6th order band pass sub for 4 x RE XXX 18's IB sub tunned to 5hz or lower. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 12-04-2013, 01:17 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
OK, starting a new thread fueled from the discussion in Notnyt's thread. LTD02 kindly offered to take a stab at designing a 6th order band pass sub. I am looking for full output right down to at least 5hz or lower if I can.
So LTD02, what do you need to get this started? I have a storage area in the back of my theater which my second IB is installed, it is about 1,200 cubic feet.
This is a pic of the size of the opening.
So let the fun begin!
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #2 of 33 Old 12-04-2013, 09:21 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
iirc, there are a couple different versions of that driver with slightly different t/s specs? do you know the t/s for what you've got?
Listen. It's All Good.
LTD02 is offline
post #3 of 33 Old 12-04-2013, 10:07 PM
LTD02's Avatar
Liked: 2576
just looking at some initial models, i'm not sure a 6th order bandpass is going to make you very happy.
for the upper tuned port to contribute much, it has to be fairly close to the lower tune and then spl rolls off quickly above whatever point is chosen. doubling the frequency is still reasonably close and in beast's build that was about 12hz lower / 25hz upper. here it would be ~5hz lower and about 10hz upper, so rolloff would start there and go down. seems like too much wasted bass to me.
however, just a big ole standard ported will pick up about 12db or so around the tuning frequency and that is significant with no loss in spl above the tuning frequency. so maybe that is the best option...at least so far. 12db is more or less the same as four times the drivers and four times the power.
very rough draft, first pass look.
in order to keep port velocity down with 3 drivers, a rather large port may be required. this may be the first build that uses full size sonotube for the port. eek.gif
but at these frequencies, and at this scale, i'm also not sure which room is actually being ported. that is actually something that i never thought about...if the rear and the front room are both the same size, does the port somehow get another 6db or something from both rooms resonating at the same frequency?
in any case, here are some max spl plots for 3 xxx sealed, ported at couple different frequencies, and 6th order.
LTD02 is offline
post #4 of 33 Old 12-04-2013, 11:22 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
I have this one I believe.
http://reaudio.com/products/woofers_xxx.php
BTW, that pic is an old one, it best represents the opening I have. I actually have 4 of the drivers.
I agree. I am not really liking those numbers. How long would a port have to be to tune to 5hz? Could I make the whole space act like a box sub? I can effectively completely seal the space as good as a boxed sub due to it being soild concrete walls ,floor and ceiling. I also have a sealed sound proof door which is air tight as well.
Edit: I gave you the wrong link for the driver I have.
My build thread
post #5 of 33 Old 12-04-2013, 11:37 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Also I should mention, I have plenty of bass above 20hz to 70hz, it is below that that I want to see some more Db's, especially around the 5hz mark.
My build thread
post #6 of 33 Old 12-05-2013, 12:24 AM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
Fascinating question.
One thing which would seem to be the case is that equal volumes on both sides of the port means equal air springs on both sides, so the port will have to be longer.
Not sure what else is going on or what the net effect is.
Noah
noah katz is offline
post #7 of 33 Old 12-05-2013, 12:34 AM
SXRDork's Avatar
Quoted: 22 Post(s)
Liked: 42
Hey man, just was thinking about this in another thread. Hope I don't sound like a salesman by now but if you have the cash get a rotary woofer to fill in below 20Hz. You certainly have the volume in your storage area. Just sayin..
SXRDork: SXRD is a technology. My name is Vann. Usernames are for life...
SXRDork is offline
post #8 of 33 Old 12-05-2013, 12:41 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Actually, I have seriously thought about doing that, I am just not sure about having them come all the way to Japan to do the install.
My build thread
post #9 of 33 Old 12-05-2013, 12:47 AM
SXRDork's Avatar
Quoted: 22 Post(s)
Liked: 42
I was thinking about this when the first 6th order bandpass thread originated. Specifically, I was thinking about porting my IB subs to give me more 7 Hz where my electronics were rolling off big time (or so I think). My storage room is approximately 1200 cu. ft. but it is a little difficult to determine the exact volume. I noticed in the simulations that the difference in port length to get the tuning frequency I wanted changed significantly with enclosure volume. If I remember correctly, I'm talking about a 6-7 inch port at 1000 cu. ft. versus a 4-inch port with 1200 cu. ft.
I'm pretty sure I've decided not to do it due to the sensitivity of tuning frequency with IB volume. You may want to consider this.
SXRDork is offline
post #10 of 33 Old 12-05-2013, 01:31 AM
LTD02's Avatar
Liked: 2576
"I'm pretty sure I've decided not to do it due to the sensitivity of tuning frequency with IB volume."
that's not a show stopper by any means. just build and test a couple ports to dial in the length to hit your target tuning. around tuning the driver will move very little compared to frequencies on either side.
LTD02 is offline
post #11 of 33 Old 12-10-2013, 07:28 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Thanks for all the help LTD02, but I think I am going to go another route.
Does anyone have the email of EMINENT TECHNOLOGY? I could not find it on their web site? I am going to see if the rotary woofer will be viable in my room.
http://www.rotarywoofer.com/
My build thread
post #12 of 33 Old 12-10-2013, 11:17 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
| INFOATEMINENT-TECH.COM |
Hidden in plain sight, bottom of the page.
info@eminent-tech.com
Here is a better link to the TRW-17:
http://www.eminent-tech.com/main.html
lilmike is offline
post #13 of 33 Old 12-10-2013, 11:59 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Thanks, I am so stupid... most of the time.
