Cinemar Theater - Dual Dayton RSS460HO 18" Flat Pack Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 11-05-2013, 02:56 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Hi Everyone.
Before I dive into the nitty gritty details of my first DIY sub build.
I thought I'd reference my original build thread where I've also documented the sub portion of the build:
http://www.avsforum.com/t/1208912/the-cinemar-home-theater-construction-thread
The actual build with lots of photos are below.
mcascio is offline
post #2 of 33 Old 11-05-2013, 02:57 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Here's my adventures in building two sealed 4 cu ft DIY Flat Packs with the Dayton Audio RSS460HO-4 18" Reference HO Subwoofer 4 ohm subwoofers. As of this writing I completely finished one of them. I'm a complete novice in this area...so be gentle.
2' clamps were all that I would have needed for this project instead of 3' clamps.
Here's a quick parts list for the project:
Dayton Audio 18" Reference Series HO Subwoofer and Cabinet Package
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-7094
Dewalt 3-Amp Orbital Power Sander
http://www.lowes.com/pd_117946-70-D26453K_0__?productId=1005793&Ntt=orbital+sander&pl=1&currentURL=%3FNtt%3Dorbital%2Bsander&facetInfo=
BIN Primer (tinted gray or as dark as possible)
http://www.menards.com/main/building-materials/drywall/primers-sealers/bin-primer/p-1963340-c-8028.htm
Sandblaster Premium Abrasive (For baffle area and edges)
http://www.menards.com/main/paint/sandpaper-respirators/sanding-blocks-sponges/sandblaster-trade-premium-abrasive/p-1419949-c-8193.htm
TiteBond II
http://www.menards.com/main/home-decor/cter
ts/glue/wood-glue/titebond-ii-premium-wood-glue-32-ounce/p-1956875-c-7176.htm
Rust-Oleum Flat back Spray Paint
http://www.menards.com/main/home-decor/crafts/spray-paint/all-purpose/rust-oleum-painters-touch-ultra-cover-2x-spray-flat-black/p-1956007-c-8050.htm
Truck Bed Boating
http://www.menards.com/main/home-decor/crafts/spray-paint/automotive/rust-oleum-truck-bed-coating/p-1963108-c-8043.htm
MH Ready Patch
http://www.menards.com/main/building-materials/drywall/patching-repair/lightweight-spackling/ready-patch/p-1956277-c-8201.htm
1/4"-20 Press in Wood Inserts x 8
http://www.menards.com/main/tools-hardware/fasteners/nuts/miscellaneous/1-4-20-press-in-wood-insert-1-pcs/p-1445518-c-8921.htm
1/4"-20 x 1-1/2" Socket Cap Screws x 8
http://www.menards.com/main/building-materials/drywall/screws/socket-cap/1-4-20-x-1-1-2-socket-cap-screws-1-pcs/p-1445723-c-8937.htm
1/4" Flat Washer - 18 PC
http://www.menards.com/main/tools-hardware/fasteners/washers/flat/1-4-flat-washer-18pc/p-1827816-c-8945.htm
Puddy Knife
http://www.menards.com/main/paint/painting-tools/paint-knives/purdy-premium-flex-putty-knife-with-hammer-head/p-1496322-c-8082.htm
3M Super 77 Spray Adhesive
http://www.menards.com/main/paint/adhesives-tape/spray-adhesives/3m-trade-super-77-spray-adhesive/p-1420001-c-7923.htm
Acousta-Stuf Polyfill Speaker Cabinet Damping Material 5 lb
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-330
Gold 12 AWG 1/4" Female Disconnect 5 Pair
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=095-810
Square Speaker Terminal Cup 4" Gold Banana Binding Post
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-284
3" Hole Saw
http://www.menards.com/main/tools-hardware/power-tool-accessories/hole-saws/3-advanced-edge-hole-saw/p-1735683-c-10085.htm
DIYSoundGroup Flat Packs all boxed up. TIP: Save the boxes. They will come in handy during spray painting:
Really packaged well...no damage to any of the parts
I started by laying out all the pieces onto a table
I did a dry fit test to see how things came together.
Then I brushed off all the edges and tops/bottoms of the pieces to get all the dust off of them
Here's the process of gluing (Titebond II) and assembling the flat packs.
I used this rafter angle square to help make sure everything was perpendicular.
I sanded the edges say they were completely flush:
I sanded smooth the inner edge where the driver sits:
Next, I dry fit the very top piece and clamped it down tight:
I marked the center so I could get the driver screws to be aligned with the center as well.
