PEAVEY IPR2 5000 fan mod!!!!!! HELP!!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 144 Old 11-19-2013, 09:58 AM - Thread Starter
DIESEL758's Avatar
Hey just got the ipr2 5000 today and got it all hooked up, everything works great but crap this thing is loud!!!!! Does anybody have any fan mod suggestions for this amp??? I can't move it I don't have anywhere else to put it but under the screen with the rest of my equipment.
DIESEL758 is offline
post #2 of 144 Old 11-19-2013, 02:18 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Do a search, there's been several threads on fan mods.
Noah
noah katz is offline
post #3 of 144 Old 11-19-2013, 02:40 PM - Thread Starter
DIESEL758's Avatar
Did a search and can't find anything on the peavey IPR2 5000 amp
post #4 of 144 Old 11-19-2013, 06:19 PM - Thread Starter
DIESEL758's Avatar
Ok I have searched everywhere and can't find anybody that has done a fan mod on one of these. Any ideas ???
post #5 of 144 Old 11-19-2013, 06:57 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Maybe pull the fans to see the size and type. It might be close or the same as some other amps that have been modded. If not the same, people could better advise you on what would be a good substitute knowing what you're working with.
gpmbc is online now
post #6 of 144 Old 11-19-2013, 07:07 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
For the life of me.....................
Why can't pro audio amp manufacturers develop a front to back venting amp! And a quiet amp to boot!!!!!! biggrin.gif
doublewing11 is offline
post #7 of 144 Old 11-19-2013, 07:14 PM - Thread Starter
DIESEL758's Avatar
Ok I will pull the fans tomorrow. How do I know what size and type they are, will they have markings. Sorry for ignorant questions.
post #8 of 144 Old 11-19-2013, 07:21 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
The fan should have a model # on the round sticker so you can look up the specs. Voltage and amperage should also be listed.
Mrkazador is offline
post #9 of 144 Old 11-19-2013, 07:27 PM - Thread Starter
DIESEL758's Avatar
Ok thanks I will have a look tomorrow and post back my findings.
post #10 of 144 Old 11-20-2013, 06:38 AM
joel md's Avatar
Most 2U pro amps seem to use 80x80mm 24V cooling fans. On the Parts Express page for your amp it describes the cooling system as "three temperature dependent variable speed fans." I'm not familiar with the Peavey amps, but I recently changed out the fan in my QSC RMX 850 amp with a quiet NMB Technologies fan, Part # 110SB-05W-B20-E00. It's so quiet I can barely hear it from a foot away.
joel md is offline
post #11 of 144 Old 11-20-2013, 08:30 AM - Thread Starter
DIESEL758's Avatar
Here are the fans[IMG]
post #12 of 144 Old 11-20-2013, 08:31 AM - Thread Starter
DIESEL758's Avatar
post #13 of 144 Old 11-20-2013, 08:32 AM - Thread Starter
DIESEL758's Avatar
And what's under the hood of the 5000
post #14 of 144 Old 11-20-2013, 08:40 AM
joel md's Avatar
Those look like 80mm fans to me, so the NMB part number in my previous post should work.
joel md is offline
post #15 of 144 Old 11-20-2013, 09:29 AM - Thread Starter
DIESEL758's Avatar
Yep ordered two of them. Hope it works !!!
post #16 of 144 Old 11-20-2013, 10:03 AM
Point Source
beastaudio's Avatar
Quoted: 3487 Post(s)
Liked: 2821
Does the 7500 have the same I wonder? I would order two in a heartbeat if so and post the findings here. I will pull the amp tonight and look. nothing like a nice little 15 pound amp biggrin.gif haha! Too easy to move around!
beastaudio is offline
post #17 of 144 Old 11-20-2013, 10:36 AM - Thread Starter
DIESEL758's Avatar
I am hope they will be quite. The two fans that are in there sound like hair dryers. It also has a small little fan up towards the front but that one is not as loud as the other ones. Got to try it out for a little while last night watching IRON MAN 3, holy crap this thing defiantly has some power a lot more than the two crown XLS 1000's bridged and this thing can get pretty low.
post #18 of 144 Old 11-20-2013, 10:52 AM
Point Source
beastaudio's Avatar
Liked: 2821
Yep. but you obviously haven't heard an unmodded LG clone. That puts the peavey to shame. The little fan or inserting resistors might be a good option for cutting down the loudness as well.
post #19 of 144 Old 11-20-2013, 10:54 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5278 Post(s)
Liked: 4163
Word. After the CV5k and my gaggle of EP4k's, I think I'm gonna try these lightweight amps next. Probably the 7500.
Hope the fan mod works!
Scott Simonian is offline
post #20 of 144 Old 11-20-2013, 11:27 AM - Thread Starter
DIESEL758's Avatar
I won't be cutting up the wires on the fans as I have a 5 year warranty. I will pick up two ends from my local ALTEX computer supply store and install them on the new fans that way if I ever need to send the amp in for warranty work I can simply replace the fans.
post #21 of 144 Old 11-20-2013, 11:36 AM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Really? Could you elaborate?
Noah
post #22 of 144 Old 11-20-2013, 11:37 AM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
That would be great if the Peavey use a standard connector that you can mate to - does it?
Noah
post #23 of 144 Old 11-20-2013, 11:51 AM - Thread Starter
DIESEL758's Avatar
This is what it uses.
post #24 of 144 Old 11-20-2013, 11:54 AM
Point Source
beastaudio's Avatar
Liked: 2821
Sure! The Peavey has a more low-hum sounding fan setup where when I first cut it on, I almost felt like the the fan was loose inside the box. It wasn't, but that is what it sounded like. The Clones on the other hand had a more higher pitched fan sound more like that which you hear from a windows laptop. I can't really go much more into detail other than the peavey disappears a little easier under a decent level of content.
Looks to be the case here:
post #25 of 144 Old 11-20-2013, 12:46 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Ah, I thought you were talking about the SQ of the amps, not the fans
Noah
post #26 of 144 Old 11-20-2013, 12:49 PM
Point Source
beastaudio's Avatar
Liked: 2821
Diesel, know of a part # or name for that type of connection?
post #27 of 144 Old 11-20-2013, 01:47 PM - Thread Starter
DIESEL758's Avatar
Hey Beast I don't have the part number but it is a 2 pin 10mm connector. I am going to take the fans to ALTEX and radio shack to match exactly. As soon as I find out I will let you know.
post #28 of 144 Old 11-20-2013, 01:56 PM
Point Source
beastaudio's Avatar
Liked: 2821
sweet. Keep us posted!
post #29 of 144 Old 11-20-2013, 02:09 PM - Thread Starter
DIESEL758's Avatar
Yep not a prob. I will post part # and results of the mod as soon as the fans come in. Thanks for all the help guys.
post #30 of 144 Old 11-20-2013, 02:12 PM - Thread Starter
DIESEL758's Avatar
I also forgot to mention these fans are on all the time. They do get louder under heavier loads. NOT like the crown XLS 1000 where the fans kick on at a set temp.
