Two bass towers with three LMS 15 "in each - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #151 of 163 Old 05-02-2015, 10:10 PM
kiwijunglist's Avatar
Quoted: 71 Post(s)
looks very nice. I'm building bass towers too, but yours will be way nicer. I'm doing 2x 15" in each tower, but the towers can stack on top of each other so I can have 4x 15" drivers in a single location, but I can split them if wanted.
HTPC (MediaPortal) / Pioneer SC LX87 / Wharfedale Jade 7 Fronts, 5 Rears, 2c Center / DIY Sub
kiwijunglist is offline
post #152 of 163 Old 05-03-2015, 12:59 AM - Thread Starter
Cobra-427's Avatar
Liked: 26
I was on your side and watch.
My first thoughts were to build 2x15 "but I thought I build upwards takes
not more floor space.
Then with six 15 "woofers in the room, I do not consider more
woofers.
It is sufficient, and becomes in the living room
Then it is better if one can place six separate in the room but in a living room does not work there because of all openings furniture, etc.
Sincerely, Roger
Cobra-427 is offline
post #153 of 163 Old 05-03-2015, 02:00 AM
Quoted: 71 Post(s)
Like this.
Like this. 2x subs on top of each other.
post #154 of 163 Old 05-07-2015, 04:28 AM - Thread Starter
Cobra-427's Avatar
Liked: 26
Like this.
A tough solution to have four pieces at altitude
post #155 of 163 Old 05-07-2015, 11:59 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
@kiwijunglist
the concern is the motion of the drivers creating a rocking motion.
if the drivers are heavy and the cabs are light, it could be a problem.
depends on the driver employed. lots of subwoofer towers like that in general though. infinity irs system went six high. ;-)
Listen. It's All Good.
LTD02 is offline
post #156 of 163 Old 05-07-2015, 12:13 PM
STL D's Avatar
Quoted: 264 Post(s)
Liked: 254
That is easily one of the finest DIY jobs I have ever seen. I'd never guess they weren't done professionally.
STL D is offline
post #157 of 163 Old 05-08-2015, 01:41 AM - Thread Starter
Cobra-427's Avatar
Liked: 26
@kiwijunglist
You are quite right that you write LTD02.
But the tower weighs about 462 lb of woofers mounted and I use the adjustable feet.
With full rash on the woofers is about 41 lb.-44 lb. moving but I have tried prints
hard high on the tower but it does not move.
So I think I'll be fine
LTD02 likes this.
post #158 of 163 Old 05-08-2015, 01:47 AM - Thread Starter
Cobra-427's Avatar
Liked: 26
thanks STL D
It was a good / nice comment such words they warm after all the of hours
been doing project
Sincerely, / Roger
post #159 of 163 Old 05-08-2015, 09:48 AM
LTD02's Avatar
Liked: 2576
was not referring to your towers, just the 4 unit drawing mentioned above. ;-)
LTD02 is offline
post #160 of 163 Old 05-13-2015, 02:11 PM - Thread Starter
Cobra-427's Avatar
Liked: 26
post #161 of 163 Old 05-13-2015, 02:25 PM - Thread Starter
Cobra-427's Avatar
Liked: 26
Updating how it will look to have the speaker cable with copper pipes
I was incredibly pleased with the outcome
post #162 of 163 Old 05-13-2015, 02:42 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
That is some damn fine copper work, every old fart at the hall would be proud if he could call you his apprentice
manuetdeo is offline
post #163 of 163 Old 05-15-2015, 08:12 AM - Thread Starter
Cobra-427's Avatar
Liked: 26
Glad you liked the solution manuetdeo to make installation
of the speaker cable through copper pipes.