And also drew a straight edge to make sure when I reassemble that the two top pieces line up:
Insert the driver:
Predrill the holes for the driver through both top pieces. I used this rafter angle square to help make sure my holes were perpendicular to the top. A variable speed drill at a slow speed is all you need:
I used these two 1/4" bits. The one on the right allow me to find a perfect center to start with. So I just started with that bit, then switched to the other since it worked much better on the MDF:
Then I threaded the socket head cap screws just to ensure I had it right:
I made sure to mark the TOP since you could possibly rotate the piece and not get perfect alignment. I'd recommend marking South, East, West and North as well:
Here's a good way to remove the driver by sliding the top boards:
Here's my make shift stop for my 3/8" drill bit:
I drilled on the under side of square edged top piece again using the rafter angle square to make sure I was drilling straight and then only went in about a 1/2":
See - straight!
I then threaded some of the socket head cap screws to lock the two top pieces in place:
I the put on a little Titebond II wood glue on the Press In Wood Insert:
I cleaned out the bottom of the 3/8" holes:
Make sure the Press in Wood Insert is pointed in the right direction and put a 1/4" washer between the socket head cap screw and the mdf. Then slowly start turning. Try to keep the sharp edges of the insert away from the edge. I did notice the mdf pushing out a tiny bit.
When this did happen, I put some extra glue around where it pushed out:
Here's what it looks like when the inserts are completely done:
I caulked the inside corners:
Finish gluing the top square edged piece:
Glue the top and just watch out for the screw insert areas:
Start tightening all the socket head cap screws:
After drying, I marked the center area of the 3" hole for the speaker terminals. I debated going with the SpeakOns, but I really liked that I could get these tighter to the wall if I needed to:
Great way to get the terminal square with the edge of the speaker when the cabinet is actually finished:
Here are the inside terminal connections that I crimped on:
Next it was time to install the PolyFill using 3M Super 77 spray. I used about .75 lb per cu foot.
I rounded all the edges to 1/2" and sanded smooth down to 220 using an orbital sander. I used a 320 grit sanding sponge pad for the rounded edges.
Primed using BIN Zinnser:
I wasn't happy with the edges so I used some wood glue. I needed a new batch of MH Ready Patch otherwise I would have used that instead:
Sanded smooth in between 2-3 coats of primer:
Ready for spray paint:
Sprayed two coats of Rustoleum Flat Black all at once. It took 1 full can:
Then waited 30 minutes and inserted 1/4" dowels to plug the speaker screw holes from being filled in with the Bed Liner spray:
Then sprayed the 2 coats of Rustoleum bed liner spray - I put some foam on a 5 gallon bucket and set the cabinet on top of it. It took 1 full can:
I waited several hours and then flipped the cabinet to finish the bottom. I set it over the top of the 5 gallon bucket and grabbing the framing inside the cabinet and the 3" center hole:
The installed the speaker terminals with screws:
Filled .75 lbs of Polyfill per cubic foot so 3 lbs for this 4 cubic foot cabinet:
Placing the heavy driver onto the cabinet and lining up the holes was not difficult at all when I used one 1/4" dowel as my guide to set the driver over:
The finished product:
I'm really satisfied with the Rustoleum Spray Bed Liner product combined with the first two coats of Flat Black. It looks very similar to an older Sony subwoofer I have...although rougher. I called up Linex and they could have sprayed each one for $60 each. Unfortunately, I had already primed the cabinet, and they said I would have to wait 30 days for the primer to cure. I think I might have preferred to go the Linex route for simplicity and no mess. The spray mist got everywhere in the garage. The Linex spray would be tougher but probably not quite as attractive as the Rustoleum bed liner.
I'll be trying out the Behringer EP4000 to power both subs:
LTD02 and shadyJ like this.
mcascio is offline
post #3 of 33 Old 11-05-2013, 03:13 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4169
Excellent work, Mario! Great job, especially for your first DIY.
Fire em up!
Scott Simonian is offline
post #4 of 33 Old 11-05-2013, 03:18 PM
kjlewie's Avatar
Quoted: 69 Post(s)
Liked: 88
Yep. Very nice. Good detail with the pictures as well. What will you power them with?