My build thread
post #14 of 33 Old 12-11-2013, 11:08 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
In my memory kryptonitewhite built an IB sub, put a huge sonotube port in it, and shook his ceiling fan so much he had to put 2 x 4's in room so the ceiling would not fall down??
this thread?? or another?
http://www.avsforum.com/t/1337645/1003-cubic-feet-5hz-tuning-gotta-make-history-properly/60
mtbdudex is offline
post #15 of 33 Old 12-11-2013, 11:12 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4167
5hz huh? Hmmm. That's a tricky area. Signal chain roll off is CRITICAL at this point. You MUST get this in line before anything else. Otherwise you're just throwing away money.
After that maybe think about a true rotary sub system. Anything resonant is not going to give you more 5hz and down, imo. At least, not worth the trouble imo.
Scott Simonian is offline
post #16 of 33 Old 12-11-2013, 11:38 AM
LTD02's Avatar
Liked: 2576
have you guys looked at the specs on the rotary sub? spl is only 115db or so...
LTD02 is offline
post #17 of 33 Old 12-11-2013, 11:39 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Dave, I've planned on implementing some Crowson transducers under my seating riser(s) for the last couple years, ... maybe you could beat me to the punch, no? By many accounts, the properly time aligned tactile transducer system blended with a killer acoustic transducer system is perma-grin material.
Scott knows of what he speaks, besides 5hz audibility begins somewhere around 110dB, ... tough stuff. Granted, if any room is ripe for it it's your wonderful room.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #18 of 33 Old 12-11-2013, 11:49 AM
Bass Enabler
Liked: 4167
Heheh. Like I've been saying for the past couple years. When in doubt.... quadruple. biggrin.gif
This is the alternate choice and probably the better as it would save Dave a TON of money. A nice transducer system would be great to get that 10hz and down. Still, though, the signal chain roll off is very very critical here.
Living with an HT room that has a concrete floor, I'm thinking of doing just this. Most likely going to start with a bare riser and then add transducers all of which would be controlled by either a DCX or MiniDSP system.
post #19 of 33 Old 12-11-2013, 11:54 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
$1k for a shadow 8 dual? one for each couch? Meh, I'll just buy 8 more SI's and stick them nearfield. Fixed
beastaudio is offline
post #20 of 33 Old 12-11-2013, 12:40 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
In case you're not already aware, be sure to put isolators under the riser to allow it to move and not mechanically short it to the slab.
Noah
post #21 of 33 Old 12-11-2013, 12:58 PM
Bass Enabler
Liked: 4167
Hey thanks, Noah. Yeah, I have read a bit about it. Not a ton but it was recommended that I use some isolation feet of sorts. I have carpet that is medium to thick so I'll have to figure what's the best to get ....when I get around to it. tongue.gif
Right now my HT room is empty-ish as I transition. cool.gif I don't want to thread crap on Dave's thread about it though. wink.gif
A simple riser is definitely on the list.
post #22 of 33 Old 12-12-2013, 06:24 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
My signal chain is pretty good down to 3hz, that is where roll off begins. No clone Amps here, I own the real thing. wink.gif
I would need some quality transducers, as I already have 'buttKickers' and they make too much mechanical sound and distract me. So I turned them off. My other thought was to make a 1" riser and couple it too a couple of LMS 18" ultras????
Yes, I am very disapointed with the Rotary sub's output, so I won't be going that route.
My threads don't get derailed, they evolve. So anything goes!
My build thread
post #23 of 33 Old 12-12-2013, 06:33 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
JD,
I have the Crowson brand and they work really well. Sometimes I even use them for music. They send a vibration much like a nearfield 30-80 hz sub does.
http://crowsontech.com/go/crowsontech/3472/en-US/DesktopDefault.aspx
And the AVS thread is here.
http://www.avsforum.com/t/1450832/the-official-crowson-tactile-motion-actuators-thread/0_50
Hope this helps,
Moto
MX48 is offline
post #24 of 33 Old 12-12-2013, 06:34 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
The Crowson transducers are, by all accounts, quality ... and way beyond the typical shakers.
FOH is offline
post #25 of 33 Old 12-12-2013, 06:51 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
From what I understand they work differently than the other brands.
I have definitely never heard them make a sound that they weren't supposed to and have run the WOW pod scene numerous times.
I don't have much cred here but Craig John does so you should read his comments smile.gif.
MX48 is offline
post #26 of 33 Old 12-14-2013, 04:58 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Bought 4 of the Crowson actuators and 2 amps. So I will see how things go.
My build thread
post #27 of 33 Old 12-14-2013, 05:09 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
You don't waste any time do you Dave smile.gif?
I think you will be happy with them, if not should only cost you the shipping assuming Crowson doesn't cover return shipping from Japan. And if they do even better.
I ended up crossing mine at about 25hz, but of course you will need to experiment.
MX48 is offline
post #28 of 33 Old 12-14-2013, 04:15 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
LOL, Yeah, no point in beating around the bush.
You need to cross these things that low? I think I will have to read that thread you linked.
My build thread
post #29 of 33 Old 12-14-2013, 04:52 PM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
I'm not sure where everyone is crossing them but I go that low because I have a nearfield sub from 30-80 for those frequencies. I probably have them crossed at 30 or 35, I would have to check.
I really need to do some serious testing with mine and get it just right. Every time I think I am going to do that I change something In the theater. Building a new baffle wall right now, if I had known what a job it was going to be I might have rethought it.
MX48 is offline
post #30 of 33 Old 12-14-2013, 11:47 PM
SXRDork's Avatar
Quoted: 22 Post(s)
Liked: 42
I'll be interested to hear what you think. I'm contemplating going the same direction to get more tactile but have not jumped in to experiment yet.
SXRDork is offline
