Joe's LOWARHORN build - Page 10 - AVS | Home Theater Discussions And Reviews
 8Likes
post #271 of 294 Old 02-22-2015, 12:35 PM
asarose247's Avatar
Quoted: 129 Post(s)
Liked: 67
here you go . . .
http://s1083.photobucket.com/user/as...?sort=3&page=1
does this link work?
if not, as a first time user, I can use all the help I can get
I'd love to post at AVS but too much like work . ..
LTD02 likes this.
Denon X5200 , Emotiva UPA7, for 7.3.4 ATMOS/DSU
Klipsch FL/FR: F3 , Center: Icon 25 , SL/SR: RC3II , SRL/SRR :Icon 36 Towers, TF & TR: SLX
FH :RB51's
2 30" BF THTLP'S and SUBMAXIMUS and Inuke6000DSP
SHARP 80" LED/LCD, Xbox1 PS4 Panny BD 220
asarose247 is offline
post #272 of 294 Old 02-22-2015, 12:52 PM
wormraper's Avatar
Quoted: 181 Post(s)
Liked: 80
Originally Posted by jpmst3 View Post
It is! I wish I could see the next person's face that fires one of these babies up!
With the UXL group buy price and some wood, this has to be one of the best time/money bangs for the buck ever!
The GHorn is awesome, but the LHorn is so much easier to build with same or slightly better FR curve!
I am surprised there are not dozens of LHorns built already, especially when they make great couch tables or TV stands or ???
honestly, probably because there aren't a lot of Ghorns around either. it's a BIIIIIIIIIIIIIIIIIIIIIIIIG build that requires an expensive driver... that and the fact that you're the only one who built one and people tend to go with the ones that get a lot of traffic. that's my suspicion at least
wormraper is online now
post #273 of 294 Old 02-22-2015, 12:57 PM
LTD02's Avatar
Quoted: 817 Post(s)
Liked: 1335
Originally Posted by asarose247 View Post
here you go . . .
link works!
Are you going LOWAR?
Listen. It's All Good.
LTD02 is offline
post #274 of 294 Old 02-22-2015, 01:00 PM
asarose247's Avatar
Quoted: 129 Post(s)
Liked: 67
It's exactly the fact there are NOT too many . . .
I'm always looking for the next SUBMAXIMUS builder myself . . . cough, cough
FH :RB51's
post #275 of 294 Old 02-22-2015, 01:01 PM
asarose247's Avatar
Quoted: 129 Post(s)
Liked: 67
to LTD02
that would be
Oh H3ll YES!
FH :RB51's
post #276 of 294 Old 02-22-2015, 02:02 PM
mfagains's Avatar
It seems as though my quest for more BASS has come full circle...... Plan "A" was 2 Full Martys with the UM-18....... then I found the Liiwrecker........ then I found the LOWARHORN..... same size, more output... sweet!
I thought that my quest was over UNTIL....... I found the beast called SUBMAXIMUS. Funny enough, SUBMAXIMUS is just a hair larger than 2 Full Martys.
Please correct me if I'm wrong..... SUBMAXIMUS has MORE BASS OUTPUT from 1 less expensive driver (SI HT18) than 2 Full Martys with UM-18's.
How did I get the wife to agree to the SUBMAXIMUS you say....... I have to build her this FIRST! http://www.tantrachair.com/wp-conten...88978879821252
Plus it's also a side benefit for me ......
So fear not my friends......there WILL be another SUBMAXIMUS before the end of summer!
mfagains is offline
post #277 of 294 Old 02-22-2015, 02:20 PM
asarose247's Avatar
Quoted: 129 Post(s)
Liked: 67
check the dawnings of the MAX evolution to see what the designer decided upon, iirc not too enthusiastic about the SI 18 but not undoable
tantra chair "looks" simple but isn't this one of "write the check and get down to business things"? anticipation is one thing but . . .
MAX comes to about 38 ft3^ mol
you have my attention
FH :RB51's
post #278 of 294 Old 02-22-2015, 02:42 PM
mfagains's Avatar
@asarose247:
I have read through the thread several times, the consensus was that the SI 18 was just ok...... I'm looking to run a sim of the FAITAL PRO 18HW1070 to see how it fairs in this box. I have used it in PA rigs 25Hz+ tune in the past with great results.
After my reverse engineering was done..... the frame is a WAY easier build than any folded horn...... the PITA will be getting the stitching correct for the seams of the cushion on top. Once the cushion is taken care of, I could be finished in a weekend.
mfagains is offline
post #279 of 294 Old 02-22-2015, 02:51 PM
chalugadp's Avatar
Quoted: 1540 Post(s)
Liked: 1315
Worm,
Go for the lowerhorn !!!!!
chalugadp is offline
post #280 of 294 Old 02-22-2015, 05:23 PM - Thread Starter
jpmst3's Avatar
Quoted: 93 Post(s)
Liked: 229
Ya, definitely on the large side.
