ep2500 vs ep400 bridged mono switch settings - AVS Forum | Home Theater Discussions And Reviews
Old 12-10-2013, 09:51 AM - Thread Starter
goonstopher's Avatar
Quoted: 290 Post(s)
Liked: 55
I am confused by the switch settings to bridge my 2 behringer amps.
On the EP2500 I have 3, 6,7,8 to the right and it seems to be fine with so signal coming through the other channel since its in stereo with parallel off. If i turn parallel on it clips.
On the EP4000 the same settings give me signal to both channels.
How the heck do i bridge these things?!
goonstopher is offline
Old 12-10-2013, 01:49 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
4,5,6,7 to the right if you have only one input going into the amp. If you have stereo inputs then 4,5 to the left and 6,7 to the right.
Mrkazador is offline
Old 12-10-2013, 09:50 PM
Shan87's Avatar
Quoted: 16 Post(s)
Liked: 27
Well I didn't read the instructions when I did mine and just used the back panel and bridged it. What I failed to read in the manual was that you have to turn the second gain knob all the way to the left. If you don't do this it then it will create a nasty clip at any decent volume. This may not be your problem at all but something to be sure of I suppose...
Shan87 is offline
Old 12-11-2013, 06:26 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
So on an EP2500 how should all of the dip switches be set if you want to bridge the amp?
Is it the same for the EP4000? I am probably going to pick up another EP2500 or EP4000 sometime in Janruary as I already have one EP4000 that I have not hooked up yet due to my confusion on the correct dip switch settings.
Martycool007 is offline
Old 12-11-2013, 07:41 AM
steve nn's Avatar
Liked: 433
^^^Hey Marty..Yes the 25 and the 4 are the same including switch schematic.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 12-11-2013, 01:29 PM - Thread Starter
Quoted: 290 Post(s)
Liked: 55
I'm going off memory here but don't 3 and 8 to the right turn off the HPF and isn't that what we want?
Old 12-11-2013, 01:36 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Yeah.
Old 12-11-2013, 08:04 PM
steve nn's Avatar
Liked: 433
Yeah 2. Go by what it says on the right side of the back instead of what it says at the switches. This has caused confusion for years.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 12-11-2013, 10:53 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
Remember on a lots of ep2500's the dips are backwards vs the manual. That had a ton of guys thrown for a loop.
N8DOGG is offline
Behringer Europower Ep2500 Amplifier , Behringer Europower Ep4000 Professional Amplifier
