Just another dual sealed LMS 5400 build - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #151 of 158 Old 11-29-2014, 07:23 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Originally Posted by SeekingNirvana View Post
My amp has either speakon, or binding posts for the output, so I think I can disconnect the speakon on the back of the amp and just hook the multimeter to the binding posts. It should be the same thing right? That way I dont need to take apart my speakon. I just wast sure how to measure it, I read that you dont want to hook up the multimeter to + and - at the same time....it could blow the meter. Maybe that was just to measure current. I thought I needed to hook both probes in line on one side of the wire.
Measuring between + and - should not blow your meter. That is what they are for. I measure high current 480V all the time with my meter so you should be fine measuring your amp. You can measure from the back of the amp if you want to and as long as you can put your leads on the contacts. You might have to hold your leads doing it this way though unless you can stick them in there and they stay. If you take apart the connector, you can clip your leads to the wire.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #152 of 158 Old 12-21-2014, 02:40 AM
Hundhausen's Avatar
Liked: 5
They look fantastic! Would it be possible to get your scetches and measurements for the box and inner bracings? I'm planning on building a single box and your build looks just right.
Awesome job!
Hundhausen is offline
post #153 of 158 Old 12-21-2014, 03:11 AM
notnyt's Avatar
Quoted: 2151 Post(s)
Liked: 1980
As long as your meter is hooked up in Volts mode, and not amperage, you'll be fine. Amperage turns it into a short basically, and it will pop the fuse inside.
notnyt is offline
post #154 of 158 Old 12-21-2014, 09:47 AM - Thread Starter
SeekingNirvana's Avatar
Quoted: 233 Post(s)
Liked: 123
Awesome job!
Thanks for the compliments! I actually posted a link to my Sketchup file, and a cut list in post 136 of this thread.
One thing to note though, is that I designed it with a quad baffle, but ended up only using a triple. So you can save yourself a few cuts if you decide on a triple baffle instead of the quad.
SeekingNirvana is offline
post #155 of 158 Old 12-21-2014, 11:45 AM
Hundhausen's Avatar
Liked: 5
Thank you so much! I had somehow missed that post.
post #156 of 158 Old 12-21-2014, 11:57 AM - Thread Starter
Quoted: 233 Post(s)
Liked: 123
No prob bud! You gonna get a build thread goin?
post #157 of 158 Old 12-21-2014, 12:11 PM
Hundhausen's Avatar
Liked: 5
I can't promise anything. I'm just planning now and the actual build probably isn't going to happen any time soon. It's wintertime...
I still might place an order for the LMS Ultra quite shortly. I'm also considering Behringer iNuke NU6000DSP amp for this project.
post #158 of 158 Old 12-21-2014, 12:11 PM - Thread Starter
Quoted: 233 Post(s)
Liked: 123
Thanks for confirming.....I knew I read something about that.
