AE TD12X vs AE TD12M - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 11-22-2013, 09:33 PM - Thread Starter
SASSAFRAS KING's Avatar
Originally Posted by Face2 View Post
Using it under a SEOS 24.
im wanting to build a tower. seos15 and td15. i only have experience building sub enclosures. this will be my first hifi build. am i on the right track?
SASSAFRAS KING is offline
post #32 of 44 Old 11-23-2013, 04:44 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
The easy part is the actual build itself, whereas the hard part is designing the crossover. You would be best served by trying to find an existing design using the Seos-15 & TD15. I believe there is one and it should show up in a google search.
Martycool007 is offline
post #33 of 44 Old 11-23-2013, 06:43 AM - Thread Starter
there is for the TD15M only. i more than likely will go active
post #34 of 44 Old 11-23-2013, 08:12 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Since you're going active, you'll be more than ok. I would contact John at AE, he's working on active AE/SEOS kits with enclosures.
Face2 is offline
post #35 of 44 Old 11-23-2013, 09:38 AM
John_E_Janowitz's Avatar
Quoted: 26 Post(s)
Liked: 81
Mark Seaton is sending up the fiberglass SEOS15 he has so I can develop a couple kits around it. I'll be doing the tower with the TD15H and bookshelf/stand mount with the TD15M using the SEOS15. I put the 12" kits as priority with the plastic SEOS15 not yet available. I expect all 4 kits within the next month though.
John E. Janowitz
Acoustic Elegance, LLC
"Learn from the mistakes of others... you can't possibly live long enough to make them all yourself"
John_E_Janowitz is offline
post #36 of 44 Old 11-23-2013, 10:46 AM - Thread Starter
you will get my business when those kits become available. are you going to do a slot port or 3 round ports for the front baffle? im digging the round ports. makes them look mean as hell! also... mdf or birch? im going with piano white!
post #37 of 44 Old 11-23-2013, 10:47 AM
donivan's Avatar
Quoted: 14 Post(s)
Which compression driver(s) will the kits be using? I might be interested in the TD15M since I have some of those just sitting in a closet.
donivan is online now
post #38 of 44 Old 11-23-2013, 11:25 AM
d_c
d_c's Avatar
Quoted: 820 Post(s)
Liked: 870
d_c is online now
post #39 of 44 Old 11-23-2013, 06:21 PM
Jon_B's Avatar
Quoted: 25 Post(s)
I am looking forward to the kits. I would love to try a active design. I already have the td12m and DNA 360, but I see you will be using the radian 475pb. If that's what you think will work better, I'm willing to give it a try.
Jon_B is offline
post #40 of 44 Old 11-24-2013, 06:32 AM
Quoted: 280 Post(s)
Liked: 176
Originally Posted by d_c View Post
The 12" mtm Kit uses the Radian 475 and MiniDSP plate amps.
12" MTM kits?? I would love to see a TD12/Seos-15/Radian-475/TD12 kit as that would be a really nice and high performance speaker! Please tell me that is a possibility??
post #41 of 44 Old 11-24-2013, 07:27 AM
d_c
d_c's Avatar
Quoted: 820 Post(s)
Liked: 870
He has some photos of a 2-way kit in the works on the ae Facebook page using the seos12 with the td12m configuration and Radian 475. I have been in contact with him about the mtm xo design using the 12m and he plans to get a kit out with this and the x series, both with the option to upgrade with the Apollo on the Lambadas and BE for the cd. I want an mtm with the 12m and seos12 and Radian over a 12x with the 12x tuned lower for a full range main for 2.1 channel listening for music. I'd cross it higher for movies. He has xo settings for MiniDSp amps, but I'd rather have a passive xo. I want everything out of Bwalso's design with another driver to help it dig deeper. How awesome would that be? Who wants to design the passive xo for us?! wink.gif
d_c is online now
post #42 of 44 Old 11-26-2013, 04:41 AM
Quoted: 280 Post(s)
Liked: 176
Are you sure that having a Be diaphragm on the Radian 475 is a possibility? I thought that the Be diaphragms were only available on the 2" compression drivers such as the Radian 950PB or the JBL-2446? Where would these Be diaphragms come from? Truxtnt?
post #43 of 44 Old 11-26-2013, 08:17 AM
d_c
d_c's Avatar
Quoted: 820 Post(s)
Liked: 870
d_c is online now
post #44 of 44 Old 11-26-2013, 10:17 AM
Quoted: 26 Post(s)
Liked: 81
The radian 475BePB is available. US speaker stocks them in small quantity and can drop ship others. If there is more demand we will be able to negotiate for better pricing. Obviously the cost is much higher with the Beryllium. This combination with the Apollo upgrade on the woofers and the Beryllium diaphragm on the compression driver really puts this system in an elite class though.
http://www.usspeaker.com/radian%20475bEpb-1.htm
John E. Janowitz
