Just another dual sealed LMS 5400 build - Page 5 - AVS Forum
 10Likes
post #121 of 138 Old 09-10-2014, 02:28 PM - Thread Starter
SeekingNirvana's Avatar
Quoted: 55 Post(s)
Liked: 84
Did those one show?
This new format really sucks for posting pictures!! total pain in the a$$ to do, and looks like they don't even show?!
My dual sealed LMS 5400 Ultra build
http://www.avsforum.com/forum/155-di...0-build-4.html
SeekingNirvana is offline
post #122 of 138 Old 09-10-2014, 02:33 PM
Bunga99's Avatar
Liked: 32
Originally Posted by SeekingNirvana View Post
Did those one show?
I can see em, and they look SWEET!!
Bunga99 is offline
post #123 of 138 Old 09-10-2014, 02:49 PM
GizzeGutten's Avatar
Quoted: 58 Post(s)
Liked: 33
So far I am super stoked on them!! Way better then the Velodyne Digital Drive subs I had before. I have not put any eq to them an all. All I did was take a RCA to Balanced cord from my AVR to the QSC amps, and ran audyssey. Bumped the trim up 6 db and let er rip. Sounds really good!! Cant wait to get the Mini-Dsp into the chain. Even with the flat audyssey curve they still shake the house, and sitting in front of the near field one puts a huge smile on my face!
Im sure once I get the mini in, I will be even happier, but with just audyssey it makes me want 2 more! The wife would probably divorce me if I told her I was getting 2 more though! For now I will be fine with 2.....
measurements to come...
PROFIT! NirvanaFound?
You are in for a world of joy! They just keep getting better and better the more you tweak with them. Sometimes I just sit shake my head in disbelieve of what these babies can do – it should be impossible.
The joy of getting proper EQ was as big as if not greater than hearing them (w/o EQ) for the first time. They just give and give and give! The only problem is that you can't get enough, and soon there were quads!
Your boxes came out really nice! I'm not the one to criticize on looks but I'd get anodized black screws if I had those beautiful black monsters. That will make them even more glorious!
Also see you've got Emotiva XPA-1 gen 2. Do you hear any difference between class A and AB mode?
DAC/Preamp: miniDSP 4x10 HD and Mytek 192 Stereo DSD DAC
Speakers: JBL 4343B, JBL 4430 and JBL 120Ti
Amplifiers: Emotiva XPR-1, Denon POA 1500, QSC GX5 and Sanway's LabGruppen FP14000 clone
Sub: DIY LMS Ultra 5400
GizzeGutten is online now
post #124 of 138 Old 09-10-2014, 03:04 PM
filtor1's Avatar
Very nice! I sanded and sanded the seams and in between coats of duratex, I still have seams showing. The cabinets look great!
filtor1 is offline
post #125 of 138 Old 09-16-2014, 06:40 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 84
Did those one show?
post #126 of 138 Old 09-16-2014, 07:27 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 84
I'm for sure one big step closer to nirvana......I think adding some JTR noesis 212's will get me there. Will need to save for a while though.
I can't believe how good they sound, they go deeper, louder, hit harder then the velodyne's ever did! I too sit and shake my head at what they can do. I had a bunch of buddies over for a BBQ, and I put on "Art of flight" at +8.5........after the demo I was trembling! My knees were weak, my heart was pounding in my throat, and my hands were visibly shaking! And I wasn't even in the hot seat (where the near field sub is) the guy who was sitting there didn't stop smiling for 5 minuets. I am soooooo impressed with these subs, and like I said....this was just with a super quick, 1 point audyssey calibration. I can't wait until I can get into the mini.
I've played some songs that I know are demanding, and with it cranked to 11, the subs look like their barley breaking a sweat. I know they have a ton left in the tank, and if I'm floored now......(shaking head) I can't imagine how I'll feel when their dialed in.
With the mini I can have 4 different presets and this is how I think I'll set them up
1) Just a Full Audyssey XT32 calibration, no EQ on the mini, but a 10hz HPF.
2) Full XT32 calibration, then adding a low shelf of 4-6db on the mini, with a 10hz HPF.
