Swolephile's SI 24" Assemble Yourself Build - Page 8 - AVS Forum
post #211 of 281 Old 03-06-2014, 11:14 AM
ChopShop1's Avatar
Quoted: 62 Post(s)
Liked: 187
Yeah, it's really not best suited for ported
ChopShop1 is offline
post #212 of 281 Old 03-31-2014, 05:39 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
I shall be placing my order for a second SI 24 this month. I was contemplating going with a bigger box, but if I do, I will need to order a second box for my first SI 24. I have a question, how can I get to a 12-15 cubic ft. box with less depth. I dont mine width or height, but any box over 18'' deep is a pain in the a$$ to move. What dimensions could I use for a 10, 12, and 15 cubic ft box that is only 18'' deep?
Swolephile is offline
post #213 of 281 Old 03-31-2014, 05:49 PM
WereWolf84's Avatar
Quoted: 53 Post(s)
Liked: 27
WereWolf84 is offline
post #214 of 281 Old 03-31-2014, 06:13 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Originally Posted by WereWolf84 View Post
In my opinion the only people who need every ounce of performance sans a HUGE box with this driver are those using very high crossovers, speakers with very little low end capability, power limited, or a very big,open room. My setup has none of those issues so I do not need a gargantuan box.
post #215 of 281 Old 03-31-2014, 06:53 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Anyone?
post #216 of 281 Old 03-31-2014, 06:55 PM
WereWolf84's Avatar
Quoted: 53 Post(s)
Liked: 27
post #217 of 281 Old 03-31-2014, 06:55 PM
ChopShop1's Avatar
Quoted: 62 Post(s)
Liked: 187
42x42x18 is a little over 15 and a half cubes gross....add the double baffle and you're either a little over 18 or down to a gross volume of 15 even if you want to keep it at 18 after double baffle
post #218 of 281 Old 03-31-2014, 06:59 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Ok thank you very much Chop.
post #219 of 281 Old 03-31-2014, 07:07 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
http://www.hometheatershack.com/forums/enclosure-volume-calculator/
I forgot about the auto box volume calculator at HTS. Thank you for the link.
post #220 of 281 Old 04-01-2014, 01:42 PM
Say No to Auto EQ
beastaudio's Avatar
Quoted: 972 Post(s)
Liked: 1043
This is another good resource as well:
http://www.the12volt.com/caraudio/boxcalcs.asp
(European models do not accept banana plugs.)
"If you done it, it ain't bragging." ~ Walt Whitman
AE TD12x SEOS12 Build
Beast's DIY Master Measurement Thread
DIY Emminence Coaxial Surround Thread
beastaudio is online now
post #221 of 281 Old 04-01-2014, 05:07 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Thanks Beast.
post #222 of 281 Old 04-20-2014, 02:25 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Still LOVING this woofer. I have a new set of neighbors so i can't play my music more than around 70db in the evenings right now. Music still sounds full, deep, and articulate thanks to the luxurious bass offered by the SI 24 even at low volume levels. Excellent for us condo/apartment dwellers. I can't wait to get my hands on one more of these to complete my setup. I recently changed out my receiver for a preamp and the setup sounds amazing. Signal strength is much better. Music quality is clearer and there is no more god forsaken ground loop buzz thanks to the xlr connections. Bass sounds cleaner now as well. This sub is definitely a stunning all in one package. It gets louder than my other four 18" subs I had up front before and it sounds TIGHTER as well. Definitely has AUDIOPHILE QUALITY BASS that matches my Bagend Infrasub 18 and Velodyne DD18 subs I had before.I keep saying one more song and then I will call it a night. I said that at 7pm and it's 1am now and I'm still jamming late. Listening to Vanessa Williams Dreaming right now. Bass is sultry smooth, deep, ultra tight, and soothing. This sub is definitely a MASTERPIECE combo of articulation and raw spl capability all in one package. Loving and savoring every moment with this sub!!!!
post #223 of 281 Old 04-20-2014, 05:18 PM
Rhino11's Avatar
Nice I can't wait to get my 24's I already got my 2 18's. But I want my 24's wink.gif
Rhino11 is offline
post #224 of 281 Old 04-20-2014, 09:48 PM
Electrodynamic's Avatar
Quoted: 68 Post(s)
Liked: 129
I think[know] you're in for an aural assault once you get the HS 24 playing. smile.gif The last G2G showed everyone what a single HS 24 is capable of. I'm very happy with the outcome. cool.gif
PS: The parts needed to keep building these monsters will arrive later this week. biggrin.gif
Electrodynamic is offline
post #225 of 281 Old 04-20-2014, 11:31 PM
BassThatHz's Avatar
Quoted: 429 Post(s)
Liked: 457
70db? Brutal.
