Final verdict on iNuke series low end roll-off? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-29-2013, 02:55 PM - Thread Starter
BrickTop's Avatar
Quoted: 47 Post(s)
Liked: 31
I have read a LOT of threads about the iNukes and may have missed something, but I cannot find a definitive answer as to the roll off of them. I am debating the NU3000DSP or another EP4000 for my buttkickers. Obviously I want the least amount of roll off and know the EP4000 has been measured to 5hz. The iNuke is so appealing, with its light weight and DSP (not so much for the buttkickers but may be useful in the future). Any info I am missing or opinions on one versus the other?
Bricktop
BrickTop is offline
post #2 of 10 Old 10-29-2013, 03:02 PM
chalugadp's Avatar
Quoted: 1673 Post(s)
Liked: 1531
Originally Posted by BrickTop View Post
I have read a LOT of threads about the iNukes and may have missed something, but I cannot find a definitive answer as to the roll off of them. I am debating the NU3000DSP or another EP4000 for my buttkickers. Obviously I want the least amount of roll off and know the EP4000 has been measured to 5hz. The iNuke is so appealing, with its light weight and DSP (not so much for the buttkickers but may be useful in the future). Any info I am missing or opinions on one versus the other? Thanks,Bricktop
My 3000 dsp is good down to 16 hz which is my port tuning . Below that I don't know .
chalugadp is offline
post #3 of 10 Old 10-29-2013, 03:42 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 44
Ep4000 is 5hz.
Inuke is maybe 2-3 db @ 10hz
Both would be good for about 99% of people.
LTD posted the chart in another thread, see if I can find it..
Thatsnasty is offline
post #4 of 10 Old 10-29-2013, 05:19 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
Here it is....
"If you're building sealed 18 subs keep in mind that the iNuke's FR starts rolling off just below 20Hz from the reports I've read."
who is spreading that mis-information?
http://forum.speakerplans.com/behringer-inuke-nu6000-vs-kam-kxd7200-bench-tested_topic69202.html
laugsbach is offline
post #5 of 10 Old 10-29-2013, 05:36 PM - Thread Starter
BrickTop's Avatar
Quoted: 47 Post(s)
Liked: 31
So it is down at 10hz. I think for a transducer the ep4000 looks better.
Sent from my Rezound using Tapatalk
BrickTop is offline
post #6 of 10 Old 10-29-2013, 07:22 PM
LTD02's Avatar
Quoted: 2495 Post(s)
Liked: 2830
here is the image again, so that it can be expanded on screen.
it is down about 2db at 10hz, which is roughly consistent with a first order highpass filter having a -3db point at 8hz.
if 3db at 8hz is deemed important, a shelf filter could be applied to bring it back up by 3db for "flat to 8hz".
Listen. It's All Good.
LTD02 is offline
post #7 of 10 Old 10-29-2013, 07:36 PM
steve nn's Avatar
Liked: 433
^^^ That being the case, my concern is more directed at the noise level of the fans between the two of them. One (i) is loud and one (E) is not as loud.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #8 of 10 Old 10-29-2013, 09:11 PM
nfraso's Avatar
Liked: 172
Having a response down -2dB at 10Hz is different from being capable of delivering full power at 10Hz, right?
nfraso is offline
post #9 of 10 Old 10-29-2013, 09:18 PM - Thread Starter
BrickTop's Avatar
Quoted: 47 Post(s)
Liked: 31
I was under the understanding that the iNukes DSP could not apply a filter below 20 Hz, so it would have have a center frequency at 20. You could boost it with an mini DSP, but that defeats having an nu3000dsp. Still looks like a good amp, but with single digits being important for a tactile transducer, it seems to have a weakness in that respect. Decisions, decisions.
BrickTop is offline
post #10 of 10 Old 10-29-2013, 09:54 PM
chalugadp's Avatar
Liked: 1531
The 3000 dsp can go lower then 20 hz with a workaround . As for single digit hz being important that would be for a single digit percentage crowd. If its important for you then you will need one of the pros here to answer that.
Behringer Nu3000 Inuke Ultra Lightweight High Density 3000 Watt Power Amplifier , Behringer Europower Ep4000 Professional Amplifier
