Birch, oak, MDF, plywood????? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 11-10-2013, 07:15 PM - Thread Starter
417 Motorsports's Avatar
Ok I see alot of you are using plywood to build these custom boxes and horns from. Others I see preach birch birch birch, and yet some just use a nice laminet plywood. However I haven't seen anyone using MDF! What's the reason? Coming from car audio where that's all that is used to seeing it never used in home, I'm a little curious as to why?
Any insight?
Blake
417 Motorsports is offline
post #2 of 23 Old 11-10-2013, 07:21 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
It has a different resonant frequency then ply. That's at least pertaining to horns.
stormwind13 is offline
post #3 of 23 Old 11-10-2013, 07:35 PM
BadmanSound's Avatar
because mdf.... sucks.
its heavy
It doesnt take screws
Water destroys it
amongst other reasons. Its only positive trait is its low cost and smoothness.
BadmanSound is offline
post #4 of 23 Old 11-10-2013, 07:37 PM - Thread Starter
^^^^ lol how do you really feel lol
post #5 of 23 Old 11-10-2013, 07:42 PM
Bill Fitzmaurice's Avatar
Liked: 4699
The question to ask is why do manufacturers use MDF? The answer is that it's cheap, it takes veneer well, and it's so dense that you can get away with minimal bracing, which reduces labor costs. For the DIYer it's a PITA to work with, and a well braced plywood cab can come in at half the weight of an unbraced MDF cab of equal vibration resistance.
417 Motorsports likes this.
Bill Fitzmaurice is offline
post #6 of 23 Old 11-10-2013, 07:55 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
I have been grappling with this for a while now. A few points from the information I have been able to gather together (this just applies to timber sheet and ignores polymers etc):
1. Ply is stiffest = good and takes bracing well
2. MDF is heaviest but not stiff
3. Chipboard provides good damping
4. Multiple layers of different material provides damping
My plan was as follows for the LCR’s:
19mm birch ply outer shell (stiff), then
19mm mdf (weight)
green glue (damping)
19mm chipboard (more damping)
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #7 of 23 Old 11-10-2013, 08:05 PM
d_c
d_c's Avatar
Quoted: 836 Post(s)
Liked: 910
I very much like building with mdf. It's cheap, easy to shape, glues strong, doesn't warp if braced well. Is great for indoor speakers that don't need to be packed around. But it's heavy, cancerous, and melts in water.
d_c is offline
post #8 of 23 Old 11-10-2013, 08:09 PM
did I really just hear the words "very much like building with mdf"? does your body run on cancer dust?
sorry, just joking.
I really dislike it because after one build (even with a face mask), I felt like my lungs had been severely violated.
also:
elill, you really intend to make LCR's with 57mm thick walls? wat?
post #9 of 23 Old 11-10-2013, 08:21 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
chalugadp is offline
post #10 of 23 Old 11-10-2013, 08:32 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Originally Posted by BadmanSound View Post
also:
Unless its a bad idea?
.....I'm not planning on ever replacing what I have planned, so if a little extra work at the start is no big deal
Peter the Greek
Elill is offline
post #11 of 23 Old 11-10-2013, 08:34 PM
it just seems... excessive? my arms are quite thin though. The perceived benefits in my mind do not outweigh the tripling in mas, and increase in overall volume. I could easily be wrong though. smile.gif
I complain when lifting an average sized speaker built out of 19mm thick material.
post #12 of 23 Old 11-10-2013, 08:42 PM
Liked: 4699
19mm mdf (weight)
Are you building a speaker or an M1 tank? I don't use more than one layer of 1/2" plywood, ever. And my cabs don't vibrate.
BadmanSound likes this.
post #13 of 23 Old 11-10-2013, 08:50 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
The rationale was more for damping then anything else.....
Speaking of which, I have read all sorts of guff about internal linings (fibre glass etc). I had planned on just 2 layers of 1" with some plastic in between (same way I build "absorber" panels). Anyone have a definative guide to this? noting its for mains so 60hz-20k+ not subs which will just be an empty box
Peter the Greek
Elill is offline
post #14 of 23 Old 11-10-2013, 09:00 PM
steve nn's Avatar
Liked: 433
+1 MDF related complaints! MDF dust.. that's some bad shxt! tongue.gif from a former MDF addict..
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #15 of 23 Old 11-11-2013, 06:27 AM
Liked: 4699
That's one way to do it, but IMO not the best way.
Damping is almost always required to reduce internal reflections. That includes subs, as the motion of the cone creates harmonics that must be damped. The exception is a folded horn sub, as the bends of the horn filter harmonics.
post #16 of 23 Old 11-11-2013, 06:57 AM
Erich H's Avatar
Quoted: 1410 Post(s)
Liked: 1779
MDF dust from years ago was not the best thing to breathe in. But the newer stuff is no where near as bad.
Inhaling dust from any wood product is not great on your lungs. Then again, either is walking downtown during rush hour and inhaling exhaust fumes.
chilort likes this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #17 of 23 Old 11-11-2013, 07:39 AM
Quoted: 60 Post(s)
Liked: 96
mmmmmmmmmmmmmmmmmmmmmmmmmm fumes!
post #18 of 23 Old 11-11-2013, 11:40 AM
JohnDean's Avatar
Quoted: 433 Post(s)
Liked: 183
MDF only for me. I don't like the exposed end grain you get from any of the ply options. Sure I could miter all the ends but I'd rather not.
It's purely an asthetic choice.
JohnDean is offline
post #19 of 23 Old 11-11-2013, 12:24 PM
thucker's Avatar
Quoted: 65 Post(s)
Liked: 24
I rather have to deal with extra bracing of plywood over MDF any day.
I will never build with MDF ever again. I don't care how much cheaper it is than plywood. The dust is a pain in the rear to clean.
thucker is online now
post #20 of 23 Old 11-11-2013, 06:30 PM
Face2's Avatar
Quoted: 335 Post(s)
Liked: 202
19mm baltic birch with bracing every 6" works very well.
Too bad Mahogany is so expensive. I ran some through my router last week and it actually smelled really nice when cut!
Face2 is offline
post #21 of 23 Old 11-11-2013, 07:51 PM
chilort's Avatar
Quoted: 16 Post(s)
Liked: 74
Arauco, if you can find it, is pretty inexpensive. Most particulate is bad for you in some form or another, which is why we should all just smoke and get it over with.
chilort is offline
post #22 of 23 Old 11-11-2013, 08:00 PM
steve nn's Avatar
Liked: 433
Could you send a sample my way? smile.gif There are a few things I like better about MDF though, it's been mentioned except for not chipping possibly..
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #23 of 23 Old 11-12-2013, 12:49 PM
Face2's Avatar
Quoted: 335 Post(s)
Liked: 202
I was restoring a desk organizer from 1810 for a friend. I wish I had enough to use for a speaker project.
pokeme likes this.
Face2 is offline