Soundproofing has helped me tremendously in this regard.
I used to be able to play almost no amount of sound.
Now I can play up to THX Reference above 200hz, and at least 80db of bass below 200hz, and 100db of bass below 15hz 24/7/365 without cops showing up.
Here is an example of my soundproofing in action... as of tonight:
note: There is a train passing by outside.
[Best with headphones cranked]
As you can see, it pretty much blocks out all the treble.
I don't recall if you ever posted any graphs?
I'd like to see how it's interacting with your room.
BassThatHz is online now
post #226 of 281 Old 04-21-2014, 09:38 PM
Rhino11's Avatar
Rhino11 is offline
post #227 of 281 Old 06-25-2014, 06:06 PM
WereWolf84's Avatar
Quoted: 53 Post(s)
Liked: 27
Hi Swolephile, have you received your second HS24 and start building on it?
post #228 of 281 Old 08-27-2014, 02:54 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
I plan on ordering my second SI 24 in September. Though Im now lusting for a ported design.
post #229 of 281 Old 08-27-2014, 03:01 PM
Say No to Auto EQ
beastaudio's Avatar
Quoted: 972 Post(s)
Liked: 1043
ported 24? You comfortable with a 32 cuft box? Haha
post #230 of 281 Old 08-27-2014, 03:06 PM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 824 Post(s)
Liked: 580
Nothing like a small ported sub.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, BG Radia, SVS & Def Tech, Denon, Marantz & Yamaha .
AV Science Sales 5 is offline
post #231 of 281 Old 08-27-2014, 03:12 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Hell no!!! Haha. But since when is lust a logical emotion? I want to do the 15 cubic ft box like what you had at the gtg, but I seriously dont know if I can fit one, let alone two boxes that size. Every home Ive looked at in the last few months has no room which could accomodate two 15 cubic ft monster boxes. And this is disparaging coming from me because I love big equipment. Usually the bigger, the better in my opinion. But my current setup is reaching a breaking point in terms of space.
post #232 of 281 Old 08-27-2014, 07:56 PM
383-s-10's Avatar
Why not IB.... Two 24s in IB would work......
383-s-10 is online now
post #233 of 281 Old 08-27-2014, 10:51 PM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
IB is a definite consideration once I settle on a permanent residence.
post #234 of 281 Old 09-08-2014, 12:11 AM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Anyone think I could gain any advantages by going with a bass tower consisting of two 24s in one sealed box and corner load it. Or would two separate boxes be a better option due to a more even room response? Oh man a bass tower consisting of two 24s just sounds so cool!
post #235 of 281 Old 09-08-2014, 09:20 PM
Quoted: 68 Post(s)
Liked: 129
A bass tower does sound cool but multiple enclosures could help smooth out room nodes more than all of the drivers in one location.
post #236 of 281 Old 09-09-2014, 12:13 AM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Thanks for the advice Nick.
post #237 of 281 Old 09-09-2014, 10:23 PM
Quoted: 68 Post(s)
Liked: 129
It may sound "silly" but harnessing a single HS 24" is hard enough to begin with. You know this from personal experience. It is hard to keep the enclosure from moving around and/or vibrating at extremely low frequencies. Now multiply that by a factor of 2x for two HS 24's in the same enclosure and you have a major problem with enclosure and structural solidity.
post #238 of 281 Old 09-10-2014, 09:02 AM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Understood Nick. Then at this point it looks like I will go with another smallish enclosure(8-10 cubic ft). Just for fun I will also add two rear subs. I'm thinking two downfiring Dayton Ultimax 18's or SI 18s(if available) should do the trick. Then I will be back up to 7.4 which was my original plan.
post #239 of 281 Old 09-10-2014, 10:23 AM
Sibuna's Avatar
Quoted: 281 Post(s)
Liked: 348
a dual 24 tower sounds awesome, until you have to move it
Sibuna is offline
post #240 of 281 Old 09-10-2014, 11:08 AM - Thread Starter
Swolephile's Avatar
Quoted: 26 Post(s)
Liked: 55
Lol. I thought about that two. My brother bitches when we have to move the single SI 24 around. So I can only imagine what he would say with dual 24 box. I'm guessing it would be at least 250lbs+.
Yorkville Unity U215 1600w Passive Speaker , Yorkville Unity U15 800w Passive Speaker , Klipsch Sub 12
Gear in this thread - U215 by PriceGrabber.com