3) Full XT32, the adding a LT, to the mini, still with a 10hz HPF.
4) Full XT32, with a LT, but change the HPF to 20-25hz and setting the amp gains just below clipping. By doing this I think I can get the most output from them, but with a high HPF I won't bottom the drivers. This will be my demo preset for music. Most music doesn't go this low so I should be safe. I could be wrong though.
I've spent the last week working on some other things in my system. I had a ground loop hum to fix, and now I'm working on a fan mod for my amps. They are too loud for my room. While music is playing it's not an issue, but when watching tv, or a movie, or at low volumes, they are really annoying. The fans will be in tomorrow, so one step closer to EQ.
With the emotiva amps......I can't really tell the difference between A and AB. Maybe my ears are not trained enough. What I can say though is that at low volumes it sounds just as detailed, (if not more) as it does at moderate volumes. Maybe that's what class A is about? Maybe I can tell a difference, and it is more detail at low volumes. I am very happy with the emotiva amps.
I'll try to get some measurements posted soon.
Oh yea and about the screws......I was so anxious to get them fired up, I just used the stock screws. I totally plan on getting black ones. It looks goofy with the silver ones.
GizzeGutten likes this.
post #127 of 138 Old 09-16-2014, 07:38 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 84
Did you route out a channel like I did? My seams were showing because the bondo was lower then the MDF surface, I sanded them to low.
Thanks for the compliment.
post #128 of 138 Old 09-17-2014, 04:56 PM
Quoted: 58 Post(s)
Liked: 33
Wow, those look sick! They probably pack a hefty punch!
Hahaha, I've read this quote three-four times already and I fully understand how you feel, sweaty hands are guaranteed with these!
When you start boosting the low end and play some bass heavy songs you'll get those cones moving. Try out Avaratz by Infected Mushroom, The Joy of Minimal by DubKing or Warm Swarm by Krumulur for instance. Some of them have very enjoyable bass.
Sounds like a solid plan. I use all four presets on the miniDSP 4x10 HD myself. I'm trying to optimize config 1, 2 and 3 and use 4 for experimentation. 1 should be linear with slight hotness in the lows, 2 is for very hot lows and 3 is going to be for movies. It's a work in progress not that I've built four midbass modules and are working on two new enclosures for a pair of extra ultras.
Yeah, had to move the FP14k out of the room until I've had it modded. With content that has wide dynamic range the fans are really annoying. The lower you get the noise floor in your room, the better dynamics you'll have at low volumes too. If your noise floor is 50dB at listening position everything below 50dB will be masked by the noise, so the more silent the better.
Yeah, I've got the XPR-1 monoblocks. Those are class AB & H, but they have fantastic SQ too. Was contemplating the XPA-1 vs the XPR's because of class A operation. I've heard class A should be very smooth sounding with no sibilance and good detail retreival. This has been my experience with class A too, but I find the same qualities in the XPR's so IDK.
Let me know if you find proper black screws, please. I had a really hard time finding anything suitable on ebay and it was downright impossible locally.
Glad but not surprised to hear you're having a blast with the Ultras.
post #129 of 138 Old 10-03-2014, 05:53 PM - Thread Starter
Quoted: 55 Post(s)
Liked: 84
I had a little time to mess around with REW. I wanted to see what you guys think, and if I did it right.
I started with some near field measurements. I couldn't do it outside so I put the sub towards the middle of the room with the mic on the ground. I first put the mic at 6" and moved it back 6" at a time until 24"
Here is the graph from the first sub.....
I am curious why each sweep has the same smooth hump from 5hz to about 12hz? The spl is the same on all the sweeps.....
Here is the sub 2
As you can see its almost identical to sub 1, even the smooth hump. Since both subs show the same response I thought that either one had no leaks, but while I was running some sweeps in increments I heard some air coming out from where I plug the speakon in. I will fix the leaks and see if it changes the response. Does this look normal for a sealed sub?? I think I did this right because I don't see any reflections, all the sweeps are the same and if there was any reflections it should show different responses right?
Here is a shot of both of my mains and both subs, with audyssey on and off.......
I have some work to do on the response, it look like a mountain range! But what do you think? I seem to be getting some room gain at about 10hz? Im not quite sure how to read these graphs yet .
