awesome. smile.gif Blurring your vision is definitely what I like to hear. biggrin.gif
Scott Simonian is online now
post #193 of 213 Old 06-06-2014, 11:07 AM
gpmbc's Avatar
Quoted: 336 Post(s)
Liked: 206
That's the stuff!
gpmbc is online now
post #194 of 213 Old 06-06-2014, 11:26 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
d_c is offline
post #195 of 213 Old 06-30-2014, 09:36 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Wow
One of the most awesome builds I've seen.
Mfusick is offline
post #196 of 213 Old 07-21-2014, 07:00 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
I finally ran some sweeps with the room done. Not nearly as bad as I thought!
No Audessey, no EQ, no processing
After Audessey xt32
d_c is offline
post #197 of 213 Old 07-21-2014, 07:04 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
With Mains, 1/6 smoothing, 2.5db hot on the AVR which measures 10db hot with both subs (my normal preference, add 10 more for demos )
The mains are AE TD12m/DNA-360 SEOS. Measurements are 2ch with both subs
d_c is offline
post #198 of 213 Old 07-21-2014, 07:37 PM
Archaea's Avatar
Liked: 2680
Very nice Doug!
Archaea is offline
post #199 of 213 Old 07-21-2014, 07:39 PM
gpmbc's Avatar
Quoted: 336 Post(s)
Liked: 206
Solid!
gpmbc is online now
post #200 of 213 Old 07-22-2014, 03:56 AM
chrapladm's Avatar
Quoted: 927 Post(s)
Liked: 346
Look awesome DC.
chrapladm is offline
post #201 of 213 Old 07-22-2014, 10:14 AM
carp's Avatar
Quoted: 2782 Post(s)
Liked: 2088
That is a sweet looking response, especially for REW which seems to be choppier than the omnimic at least from the graphs I have seen.
So you have your mains done? Pictures? Or did I miss them. What are you crossing them at?
carp is offline
post #202 of 213 Old 07-22-2014, 04:38 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
Yes and no. I built some temporary cabs so I can listen to them while I make some nice ones. They will perform the same, and they sound awesome. The sweet spot is 10 feet wide. I have them crossed at 60hz, or I should say Audessey crossed them at 60. I tuned them to 45, so a xo at 60 is perfect for these.
ORIF likes this.
d_c is offline
post #203 of 213 Old 07-22-2014, 04:41 PM
gpmbc's Avatar
Quoted: 336 Post(s)
Liked: 206
Clean set up, I really like how you did the edges of the speakers and the port.
gpmbc is online now
post #204 of 213 Old 07-22-2014, 05:59 PM
Samps's Avatar
Quoted: 896 Post(s)
Liked: 499
Have the police visited yet? You should send a few dozen donuts to your local station.
Samps is online now
post #205 of 213 Old 07-22-2014, 06:39 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
Thanks - the baffle edge on the final ones will be deeper and steeper, with curved sides. I dig the port too, so that will stay the same.
Not that I have noticed
The downside to these subs is that they empty the contents of the pantry shelves to the floor when I play the server room scene from Pulse at +10 reference with subs +10db hot. My wife does not approve of this.
d_c is offline
post #206 of 213 Old 04-16-2015, 01:57 PM
Archaea's Avatar
Liked: 2680
For the upcoming KC HT crawl, you should put together a before and after slideshow - showing your room conversion.
It's just darn impressive!
BTW --- where's the picture of the new finish on the center channel?
Archaea is offline
post #207 of 213 Old 04-16-2015, 03:03 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
d_c is offline
post #208 of 213 Old 04-19-2015, 12:42 PM
louisdamani's Avatar
louisdamani is offline
post #209 of 213 Old 04-19-2015, 12:51 PM
michaelddd's Avatar
Quoted: 322 Post(s)
Liked: 207
That is one heck of an impressive picture. To the unmitigated, they'd ask "Why is there a fan inside a box in your ceiling?" To those in the know, it would be shocking to see that and so nicely integrated too. Great work!
Done
michaelddd is offline
post #210 of 213 Old 04-20-2015, 08:45 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 877 Post(s)
Liked: 1008
d_c is offline
