HELP! Thinking of going down this road but I know nothing! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 12-04-2013, 09:55 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
I'm looking at buying a UXL18 and a 4 cu ft flat pack from DIY sound group but what amp will I need? I'll likely end up with two of those subs one to start then another one later. Also, what else is needed? Is that all there is to do? Put the box together slap the sub in and done? Is there no tuning or anything? Also, how do you finish the box? If I wanted a bamboo veneer do I just bring the box to a local veneer shop and get them to put it on? How do I power the sub and connect it all? Is there somewhere that explains all this? Yeah I'm this new hahah
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is offline
post #2 of 25 Old 12-04-2013, 10:10 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
I'am also thinking about buying the Rythmik DS1500 CI?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #3 of 25 Old 12-04-2013, 10:13 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
You could power both sub's with a inuke 6000.
Mrkazador is offline
post #4 of 25 Old 12-04-2013, 10:15 PM
notnyt's Avatar
Quoted: 2790 Post(s)
Liked: 2569
notnyt is offline
post #5 of 25 Old 12-04-2013, 10:24 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
How much does an EQ cost?
So inuke is a good amp? I see its a class D? Is that going to be better than class ab?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #6 of 25 Old 12-04-2013, 10:31 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
The minidsp is real popular
http://www.minidsp.com/products/minidsp-in-a-box/minidsp-balanced-2x4
The inuke has a model with a DSP that can eq to 20hz. Lots of people use the inuke series for sub duty and I haven't seen a complaint about them other than fan noise. Most pro amps are noisy so home theater users will replace the internal fans with quieter ones.
post #7 of 25 Old 12-04-2013, 10:45 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Cost adding up..
$120 for box
$530 for sub
$500 for amp
$195 for EQ and mic
$1345
Ahh I guess that's not too bad, about the price of a Rythmik FV-15HP
Plus the price to get box finished in Bamboo... Is that hard to do?
I guess the big price saver will be when I add the 2nd one.
What about quiet amps? Is the fan pretty noticeable?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #8 of 25 Old 12-04-2013, 10:58 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
280 for inuke3000 amp with dsp. 100 bucks for umik mike. That's a little cheaper .
chalugadp is offline
post #9 of 25 Old 12-04-2013, 11:00 PM
chalugadp's Avatar
Liked: 1532
You will need fan mod and its 20 bucks and 10 mine.
post #10 of 25 Old 12-04-2013, 11:52 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Do I still need the EQ if I'm using an Anthem MRX with it ARC? Wouldn't that do the EQing ?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #11 of 25 Old 12-05-2013, 01:02 AM
chalugadp's Avatar
Liked: 1532
I'm not familiar with arc.
post #12 of 25 Old 12-05-2013, 01:07 AM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
It's like Audyssey XT32 that come built in avrs
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #13 of 25 Old 12-05-2013, 01:24 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
I'm not real familiar with how Audyssey or ARC works with low frequencies. I think it measures the F3 of the sub in room then Audyssey won't apply any EQ below that...Once the subs are in room, you might gain some spl down low because of room gain. I say you try without an EQ and if you feel like its lacking down low then go ahead and buy an EQ and microphone to measure.
post #14 of 25 Old 12-05-2013, 02:14 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Ok so is this how I'd build it...
Glue box together
Drill a hole for wire
Insert sub
Connect sub to amp
Run EQ
Done?
Is it that simple?
I guess I should add dampening too?
And since the amp is powering the sub the sub wouldn't need a power outlet?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #15 of 25 Old 12-05-2013, 02:22 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
A single UXL-18 in a 4cuft enclosure with an iNuke6000 and MiniDsp for the lows will likely outperform the Rythmik by a good bit, and when you add a second UXL-18, well then you will likely outperform the Rythmik by leaps and bounds!
Go with the iNuke3000 if you can't afford the iNuke6000. You can find the iNuke3000 for under $280 all day long!
Martycool007 is offline
post #16 of 25 Old 12-05-2013, 05:41 PM
BassThatHz's Avatar
Quoted: 2378 Post(s)
Liked: 2152
Originally Posted by JustABrah View Post
Cost adding up..
$120 for box
$530 for sub
$500 for amp
$195 for EQ and mic
$1345
Use speakon instead of just a hole (it's well worth the extra few bucks).
You will also need an RCA to 1/4 TRS wire/adapter; and a speakon cable.
The DSP amp has the EQ and XO built in, you don't need to have two EQ's. So that saves you some money.
What mic are you talking about? You will need both an SPL meter and a measurement mic kit. (You can d/l for free a basic SPL meter software for most smartphones these days, not ideal, but that would do in a pinch.)
Most silent amps that are also good, are also very expensive; or very cheap and crappy.
BassThatHz is offline
post #17 of 25 Old 12-05-2013, 07:49 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
The mini DSP had a add on called UMIK-1, I'm assuming that's a mic for measuring?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #18 of 25 Old 12-05-2013, 07:57 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
So when the boxs is done I just run a wire from the back of the sub to the amp? I use a speakon insert, is that to keep the box sealed from the hole for the wire?
Speakon insert looks like a good idea, so I hook the sub to that then I use the cable that runs from the back of the sub to the amp?.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #19 of 25 Old 12-05-2013, 08:53 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
The box needs to be sealed so you'll need to use binding posts or a speakon connector w/mount.
You can get a pair of binding posts from diysoundgroup.
post #20 of 25 Old 12-05-2013, 09:14 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
And Do I connect the sub from the inside with a Y? Then I connect wire from both red and black to the amp? Then I use the LFE on the amp to the avr? Is this correct?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #21 of 25 Old 12-05-2013, 09:16 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Thanks a lot everyone for the help, I've never done this before, so thanks for helping me with my dumb questions haha
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #22 of 25 Old 12-05-2013, 11:11 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
So is the benefit of a Rythmik kit be that I don't have to EQ it? I'm guess its more plug and play? Or do I still need to do that?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #23 of 25 Old 12-06-2013, 05:17 AM
Bill Fitzmaurice's Avatar
Liked: 5687
Every room has a different response curve, so every system needs EQ.
Bill Fitzmaurice is offline
post #24 of 25 Old 12-06-2013, 09:37 PM - Thread Starter
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
So what's the difference from a EQ like minidsp vs ARC in the Anthem MRX?
Is the mini dsp hard to understand and use?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #25 of 25 Old 12-07-2013, 06:41 AM
Quoted: 280 Post(s)
Liked: 181
The ARC in your Anthem is for people that want to basically plug and play. It probably works reasonably well at somewhat smoothing out the response, but the MiniDsp is a much more capable unit. The ARC is only going to do so much. I am sure that all receiver manufactures would love to have a more capable EQ in their receivers, but the reality is that it would be way to complicated for the average Joe, and likely hurt sales if people had to learn all of this stuff when they can just buy another receiver and have a plug n play room correction built in.
Think of DVD MiniDsp as a way to improve upon what the ARC will do in your Anthem. Keep in mind that most room correction in the receivers, such as ARC in your Anthem, only have very limited ability to EQ the subwoofers. So to get the best sound from your subs, you will need a MiniDsp to EQ them properly. Especially if your sub(s) are sealed. Hope this helps!
