LTD-M18 Sub Build - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #481 of 640 Old 05-19-2014, 07:54 PM - Thread Starter
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
So I finished putting both of the Subs that I had cut on the CNC together.
I just need to wood fill everything then sand and router the edges and then a coat of paint and they're good too go smile.gif
jbrown15 is offline
post #482 of 640 Old 05-19-2014, 08:10 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Wow..........................sun in BC?
Better hurry and get those beasts into the garage before the next monsoon hits!
Looks good....................
Can't imagine the output you'll get......................................
doublewing11 is offline
post #483 of 640 Old 05-19-2014, 08:13 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
His neighbors will feel 130 plus dB's.
chalugadp is offline
post #484 of 640 Old 05-19-2014, 10:50 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5243
Originally Posted by jbrown15 View Post
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #485 of 640 Old 05-19-2014, 11:10 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
there is just some so wrong with that picture. double stack subs in the foreground...double stack of heads in the background! eek.gif
Listen. It's All Good.
LTD02 is offline
post #486 of 640 Old 05-19-2014, 11:24 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
jbrown15 is offline
post #487 of 640 Old 05-19-2014, 11:26 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
Originally Posted by basshead81 View Post
Or I could get the plans emailed to you, then all you have to do is find a CNC shop that'll cut them up for you!...lol wink.gif
LTD02 likes this.
jbrown15 is offline
post #488 of 640 Old 05-19-2014, 11:54 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
The CNC makes the process look ridiculously easy.
gpmbc is online now
post #489 of 640 Old 05-20-2014, 12:23 AM - Thread Starter
jbrown15's Avatar
Liked: 1993
It sure makes it a lot easier on someone that doesn't have much experience building stuff. The best part is the all of the pieces are perfectly cut to size, no need to worry about a piece being a 1/8th or a 1/16th out because you didn't account for the blade width if you were cutting them yourself on a table saw. smile.gif
jbrown15 is offline
post #490 of 640 Old 05-20-2014, 12:45 PM
jlpowell84's Avatar
Quoted: 1614 Post(s)
Liked: 712
Why not keep your two SubM HP's and just built two flat pack sealed 18's from Erich? The UM18-22 is only about 6 weeks from being available. You could buy two of those, plus the flat packs and an INuke 6000 for a little over a grand.
Yea that will be the future route when adding more. To be honest I get A LOT already in my room with what I have. I am not sure it would be such a big improvement with a couple more subs you know. Really no space to put them anywhere but up front next to each Submersive. Although I could build a skinny tall and long cab for behind the couch smile.gif
jlpowell84 is offline
post #491 of 640 Old 05-21-2014, 03:00 PM
LTD02's Avatar
Liked: 2578
should coordinate with gorilla83 and maybe urapnes1.
LTD02 is offline
post #492 of 640 Old 06-12-2014, 12:40 AM - Thread Starter
jbrown15's Avatar
Liked: 1993
So I finally got the last two subs setup tonight, and hopefully I can take some measurements this weekend and get them all dialed in.
jbrown15 is offline
post #493 of 640 Old 06-12-2014, 12:43 AM - Thread Starter
jbrown15's Avatar
Liked: 1993
I guess I should have included the pictures, damn new forums!
Name:	photo 1 (15).jpg
ID:	110257   Click image for larger version
Name:	photo 3 (13).jpg
jbrown15 is offline
post #494 of 640 Old 06-12-2014, 05:09 AM
WarrenBerry's Avatar
Quoted: 40 Post(s)
Liked: 48
How do they sound? Big diffrence?
WarrenBerry is online now
post #495 of 640 Old 06-12-2014, 10:12 AM - Thread Starter
jbrown15's Avatar
Liked: 1993
Crazy!....lol
When are you back from vacation to come over and hear them?
jbrown15 is offline
post #496 of 640 Old 06-12-2014, 10:16 AM
wyattroa's Avatar
Quoted: 165 Post(s)
Liked: 117
I cant see your mains.. Where did they go? Did you put the, off to the side for the picture? Lol. Man those look great!
Sub build http://www.avsforum.com/forum/155-di...et-r-done.html
Center - JBL LC2
Mains - JBL L820
Surrounds - JBL L820
Sub - Dual UXL'18 enclosures,iNuke6000dsp
wyattroa is offline
post #497 of 640 Old 06-12-2014, 10:20 AM
LTD02's Avatar
Liked: 2578
AWESOME ! ! !
