sealed box too big ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-01-2013, 07:14 AM - Thread Starter
Fabricator's Avatar
what would most likely be the result of putting a driver in a sealed box that is about 25% to big ?
i have 2 6cf'ish boxs that now hold a 12" each. i want an upgrade, and, i have no experience with sealed subs. i would build proper vented boxs soon, but in the mean time, i am wondering what to expect if i put larger drivers in this box. i am wanting 18's.
thanx
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is offline
post #2 of 4 Old 12-01-2013, 07:27 AM
Bill Fitzmaurice's Avatar
Liked: 4630
In general, not that much. Sealed designs are pretty forgiving of too much volume. But to be sure just software model the driver/box combination and you'll know.
Bill Fitzmaurice is online now
post #3 of 4 Old 12-01-2013, 08:53 AM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
You could easily decrease the volume by putting bricks, bags of sand or whatever inside the box.
rajacat is offline
post #4 of 4 Old 12-01-2013, 09:33 AM - Thread Starter
Fabricator's Avatar
i am looking at either the Stereo Integrity HT 18. or the new Dayton Audio UM18-22 18" Ultimax DVC Subwoofer
i just looked at the SI info. it says = Ported = 5-6 ft^3 tuned to 20 Hz. that is the size of my box's ! but idk what size/shape the port should be.
that would be GREAT if i could reuse my cabinets.
here are my current 12" subs, at my last home. the baffle is right at 18". but perhaps i could put them in the sides.
Dayton Audio Um18 22 18 Ultimax Dvc Subwoofer 2 Ohms Per Coil
