Need help with ported design for Dayton Ultimax 15'' - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 79 Old 06-30-2014, 12:15 PM
djhamp's Avatar
Quoted: 24 Post(s)
Liked: 27
Do you have this running now, are you happy with the diffrence? I am thinking of doing the same thing so please describe how it turned out!
djhamp is offline
post #62 of 79 Old 06-30-2014, 01:02 PM
swc11's Avatar
[QUOTE=djhamp;253do you have this running now, are you happy with the diffrence? I am thinking of doing the same thing so please describe how it turned out![/QUOTE]
I have no way of measuring it but to me it sounds better and goes lower. Really shakes the house. My wife tells me more often than before to turn it down. So that tells me its working.
swc11 is offline
post #63 of 79 Old 06-30-2014, 04:40 PM
schmidtwi's Avatar
Quoted: 167 Post(s)
Liked: 121
Nice job. That is a good sign...
Can you post your box & port measurements? And why did you decide on a 10 cu/ft box?
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
post #64 of 79 Old 06-30-2014, 06:11 PM
swc11's Avatar
24" length 24" width 40" tall box.
32" length 21" width 2" tall port
swc11 is offline
post #65 of 79 Old 07-06-2014, 08:42 PM
swc11's Avatar
swc11 is offline
post #66 of 79 Old 07-06-2014, 09:11 PM
swc11's Avatar
http://www.avsforum.com/forum/attach...1&d=1404702557
this was done with roll on bed liner. looked terrible
ID:	150778   Click image for larger version
ID:	150786   Click image for larger version
ID:	150794   Click image for larger version
swc11 is offline
post #67 of 79 Old 07-06-2014, 09:14 PM
swc11's Avatar
painted over with black paint and added trim. still not happy
swc11 is offline
post #68 of 79 Old 07-06-2014, 09:18 PM
swc11's Avatar
http://www.avsforum.com/forum/attach...1&d=1404703039
got some quarter inch oak panels and cut to fit top, front and sides
ID:	150810   Click image for larger version
ID:	150818   Click image for larger version
ID:	150826   Click image for larger version
swc11 is offline
post #69 of 79 Old 07-06-2014, 09:19 PM
swc11's Avatar
swc11 is offline
post #70 of 79 Old 07-06-2014, 09:20 PM
swc11's Avatar
swc11 is offline
post #71 of 79 Old 07-06-2014, 09:20 PM
swc11's Avatar
swc11 is offline
post #72 of 79 Old 07-07-2014, 06:22 PM
swc11's Avatar
Just curious if somebody good at winisd could model this for me and let me know if it's a good setup? Seems to be working great but would like to see the numbers. Thanks
swc11 is offline
post #73 of 79 Old 07-07-2014, 06:54 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
The top is the size of the minimarty with 17 hz tuning.
chalugadp is offline
post #74 of 79 Old 07-07-2014, 07:16 PM
swc11's Avatar
So is 17 hz what I should see from mine? Spl?
swc11 is offline
post #75 of 79 Old 07-07-2014, 07:18 PM
chalugadp's Avatar
Liked: 1505
Yes , green line
post #76 of 79 Old 07-07-2014, 07:20 PM
swc11's Avatar
Yes , green line
swc11 is offline
post #77 of 79 Old 07-08-2014, 08:07 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
How did you add the 1/4" oak panels with out the edges showing on the corners and edges of each side? It looks to me like you attached the 1/4" oak panels and used some type of trim to go around the perimeter. Is that correct?
Martycool007 is offline
post #78 of 79 Old 07-08-2014, 08:15 AM
swc11's Avatar
I put the angled trim on first then cut the quarter inch thick oak panels to fit. The trim was also quarter inch thick so its flush. It looks better in person. The pictures make it look like the trim is lighter than it really is. I used liquid nails to attach it all and it feels solid. Ive moved it around several times and nothing has come loose.
swc11 is offline
post #79 of 79 Old 07-08-2014, 08:18 AM
swc11's Avatar
I still need to finish the front panel and attach it.
swc11 is offline
