Screws or no screws - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 12-02-2013, 02:55 PM - Thread Starter
mike47's Avatar
Im getting ready to build my floorstanding speaker cabinets. I was wondering if I should use woodscrews and glue to assemble, or just glue.
mike47 is offline
post #2 of 26 Old 12-02-2013, 03:52 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
If you have enough clamps then glue only. Glue and screws are nice if you want to put it all together in one go but then you have to fill the holes before painting.
Mrkazador is offline
post #3 of 26 Old 12-03-2013, 09:33 AM
kgveteran's Avatar
Quoted: 446 Post(s)
Liked: 171
I always use screws and hate myself when its filling time.......
kgveteran is offline
post #4 of 26 Old 12-03-2013, 11:23 AM
Adam-DiVine's Avatar
you could use a brad nailer which would make for easy filling. Or you could use a kreg jig on everything except for the baffle. Then just glue and weigh down the baffle.
Adam-DiVine is offline
post #5 of 26 Old 12-03-2013, 12:29 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
+1
I strongly recommend using the Kreg jig. They are affordable and cut assembly time in half.
Brads can work well, but can be a mixed bag when working with plywood as the layers guide the nails and can make them shoot out the sides of the panels.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #6 of 26 Old 12-03-2013, 02:14 PM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
The glue is ONLY as good as the surface or layer it is glued to. It does not "penetrate" very far.
By using fasteners-you have a much more secure bond deeper into the wood.
I HIGHLY suggest both.
Think of it this way-you can use the best glue into world to hold an object to a painted wall. But when the paint falls off-the object falls.
If you have screws going through the wall-it will hold much better.
HOWEVER you need the glue to hold the pieces of wood together so they don't buzz.
Screws are better than nails-since the pull the pull the wood together.
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #7 of 26 Old 12-03-2013, 02:21 PM - Thread Starter
mike47's Avatar
Thank yall for the replys. I plan on painting the speakers gloss white and I really need them to be smooth. Maybe just a few screws in stratigic locations. Im using 3/4 MDF and if you prep the screw holes correctly with a drill/countersink bit, then its pretty clean. I have been told not to use screws is the reason I brought it up. I guess its a matter of debate (like every other part of building speakers).
mike47 is offline
post #8 of 26 Old 12-03-2013, 04:34 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 962
I concur..............................screws are the only way to go. Even when building my home, I told the contractor no nails!! The guy almost flipped out! Cost me more.................but who cares, (Mike) Holmes on Homes would be proud of me! biggrin.gif
doublewing11 is offline
post #9 of 26 Old 12-03-2013, 05:10 PM
steve nn's Avatar
Liked: 433
I always tell myself no screws this time around and within 5 minutes I’m doing the screw, (maybe clamps) and glue. With veneer it’s no biggie, but when you’re painting, getting things right can be a bear. I’m sure I need to learn more regarding the prep process in painting or material to top the screws when countersunk since I opt for veneer so much though. Spackle dosen't seem to cut it no matter how much I sand with what grit.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #10 of 26 Old 12-03-2013, 05:25 PM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
I use a biscuit joiner.
FMW is offline
post #11 of 26 Old 12-03-2013, 05:58 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
That works well too and have gone that route as well. A little more work and more expensive tools that then the Kreg Jig, but very good.
Joe = LFE Addict
jpmst3 is offline
post #12 of 26 Old 12-03-2013, 07:53 PM
Face2's Avatar
Quoted: 343 Post(s)
Liked: 207
+1 and glue, no screws ever in speaker cabinets.
Face2 is offline
post #13 of 26 Old 12-03-2013, 08:25 PM
djarchow's Avatar
Quoted: 25 Post(s)
Liked: 40
I like using pocket screws where it is difficult to get good clamp pressure, The center braces in sub cabinets are a good example. Without using a slightly curved caul it is tough to get good clamp pressure in the center of a 24" wide panel. Using pocket screws in that center brace helps insure that there will be a good glue joint in the center. I have a biscuit jointer and that gives some additional strength to the joint but doesn't help pull panels and braces together.
djarchow is offline
post #14 of 26 Old 12-04-2013, 05:38 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Which Kreg Jig are you guys referring to?
Martycool007 is offline
post #15 of 26 Old 12-04-2013, 05:42 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I am only aware of one. They are typically around $100 but can run more if they include things like clamps, extra screws, plugs, etc.
http://www.kregtool.com/Pocket-Hole-Jigs-Prodlist.html
Joe = LFE Addict
jpmst3 is offline
post #16 of 26 Old 12-04-2013, 07:16 AM
djarchow's Avatar
Quoted: 25 Post(s)
Liked: 40
I have one of the more expensive ones, but the Kreg Mini jig is under $20.
djarchow is offline
post #17 of 26 Old 12-04-2013, 07:48 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I never even considered the pocket version. It seemed like more of a pain for saving the few dollars.
Joe = LFE Addict
jpmst3 is offline
post #18 of 26 Old 12-04-2013, 08:05 AM
djarchow's Avatar
Quoted: 25 Post(s)
Liked: 40
The nice thing about the mini is that you have more flexability with the location and angle for the pocket screw hole compared to the larger ones. If all you are doing is standard rail and stile pocket holes, then the larger ones are great. The smaller ones are nice, for example, to add a pocket screw to the inside of an already glued up cabinet. I have never had to do that though as all my joints are perfect:)
djarchow is offline
post #19 of 26 Old 12-04-2013, 08:15 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Ahh, that makes sense. Thanks for the info.
Joe = LFE Addict
jpmst3 is offline
post #20 of 26 Old 12-04-2013, 08:44 AM
notnyt's Avatar
Quoted: 2709 Post(s)
Liked: 2494
Brad nails and glue here. much quicker than alternatives. Long panels I'll use a biscuit joiner.
notnyt is offline
post #21 of 26 Old 12-04-2013, 09:17 AM
SeekingNirvana's Avatar
Quoted: 248 Post(s)
Liked: 164
Using this method do you...
Apply glue...
Clamp....
Shoot some brads...
Remove clamps....
Repeat?
That way you don't have to wait for the glue to set up?
SeekingNirvana is offline
post #22 of 26 Old 12-04-2013, 09:24 AM
notnyt's Avatar
Liked: 2494
notnyt is offline
post #23 of 26 Old 12-04-2013, 12:25 PM
Jstslamd's Avatar
You can also use trim head screws it's makes a nice small hole to have to fill. Not as small as brad nails but half of the size of a regular #8 screw.
steve nn likes this.
Jstslamd is offline
post #24 of 26 Old 12-04-2013, 12:33 PM
steve nn's Avatar
Liked: 433
Good idea!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #25 of 26 Old 12-04-2013, 01:07 PM
BeerParty's Avatar
The 'not use screws' may have been in reference to your material choice rather than speaker building. MDF is fine if you pre-drill and use the proper type of screw, but if you don't... mad.gif
Just a word of caution: If you plan to round over the corners of the cabinet, make sure the screw heads are deep enough to avoid hitting them. A screw head will do a fair amount of damage to a round-over bit.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #26 of 26 Old 12-04-2013, 01:10 PM
BeerParty's Avatar
I have been using a Kreg R3 for years, and love it.
Chris