Audio: Marantz AV7702mkII / Marantz MM8077 / Emotiva UPA-7 for 7.2.4 Atmos/DTS:X - Video: Sony VPL-VW600ES & SI Black Diamond 133" 2.35:1 CIH for 4K UHD - Sources: Oppo BDP-103D, Mede8er 600d with Synology ds716 NAS (28tb), PS4, DirecTV - 7. Paradigm Studio 20 v5 (L, R, FW), Studio CC-590 v5 (C), Sonance VP63 (SS); 2. DIYSG Dayton HO 18" (4); PSA S3000i (3); 4! Infinity Entra One (FH), Sonance VP65R (TR)
kjlewie is offline
post #5 of 33 Old 11-05-2013, 05:13 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
They look really good. There is a slightly easier way to assemble those, but in the end your enclosures look great, so no problem. I made up a diagram that can be downloaded on the PE page where you order the box by itself. I've never checked to see if they have a link on the product page for the 'combo' package.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #6 of 33 Old 11-05-2013, 07:58 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Great job! Hoping to hear what you think and what you'll use to power!
doublewing11 is offline
post #7 of 33 Old 11-06-2013, 03:15 AM
Danielson99's Avatar
Quoted: 82 Post(s)
Liked: 63
The flat-pack looks like it was packaged well and I'm impressed with how easy it makes assembling an enclosure. You did a great job on the finish for the money you spent. Hopefully the speakon insert is air tight.
Danielson99 is offline
post #8 of 33 Old 11-06-2013, 05:28 AM
steve nn's Avatar
Liked: 433
Excellent job in presenting your project, putting it together, and finishing work.. very nice!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #9 of 33 Old 11-06-2013, 08:26 AM
Hoodcom's Avatar
Quoted: 111 Post(s)
Liked: 73
Very nice job, I'm quite impressed how well they turned out! A lot better than my own flat pack build. biggrin.gif
By the way, what type of bit is the one you used for the centering of the bolt holes? I'm interested in finding something like that to use on my next project. smile.gif
Hoodcom is offline
post #10 of 33 Old 11-06-2013, 08:46 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Fire em up!
Thanks Scott. Appreciate it.
mcascio is offline
post #11 of 33 Old 11-06-2013, 08:46 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks. I'm using the Behringer EP4000 to power them both.
mcascio is offline
post #12 of 33 Old 11-06-2013, 08:48 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks Erich. I'll have to check it out. Not sure how I could have done it any differently though.
BTW, did you get my email regarding the incorrect size of the sub on your website?
The flat packs were just what I needed to decide to push forward with this sub build finally. Major time saver!
mcascio is offline
post #13 of 33 Old 11-06-2013, 08:49 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
The second one definitely went together a little quicker since you gain a little knowledge along the way. smile.gif
I've seen them named dowel drill bits and brad drill bits:
http://www.menards.com/main/tools-hardware/power-tool-accessories/drill-bits/1-4-brad-point-bit/p-1461482-c-10079.htm
mcascio is offline
post #14 of 33 Old 11-06-2013, 09:50 AM
Hoodcom's Avatar
Quoted: 111 Post(s)
Liked: 73
I'd imagine so. smile.gif I used screws on mine when I glued and fastened it together. If I were to do it again, I would have been more patient and glued it all together like you did with yours. wink.gif
I just wanted to get to finally hear my Dayton, and I'm very pleased. I hope you'll be enjoying yours. smile.gif
Cool, Thank You very much for that information!
Hoodcom is offline
post #15 of 33 Old 11-06-2013, 07:51 PM
Erich H's Avatar
Liked: 1771
Which size is showing up wrong?
When you assemble the box, this is the easiest method:
Glue braces on the rear panel.
Glue top and bottom to the rear panel.
Glue on one side only.
Glue on the inner baffle.
Glue on the other side panel.
Then glue on the outer baffle.
If you glue on both sides before that inner baffle, it's a little harder getting that inner baffle in without a good deal of glue being squished out as it slides in.
But no big deal, you got it done and it looks great.
I'm glad to see the box made it to you okay because it looks like the shipping company dropped it a few times. Not good with a 67lbd package of wood. rolleyes.gif Those pallet corner protectors I use sure do save a lot of flat packs.
Erich H is offline
post #16 of 33 Old 11-07-2013, 02:01 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2577
bravo! and...FANTASTIC write up!
Listen. It's All Good.
LTD02 is online now
post #17 of 33 Old 11-07-2013, 03:50 AM
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
Very nice job.
I thought poly fill wasn't wanted for these flat packs?
Sent from my Nexus 7 using Tapatalk 4
sslv2pwned is offline
post #18 of 33 Old 11-07-2013, 04:50 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
So how does it sound? Are you going to get any EQ devise to boost the bottom end?
