Very low frequencies (WinISD vs. laser measurement) - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 9 Post By FoLLgoTT
  • 6 Post By nfraso
  • 2 Post By FoLLgoTT
  • 1 Post By FoLLgoTT
post #1 of 17 Old 11-19-2013, 10:47 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
I stumbled on an increase of cone excursion in the very low frequencies of WinISD. It strongly depends on the parameter Ql which describes the box' leakage. The lower Ql the higher the increase.
I wanted to know if this is correct and took a measurement with my laser (Baumer OADM 20l6441/S14F) directly from the moving cone using REW. The subwoofer was a Peerless XXLS12 in closed box of 150 l. Soundcard and power amplifier were calibrated.
The measurement clearly doesn't show this increase. Simulation is only always as acourate as its parameter settings. smile.gif
LTD02, popalock, Nuno C and 6 others like this.
FoLLgoTT is offline
post #2 of 17 Old 11-19-2013, 11:05 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
UNIBOX does the same thing. The lower you set Ql the more excursion in the very low bass.
How do you know which Ql to input in the simulator?
splotten is offline
post #3 of 17 Old 11-19-2013, 11:21 AM
nfraso's Avatar
Liked: 172
Pretty nifty measurement/tool there.
Unibox uses three presets: Minor Leaks, Minimal Leaks, No Leaks. These correspond to a Ql of 20, 30, and 50 respectively.
WinISD defaulted to a Ql of 10 for me- that's seems like a pretty leaky assumption!
Sounds like if you know your box will/has no leaks, go with a Ql of 50 for better simulation.
Also, right next to Ql is Qa, or the Absorption factor. Give this article a run over for comparisons: http://www.data-bass.com/data?page=content&id=79
WinISD defaults to 100 for me. Unibox has four presets: Heavy Fill, Walls Covered, Minimal Fill, No Fill. These correspond to a Qa of 5, 20, 80, 120.
So WinISD's default assumption is a pretty leaky box with minimal to little fill. tongue.gif
Here's the difference between default WinISD parameters, and Heavy Fill (Qa of 5) with No Leaks (Ql of 50) for a SI-18 in 4cf with 1000w:
LTD02, dgage, notnyt and 3 others like this.
nfraso is offline
post #4 of 17 Old 11-19-2013, 02:53 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
That's odd.
I guess if it's leaky enough it's essentially unbaffled and should approach the excursion with a very large Vb
Noah
noah katz is offline
post #5 of 17 Old 11-19-2013, 11:07 PM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
Yes, I used the setting as described in ARTA application Note 7. ARTA has the ability to measure THD over excursion ("Klippel light"). I bought the laser and a low THD microphone (Audix TM-1) to do this.
I think so. I only use a high Ql now like Unibox is suggesting it. It seems to be more real.
LTD02 and popalock like this.
FoLLgoTT is offline
post #6 of 17 Old 11-19-2013, 11:20 PM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
So if you intentionally make the box leaky, do you see the predicted behavior?
Where did you purchase the laser? That's a real neat test setup.
-Mike Bentz
~It's all about compromise~
MBentz is offline
post #7 of 17 Old 11-20-2013, 12:56 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
No, but I can do it when I have time. Since the box was bassreflex originally I just have to remove the cover of the hole and measure again.
I had luck and found a used exemplar on ebay for 150 €. A new one costs about 900 €. I don't know if there are other cheaper distance sensors that work for this case. The Baumer can measure +/- 20 mm and its response time allows an upper frequency of 550 Hz. For many subwoofer this is enough (but not for the very high excursion ones, of course).
FoLLgoTT is offline
post #8 of 17 Old 11-20-2013, 09:09 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 471
Nice setup FoLLgoTT...You got a great deal on the laser. (Poor mans Klippel is still expensive. )
Ricci is offline
post #9 of 17 Old 11-20-2013, 10:42 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Now that is cool. I had no idea that ARTA could do this.
Time to learn what I can do with the things I have...
lilmike is offline
post #10 of 17 Old 11-21-2013, 12:58 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
ARTA is still one of the best measurement tools if you want to develop a loudspeaker. REW's focus is much more on room acoustics. Both tools have its strength.
@all
So here comes the laser measurement with a small leakage. I loose three of the screws that hold the plank covering the bassreflex hole I used originally. So it was not a big leakage. The driver's cone still came out slowly when I pushed it in. This usually is a sign for a small leakage.
As you can see the simulation with WinISD was correct! Only the default value for Ql is completely useless for closed boxes. smile.gif
LTD02 and notnyt like this.
FoLLgoTT is offline
post #11 of 17 Old 11-21-2013, 04:43 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2571
nice work.
2db increase of spl is something on the order of magnitude of 30% increase in cone motion, no?
Listen. It's All Good.
LTD02 is online now
post #12 of 17 Old 11-21-2013, 05:27 PM
nfraso's Avatar
Liked: 172
I believe that's a direct graph from the laser in REW, so the curves represent excursion. I'm not sure how you'd use the Y-axis though other than for comparison.
nfraso is offline
post #13 of 17 Old 11-21-2013, 06:16 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
I'd be a little leery of using the port, as the Helmholz resonator behavior could confuse leakage effects
Noah
post #14 of 17 Old 11-21-2013, 11:56 PM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
There was just the hole left. I removed the tube long time ago. No reason to be leery. smile.gif
Yes we just can compare the shapes of the curves. And we have to consider that REW shows voltage in dB. WinISD shows excursion lineary. The laser's output voltage is linear, too. So if the whole chain is calibrated we could calculate the absolute excursion from REW's SPL. But I would rather buy an oscilloscope and connect the laser to it, because it can display DC displacement. A soundcard with its high pass can't do this.
popalock likes this.
FoLLgoTT is offline
post #15 of 17 Old 11-23-2013, 05:33 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I would love to see some discussion on how to properly calibrate the down-stream components. I am just getting my feet wet with regards to measurements, but I would love to have the knowledge & ability to calibrate all of the components in my audio system.
Martycool007 is offline
post #16 of 17 Old 11-29-2013, 12:51 AM
Nuno C's Avatar
Quoted: 29 Post(s)
Great post. Thumbs Up for sure.
Nuno C is offline
post #17 of 17 Old 11-29-2013, 01:16 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
I converted the measurement data to a linear representation. So it can be directly compared to WinISD or Unibox.
Now in lnear representation I can see a slight raise of excursion in the lowest frequency. Apparently the test subwoofer was not as airtight as I thought first.
FoLLgoTT is offline