Stability?
Cone motion peaks around 21hz or so in your build, so hitting the subs with some 21hz "bursts" and monitoring for any rocking would provide some useful data.
LTD02 is offline
post #498 of 640 Old 06-12-2014, 10:26 AM
Willie's Avatar
Quoted: 75 Post(s)
Liked: 106
Looks awesome! Betting it sounds awesome too.
Willie is offline
post #499 of 640 Old 06-12-2014, 10:28 AM
LTD02's Avatar
Liked: 2578
looks like there is room to upgrade to mtm 12" mains. :-)
Name:	jbrown15 mockup with 12 inch drivers.png
LTD02 is offline
post #500 of 640 Old 06-12-2014, 10:50 AM - Thread Starter
jbrown15's Avatar
Liked: 1993
LOL.... that looks awesome John. I'll let you know about the rocking when I get a chance to really push them. I'll try to take some measurements tonight.
I'm actually talking with tuxedocivic about doing a DIY build for a WTW build using 15's
jbrown15 is offline
post #501 of 640 Old 06-12-2014, 04:50 PM
Dank1209's Avatar
Looking good mr. Brown.
Dank1209 is offline
post #502 of 640 Old 06-12-2014, 07:12 PM
LTD02's Avatar
Liked: 2578
15's?
dual 12's have the area of an 18.
at the crossover point, subs and mains are pulling equally, so 4 + 3 = 7 18's covering bass at 80hz. :-0
BUT, if you want to go bigger...
...i support that. ;-)
LTD02 is offline
post #503 of 640 Old 06-12-2014, 07:21 PM
LTD02's Avatar
Liked: 2578
15's :-)
Name:	jbrown15 mockup with 15 inch drivers.png
LTD02 is offline
post #504 of 640 Old 06-12-2014, 07:26 PM
Quoted: 40 Post(s)
Liked: 48
Were not using that stage during the gtg are we?
post #505 of 640 Old 06-12-2014, 10:50 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
Well I'm certainly not taking it out of the room for the GTG....lol
Why?
jbrown15 is offline
post #506 of 640 Old 06-12-2014, 10:52 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
15's?
I was thinking 15's because I could use the SEOS-15 and a BMS 4550 compression driver. The combo of waveguide and CD can be crossed around 800-850hz to the 15's. And just like your photoshop I'd port the top and bottom on the speaker cabinets. basically a bigger version of the JTR 228's and 212's, what are your thoughts about that?
jbrown15 is offline
post #507 of 640 Old 06-13-2014, 07:44 AM
Point Source
beastaudio's Avatar
Quoted: 3517 Post(s)
Liked: 2835
I wouldn't go down to 800hz on the CD. 850 should be ok though.
beastaudio is offline
post #508 of 640 Old 06-13-2014, 08:27 AM
Quoted: 40 Post(s)
Liked: 48
Why?
Wall of sound looks heavy.
Let me know if you want a hand getting the gtg ready
post #509 of 640 Old 06-13-2014, 02:14 PM
LTD02's Avatar
Liked: 2578
"I was thinking 15's because I could use the SEOS-15 and a BMS 4550 compression driver. The combo of waveguide and CD can be crossed around 800-850hz to the 15's. And just like your photoshop I'd port the top and bottom on the speaker cabinets. basically a bigger version of the JTR 228's and 212's, what are your thoughts about that?"
if you are not going with something that is already designed and don't mind spending a little bit more money, you might take a look at using a larger compression driver and shooting for a lower crossover point.
paul (pnw) made a very nice speaker with the 18 Sound ND1460A w/ XT1464 horn. he might have some tips.
http://www.htguide.com/forum/showthr...-a-10-quot-MTM
with the right 15's, perhaps the 15nd930's as used in the Unity U215, i suspect that you could make one heck of a speaker.
LTD02 is offline
post #510 of 640 Old 06-13-2014, 09:05 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
Thanks for the heads up on that compression driver, I wanted to use a 1.4" CD to start with (BMS 4593) but at $700 a piece it was a little too steep for my blood. But that ND1460A is half the price so that might be a really nice option.
How do you think the XT1464 would compare to the SEOS-15?
I was thinking about using the Eminence KAPPALITE 3015 15" driver, seems like a great driver for a good price at $260ea.
jbrown15 is offline
