LTD-M18 Sub Build - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #361 of 640 Old 04-16-2014, 10:41 AM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
J Brown, the 3" brace you have running down the center of the port, does it attach to the opposite side of the cabinet wall? Also is there another brace that follows as the port turns up?
gpmbc is offline
post #362 of 640 Old 04-16-2014, 11:01 AM - Thread Starter
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
There's a center support brace running down the middle of the entire length of the port.
jbrown15 is offline
post #363 of 640 Old 04-16-2014, 11:13 AM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Thx, and can you give the two port dimensions that form the total 47"length?
gpmbc is offline
post #364 of 640 Old 04-16-2014, 11:36 AM
LTD02's Avatar
Quoted: 2526 Post(s)
Liked: 2869
"Does the response calculator allow you to change the dimensions of a room that isn't exactly rectangular? The would be pretty cool in the was the case, then I could give you all of the exact dimensions of my room and see what it comes up with."
nah. it is a relatively simply calculator. rectangular room. two sources. one listening location. still, quite powerful and instructive though.
Listen. It's All Good.
LTD02 is offline
post #365 of 640 Old 04-16-2014, 02:29 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Nevermind on the two dimensions I figured it out, 28.25" and 18". I decided on a built and tested design and yours just happens to fit so four it will be.
gpmbc is offline
post #366 of 640 Old 04-16-2014, 03:08 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
The total width of my port area is 19", its 47" long and 3" high.
jbrown15 is offline
post #367 of 640 Old 04-16-2014, 03:54 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
I'm getting 19.75 for the width of the port?
gpmbc is offline
post #368 of 640 Old 04-16-2014, 04:01 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
The total width of the cabinet is 22" wide, so subtract 1.5" for the double baffle, then .75" for the center support and another .75" for the back panel. That gives you 19".
jbrown15 is offline
post #369 of 640 Old 04-16-2014, 04:08 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
I see what you mean, it is 19.75 to attach from front to back but the center brace detracts from the total. Did you line the cabinets or add any fill/pillows? Also, did your hi pass stay at 16hz and what slope? Thx
gpmbc is offline
post #370 of 640 Old 04-16-2014, 04:10 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
No, I have a bunch of the egg crate foam but never put it in.
jbrown15 is offline
post #371 of 640 Old 04-18-2014, 06:43 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Just curious, how many sheets of ply did it take for the two enclosures?
gpmbc is offline
post #372 of 640 Old 04-18-2014, 06:59 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1531
Six
chalugadp is offline
post #373 of 640 Old 04-18-2014, 07:03 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Thx, I coming up with 9 for four enclosures. I'll have to triple check my math.
gpmbc is offline
post #374 of 640 Old 04-18-2014, 08:17 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
You'll need two sheets for the double baffles, one sheet to cut the two back pieces, you can get all the side pieces out of one sheet. And one sheet for the tops and bottoms and one for odds and ends like the port and bracing.
jbrown15 is offline
post #375 of 640 Old 04-18-2014, 08:28 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
For one enclosure I came up with one sheet to get the front and back, the two port pieces and 3" port brace. A second sheet to get the top, both sides and the second front for double baffle. 3rd sheet only uses 32" x 22" for the bottom so could be used for 3 more bottom pieces. 4.5 sheets total for two enclosures or 9 sheets for 4 boxes. Bracing will be dowels or 2 x 2s attaching panel to panel.
gpmbc is offline
post #376 of 640 Old 04-18-2014, 08:58 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
Are you taking into account that the front baffle is doubled up? So it's two 3/4" pieces for the front. I personally wouldn't use dowels it's easier to rip the extra would into 1" strips and just use that.
jbrown15 is offline
post #377 of 640 Old 04-18-2014, 09:50 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Yep, you get the second baffle off the second sheet. I used 2 x 2s in my previous build seemed to work fine I'll probably just use those again.
gpmbc is offline
post #378 of 640 Old 04-18-2014, 10:39 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
Actually now that I think about it you could get three front baffle pieces and three back pieces per sheet. So you could cut all eight front baffles and four back panels from only four sheets. Then two sheets for the side pieces and two sheets for the tops and bottoms, and then one sheet to cut up for the ports. Wouldn't hurt to spring for one extra sheet just in case.