Martycool007 is offline
post #19 of 33 Old 11-07-2013, 06:54 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Hi Erich,
The 4.0 Cu Ft flat packs finished assembly are really 23.5" tall and not 23". I had planned for 23" plus a 1/2" for the rubber feet to fit inside the opening of my front cabinets. I have an opening of 23.75" which is how I discovered it being off. My plan now is to just slide the subwoofer in, then slide the rubber feet under the cabinet to prevent it from moving around inside there. Once I get past the opening I have a little more space vertically. WIth the feet on, it'll be physically impossible to squeeze it in unfortunately.
Thanks for the details on the assembly. There was a lot of glue being squished out. So the order change probably would have helped. Although, being that I used the Press In Wood Inserts, I needed to remove the inner baffle to drill the 3/8" hole. I guess I could have dry fitted and clamped though.
The boxes do look like the took some dings on the corners...but the content inside held up great.
mcascio is offline
post #20 of 33 Old 11-07-2013, 06:56 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Originally Posted by sslv2pwned View Post
Very nice job.
I wasn't aware of this...my first subwoofer build. But I thought that it was helpful to add it. Perhaps other experts can chime in. I'm using Acousta-Stuff from parts-express.
mcascio is offline
post #21 of 33 Old 11-07-2013, 07:00 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
They sound great. Upon initial testing, I don't think they are digging as low as my HSU VTF-15, but my goal was to fill in the nulls in the room with more subwoofers. The whole room shakes when my VTF-15 digs that low already, so I wasn't trying to add to that.
I've got a total of 4 subs now, the other one is an M&K MX-350. All the subs together sound great. I still need to set my levels on the EP4000 as well as re-run Audyssey. I'm waiting on a USB mic as well.
I've yet to research getting any EQ devices to boost the bottom end. Is that the only advantage of adding something like a miniDSP? I'm green in this area too!
mcascio is offline
post #22 of 33 Old 11-07-2013, 07:00 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks LTD02!
mcascio is offline
post #23 of 33 Old 11-07-2013, 11:24 AM
LTD02's Avatar
Liked: 2577
"I wasn't aware of this...my first subwoofer build. But I thought that it was helpful to add it. Perhaps other experts can chime in. I'm using Acousta-Stuff from parts-express."
ricci did a good test and writeup on the topic here: http://www.data-bass.com/data?page=content&id=79
LTD02 is online now
post #24 of 33 Old 11-07-2013, 11:51 AM
nfraso's Avatar
Liked: 172
And the TL:DR (though everyone should read!):
Overall, stuffing or damping the inside of a subwoofer’s enclosure is generally a good idea to prevent the internal reflections inside of the enclosure from bouncing around and coloring the response and sound. If you are looking for the utmost in uncolored and well-damped sound or if you intend to use the system extra high in frequency up into the lower midrange, it is recommended. If you are trying to be as absolutely loud and efficient as possible, then leave it out.
In general, there is probably a sweet spot for most systems where the system's major response issues are cleaned up and damped, but further addition of material will only serve to further decrease efficiency. Unfortunately, finding this sweet spot probably involves trial and error or other testing.
nfraso is offline
post #25 of 33 Old 01-04-2014, 10:47 PM
LTD02's Avatar
Liked: 2577
bump for best write up ever.
Mfusick likes this.
LTD02 is online now
post #26 of 33 Old 01-04-2014, 11:00 PM
Erich H's Avatar
Liked: 1771
Agreed! Lots of good information.
I'm curious if an EQ was ever added to bring up the low end to really make them shine.
Erich H is offline
post #27 of 33 Old 01-05-2014, 10:08 AM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks guys.
Erich,
I haven't done anything with EQ. I'm new to that whole arena as well. Any good references you could point me to for just getting started?
Hopefully someone with a similar setup has already documented the steps.
I have a total of four subs now. The two I just built and the HSU-VTF15h and an M&K 350. I believe I'll just be eqing the Dayton's right?
mcascio is offline
post #28 of 33 Old 04-30-2014, 01:37 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Thanks guys.
Erich,
Did you ever go down this road ? If so, I'd be curious as to what you did.
Mfusick is offline
post #29 of 33 Old 04-30-2014, 01:58 PM - Thread Starter
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
No. I never looked into next steps. Let me know if you decide to tackle it so I can learn as you go. smile.gif
mcascio is offline
post #30 of 33 Old 04-30-2014, 07:52 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
TBH easiest way to EQ is to get something like the miniDSP if you don't already have a DSP built into the amp
then you need a measurement mic and some EQ software
i did my 2 sealed 18s with a MiniDSP and an Omnimic
Sibuna is offline
Dayton Audio Rss460ho 4 18 Reference Ho Subwoofer 4 Ohm
