Mounting the crossover? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-28-2013, 01:08 AM - Thread Starter
ozziedog's Avatar
Liked: 24
Alright, I thought I was done asking questions but I have one more. How should I mount the crossover in the Tempests?
This should be the last question.
ozziedog is offline
post #2 of 8 Old 10-28-2013, 03:19 AM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
Mount the crossover directly to the side or bottom of the cabinet.
Screw it in, and use a rubber washer between the crossover board and cabinet to space it out by a hair, and stop vibrations.
Thatsnasty is offline
post #3 of 8 Old 10-28-2013, 06:51 AM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
i used industrial strength velcro. mine are either on the side or back depending on size
Sibuna is offline
post #4 of 8 Old 10-28-2013, 08:50 AM
Looneybomber's Avatar
Liked: 25
I've used gasket tape and screwed 'em down and I've used good Velcro. I've put them on the bottom and on the sides. Every way and position has worked fine for me.
YID DIY
Looneybomber is offline
post #5 of 8 Old 10-28-2013, 12:41 PM
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
I used Velcro and mounted it on the side wall in the upper part if the cabinet in my Fusion 10 Pure's.
mmarki is online now
post #6 of 8 Old 10-28-2013, 01:55 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Mrkazador is offline
post #7 of 8 Old 10-28-2013, 03:47 PM
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
^^^ that's what I used.
post #8 of 8 Old 10-28-2013, 05:02 PM
maxcooper's Avatar
Quoted: 13 Post(s)
I screwed some felt furniture pads, since I didn't have any rubber washers.
Be careful not to screw all the way through the cabinet -- you don't want any screw points sticking out the side.
-Max
maxcooper is offline