jbrown15 is offline
post #379 of 640 Old 04-18-2014, 10:46 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
On the second cabinet I found it really easy to do the bracing the same way that forum member notnyt did. I used strips that were ripped down to 1.25" and then I also cut little blocks from some of those strips. After doing that I measured out where the bracing was going and then glued and nailed those little blocks in place and then nailed and glued my bracing strips to the blocks.
the blocks were nice to use because the strips didn't have to be perfectly snug in place. It allowed you to have about a 1/16th of an inch of play and I was using expanding glue, so when it dried there was no gap at all. It turned out great, very sturdy. smile.gif
jbrown15 is offline
post #380 of 640 Old 04-18-2014, 11:27 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Noted, thx JBrown!
gpmbc is offline
post #381 of 640 Old 04-19-2014, 02:58 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
Haha, so for fun I decided to play "Bass I Love You" today, I only had my master volume at -15 and I was hitting 118-119dB. eek.gif
Four of these things are going to be insane....lol
I was tickling the clipping light at that volume, I think I counted in coming on like four times during that song.
jbrown15 is offline
post #382 of 640 Old 04-21-2014, 04:47 PM
uopdrmark's Avatar
Quoted: 94 Post(s)
Did you end up using the minidsp for anything or just the inuke6000dsp? If the inuke6000dsp, how did you deal with the cutoff at 20hz? I'm going to be building a few of these once drivers are back in stock and I already ordered the inuke6000dsp so I'm hoping that works ok.
uopdrmark is offline
post #383 of 640 Old 04-21-2014, 05:46 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
Right now I'm just using the DSP from the inuke amp, and I've set up a 16hz high pass filter so that I don't bottom out the drivers under heavy bass. I do have a balanced miniDSP that I'm going to use, just waiting for the cables to come in that I ordered.
http://www.bhphotovideo.com/c/product/488060-REG/Hosa_Technology_PHX_106F_BULK_PNX_106FB_Phoenix_Connector.html
jbrown15 is offline
post #384 of 640 Old 04-21-2014, 06:05 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
JBrown, couldn't you set the hi pass at 14/15 hz since you're tuned close to there?
gpmbc is offline
post #385 of 640 Old 04-21-2014, 06:18 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
Yes, I could easily lower the HP filter. Honestly I just haven't gotten around to playing with a different HP, I wouldn't want it set any lower then 14hz though.
These first two subs can get just down right silly if I want too. My theater is on concrete slab which makes it harder to get a tactical feel from subs, and honestly that was the case with my dual XS30's. You could feel them playing really low but they wouldn't do something like shack the chair you were sitting in. Well definitely not the case with the first two subs that I built, while playing "Bass I Love You" my theater seats were shaking like never before. I can't wait to get the last two build and have all four going at once! smile.gif
LTD02 and gpmbc like this.
jbrown15 is offline
post #386 of 640 Old 04-22-2014, 02:25 AM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
You will be rocking! Very nice, sir!!!
blah450 is offline
post #387 of 640 Old 04-24-2014, 11:33 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
I fired one up tonight and I think I'll be happy. After a little eq I'm flat from 13hz to 36 then a drop off. Maybe that will improve once elevated 10"off the ground which was my intention so I'll be close to the 1/4 points from the walls, floor and ceiling. Anyhow, output won't be an issue at all with one already goin strong and three more coming.
LTD02 likes this.
gpmbc is offline
post #388 of 640 Old 04-24-2014, 11:39 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
Nice work! One is awesome, two will make you crap your pants, four will make you ____ yourself! eek.gif
jbrown15 is offline
post #389 of 640 Old 04-24-2014, 11:44 PM
LTD02's Avatar
Liked: 2869
i pop in for 2 minutes and find this. AWESOME!!! now you just need the one on the right to manifest as easily as i reversed the image. :-)
LTD02 is offline
post #390 of 640 Old 04-25-2014, 05:49 AM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
gpmbc is offline
