SQ DIY sub to match Anthony Gallo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-03-2013, 02:20 AM - Thread Starter
nume01's Avatar
Hi all
sorry to bug you with this but I nead some nice sub woofer for my HT
I have search around the net, maybe not enough, but haven't found what I nead...
The thing is that I nead advice for some nice diysubwoofer with SQ on mind.
I have budget of around 300Euro for a driver (new in store / hoping to find the sime used driver for 200Euro on ebay)
I have 500W IcePower D class amp
Was planing to use minidsp (2/4) for setup crossover and phase
(or if you could advise me some kit that have classic, frequency cut, phase,gain...instead of useing minidsp just for sub)
I have small apartment with living room of 3.5mX6m (2.6m height) which is connected to a kitchen at half wide with dimension 2x2.5m
And it would be nice that I can easily integrate it with anthony gallo speakers which I will use in HT system (have due's for front and center, and nucleus for back...5.1 system)
and would like to use it as a coffee table ;), so maybe something like 60x60x20cm would do ;)...or smaller...not bigger...like 50L or so...the smaller the beter ;)
So please advice me what to build;
what driver
what volume for closed design
(I was thinking something like peerless XXLS12...but...I'm open to sugestions ;))
big thanks
Josip
nume01 is offline