And finally here is a shot of both subs in 5db increments starting with the MV at -25, and REW -20dbfs.....
I thought by doing this kind of measurement I would see where the room gain kicked in, but its the same with every sweep. If I am reading it right...im getting good gain from 10hz?
I thought I read that you can figure the Q of a box form some measurements. How would I figure the Q of the boxes? I would like to know if I put to much stuffing in them, or not enough.
It would be great if someone who is experienced in REW to give me some pointers, and explain what is going on with these graphs.
Ill try to get some responses here first, but if I don't get any ill start a thread for just the measurements.......maybe ill name it "Marty graphs" or something. That should get attention.
Name:	sub 1 near field.jpg
ID:	293698   Click image for larger version
ID:	293706   Click image for larger version
Name:	sub 2 near field.jpg
ID:	293714   Click image for larger version
Name:	mains + subs -20dbfs mv@ -10.jpg
ID:	293722   Click image for larger version
Name:	both subs in 5db increments.jpg
post #130 of 138 Old 10-03-2014, 06:17 PM
BassThatHz's Avatar
Quoted: 311 Post(s)
Liked: 404
Looks like your mains are interfering with your subs at 35hz something bad. Room null at 70hz.
I assume you haven't applied a 20hz shelf boost yet via a miniDSP or somesuch.
I would expect that 1 LMS wouldn't show any compression until at least 110db, and a pair 116db. So no need to measure beefy subs lower than 90db really.
I got 116db @ 16hz @ 6inches cone center on music-program before excursion got big.
BassThatHz is offline
post #131 of 138 Old 10-03-2014, 06:49 PM
BassThatHz's Avatar
Quoted: 311 Post(s)
Liked: 404
I get this from 1 LMS-18 and iTech 8000 (-3db@6.5hz) and DCX (-3db@8hz)
TermLab
CM-140 and UMC Mic-1
post #132 of 138 Old 10-03-2014, 06:53 PM
BassThatHz's Avatar
Quoted: 311 Post(s)
Liked: 404
near-field 0.5ft, near max excursion.
DCX 20hz shelf boost.
Name:	TL Chart3.png
ID:	293770   Click image for larger version
post #133 of 138 Old 10-03-2014, 06:59 PM
BassThatHz's Avatar
Quoted: 311 Post(s)
Liked: 404
This is 10 subs with my theater doors open.
Gives me 3hz deeper from some reason.
I don't have a calibrated umik (it's on my to-do-soon list though!), so keep that in mind.
post #134 of 138 Old 10-03-2014, 07:28 PM
BassThatHz's Avatar
Quoted: 311 Post(s)
Liked: 404
Here is Chal's ported HO-15's near-field 0.5ft, about 3-4db below it's max excursion.
This is what a: "mini-marty" they call it?
post #135 of 138 Old 10-03-2014, 07:47 PM
BassThatHz's Avatar
Quoted: 311 Post(s)
Liked: 404
single near-field vs quad non-co-located at LP.
post #136 of 138 Old 10-10-2014, 08:59 AM - Thread Starter
Quoted: 55 Post(s)
Liked: 84
I've had a handful of members ask me for the plans to my box. Here is a dropbox link that will give you the Sketchup file, and a scan of the cut list and a cutting diagram. The number on the cut list corresponds with the number on the cutting diagram. A little later I will update this post with the box calc's (Internal voulume, and Q) If anyone decides to use my design, and has any questions I will be glad to help!
https://www.dropbox.com/sh/ij8e5pfy8...FVLlyM1fa?dl=0
Its just a simple sealed enclosure, but I am happy to help anyone trying their first build.
post #137 of 138 Old 10-10-2014, 09:23 AM
berrmich's Avatar
Thanks! I really appreciate it.
-Mike
berrmich is offline
post #138 of 138 Old Yesterday, 05:18 PM - Thread Starter
Quoted: 55 Post(s)
Liked: 84
Its taken a while for me to get to post the calcs of my box......
It ended up being 3.5^3. thats with the bracing displacement, and driver displacement, from online box calculators that makes it a QTC of 0.6
User Tag List
