mic2200 clipping? - AVS Forum | Home Theater Discussions And Reviews
Old 12-10-2013, 09:54 AM - Thread Starter
goonstopher's Avatar
Quoted: 303 Post(s)
Liked: 60
My behringer mic2200 servers as a HPF and signal boost.
I have it set up
AVR-Antimode-Mic2200
With the mic line level on and turned down near the lowest setting (15 max) the mic2200 says its clipping nearly all the time.
To get sufficient bass levels I need to have it clip.
Is this clipping a problem if the amp isn't clipping?
goonstopher is offline
Old 12-10-2013, 06:31 PM
H8TWRK's Avatar
Does it look somewhat similar to this set-up? I got this from Neo Dan a few years ago and have never had a problem with the clip light. Do you think its clipping because of input signal or the boost?
H8TWRK is offline