I would say the driver is cheap, but it is all relative...I am used to $900 LMSs. With the group buy and under $400 that is ton of driver for the money, especially since in the LOWARHORN it would best multiples of cheaper drivers in other enclosures, it really is more economical...IF you have the space.
I agree on the traffic. Once another gets built I am guessing the interest will pick up dramatically.
Joe = LFE Addict
jpmst3 is online now
post #281 of 294 Old 02-22-2015, 06:15 PM
asarose247's Avatar
Quoted: 129 Post(s)
Liked: 67
tantra form easy to make, accommodating padding , trickier
what about lots of multi layered foam/denser foam/bed topper foam
and then instead of a form fitted cover, a real accomplishment in itself . . .
a removable cover, just needs to be "close', not so "exact"
you can use/attach adjustable straps, attached away from the action, for tautness, keeping it mol in place, have them pass underneath, or thru some holes cut near the bottom , pull straps thru and take up the slack, not necessarily from Harbor Freight, but you get my drift . . .
a new product line for HF?
Eureka! By George, I think he's got it!
a cover made of something smart, like they use in the liberator pillow . . ., removable. washable , wipes down well . . . ripstop nylon comes to mind
TMI?
and maybe/sometimes an extra coverlet or a nice fuzzy/snuggly towel . . . just to top things off
YMMV
LOL
pictures or it didn't happen
I'm just sayin' . . .
FH :RB51's
post #282 of 294 Old 02-22-2015, 06:21 PM
wormraper's Avatar
Quoted: 181 Post(s)
Liked: 80
yeah, once theres like half a dozen builds it'll start taking off, especially with the rash of UXL 18s coming from the group buys
post #283 of 294 Old 02-22-2015, 07:46 PM
mfagains's Avatar
@ asarose247:
Your description is not too far off from what I came up with........ Great minds........ you know the rest......
mfagains is offline
post #284 of 294 Old 02-23-2015, 09:58 AM
Michael Mitten's Avatar
Quoted: 57 Post(s)
Liked: 46
Is the HPF based on pushing the driver with 1200w? What if it were only 600w? 300w?
WARNING: A high pass at 13-15 Hz is REQUIRED to protect the driver.
Here is the excursion with only 1200w:
As shown, the driver unloads quickly below ~15Hz.
Michael Mitten is online now
post #285 of 294 Old 02-23-2015, 03:24 PM - Thread Starter
jpmst3's Avatar
Quoted: 93 Post(s)
Liked: 229
The graph was based on 1200w.
The lower the power the lower the excursion, but a high pass filter is recommended on most designs.
Yes, if you have a very capable driver and only feed it 500w you could probably get away without out, but why live dangerously?
You will need some form of EQ regardless...just apply the HPF and mitigate the possibility of damage.
Joe = LFE Addict
post #286 of 294 Old 02-23-2015, 04:41 PM
Quoted: 57 Post(s)
Liked: 46
Just curious that's all.
post #287 of 294 Old 02-23-2015, 05:06 PM - Thread Starter
jpmst3's Avatar
Quoted: 93 Post(s)
Liked: 229
Understood, and your assumption is correct. Just clarifying so we are all on the same page.
Michael Mitten likes this.
Joe = LFE Addict
post #288 of 294 Old Yesterday, 03:12 PM
bryan.lynch's Avatar
Subscribed
bryan.lynch is offline
post #289 of 294 Old Yesterday, 03:15 PM - Thread Starter
jpmst3's Avatar
Quoted: 93 Post(s)
Liked: 229
Originally Posted by bryan.lynch View Post
Subscribed
Hey Brian! Welcome to AVS!
You might want to subscribe to the Dueling Lowarhorn build as well. It is more active as the build is currently in progress.
Joe = LFE Addict
post #290 of 294 Old Yesterday, 05:30 PM
Will do. Thanks!
post #291 of 294 Old Yesterday, 07:43 PM
Quoted: 39 Post(s)
Liked: 6
You don't realize how big these things are until you start pulling out the measuring tape in the seating room. I thought it would be cute to put one in my front room as a couch table but 24" is a bit big. The wife just looked at me funny. Honey I can cover it in shag and see if it puts you in a better mood.
Doradoguy is online now
post #292 of 294 Old Yesterday, 08:12 PM - Thread Starter
jpmst3's Avatar
Quoted: 93 Post(s)
Liked: 229
Ha! Yes, they can be a bit large, especially when you are not used to larger enclosures. It's like most things though, after you get used to it you forget about it. I put a table cloth over mine and it works well.
Joe = LFE Addict
post #293 of 294 Old Yesterday, 09:24 PM
Quoted: 39 Post(s)
Liked: 6
Perfect. I can put chairs around it.
post #294 of 294 Old Today, 09:14 AM - Thread Starter
jpmst3's Avatar
Quoted: 93 Post(s)
Liked: 229
Sure, why not add a lazy susan to the top and you are good to go!
Joe = LFE Addict
