LTD-M18 Sub Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #91 of 640 Old 02-05-2014, 05:44 PM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
"I will be interested to see how impactful these monsters are going to be."
Me too, chaluga!
blah450 is offline
post #92 of 640 Old 02-05-2014, 06:03 PM - Thread Starter
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
Originally Posted by chalugadp View Post
Here is the drawing with measurements
So I've done a few re-measurements Donny and I have enough room to push these to 78" tall, otherwise 32" wide and 22" deep are still the other dimensions.
jbrown15 is offline
post #93 of 640 Old 02-05-2014, 06:03 PM
notnyt's Avatar
Quoted: 2773 Post(s)
Liked: 2561
notnyt is offline
post #94 of 640 Old 02-05-2014, 06:04 PM
notnyt's Avatar
Liked: 2561
They're going to rock being on that narrow of a base and having a driver that high in the air.
Also looking at the 3d model, you have 4 of the braces listed, but one will be a different size since it will not be up against the port. Keep an eye on that.
EDIT: 3 will be a different size, the size you listed doesn't account for the port.
notnyt is offline
post #95 of 640 Old 02-05-2014, 06:07 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
You think so? I talked to LTD02 about this when we were coming up with the design, he didn't seem too concerned about the cabinets rocking. We could also mount the drivers a little lower in the cabinets too, the bottom one could be mounted near the bottom and the top driver could be installed closer to the middle of the cabinets.
jbrown15 is offline
post #96 of 640 Old 02-05-2014, 06:10 PM
notnyt's Avatar
Liked: 2561
My sealed boxes rocked with heavier drivers mounted lower in about the same depth of a cab. Did it impact sound? Who knows. I can almost guarantee you that those will in fact rock at higher excursion levels and low frequency.
notnyt is offline
post #97 of 640 Old 02-05-2014, 07:19 PM
Bill Fitzmaurice's Avatar
Liked: 5684
It did. The driver creates sound by literally pushing and pulling against the air in front of the cone. If some of that energy is used to push the cabinet back and forth instead of pushing the air back and forth less sound is produced. If I was building a sub with two large drivers I'd make it dual opposed, which will eliminate any rocking and lost SPL.
Bill Fitzmaurice is offline
post #98 of 640 Old 02-05-2014, 07:20 PM
notnyt's Avatar
Liked: 2561
True, but it's a sealed box and still creating the same amount of displacement/pressure change in the room.
EDIT: and yes, I know it affected the sound, but I meant to a noticeable degree.
notnyt is offline
post #99 of 640 Old 02-05-2014, 07:36 PM
Liked: 5684
If the cone was moving back and forth by 15mm and the box was rocking back and forth by 3mm there'd be a fair amount of SPL loss.
post #100 of 640 Old 02-05-2014, 07:41 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1531
All four braces are the size listed. Me knows my way around sketchup cool.gif
chalugadp is offline
post #101 of 640 Old 02-05-2014, 07:42 PM
notnyt's Avatar
Liked: 2561
How does that work if 3 braces go front to port, and one goes front to back?
notnyt is offline
post #102 of 640 Old 02-05-2014, 07:45 PM
chalugadp's Avatar
Liked: 1531
There won't be any rocking except maybe in jbs theater by things other then subwoofers tongue.gif
Box will be attached to wall.
post #103 of 640 Old 02-05-2014, 07:48 PM
notnyt's Avatar
Liked: 2561
Well, that will sure solve the problem. Hopefully those are some concrete walls smile.gif
notnyt is offline
post #104 of 640 Old 02-05-2014, 07:50 PM
steve nn's Avatar
Liked: 433
Cool it's back! Do you guys have any plans to brace the top and bottom?. a couple dowels top to bottom?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #105 of 640 Old 02-05-2014, 07:57 PM
chalugadp's Avatar
Liked: 1531
Cuz all go front to port. I haven't included the 1 by 1 support braces . Only the plywood needed to be cut. The nice birch plywood jbs getting .
post #106 of 640 Old 02-05-2014, 07:58 PM
chalugadp's Avatar
Liked: 1531
Will be lots of vertical 1 by 1 support pieces. Jb is going to be cutting those by his bare hands cool.gif
post #107 of 640 Old 02-05-2014, 08:00 PM
steve nn's Avatar
Liked: 433
cool.gif I want a vid of that lol. seriously!!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #108 of 640 Old 02-05-2014, 10:37 PM
LTD02's Avatar
Quoted: 2527 Post(s)
Liked: 2869
as for rocking, the reason that I wasn't concerned in this particular case is what I mentioned in post #2: the low ceiling joists could offer a method for bracing the cab. but then it was pointed out that the cabs could be bolted to the wall. so long as the wall is quite sturdy, that should solve that.
anyway, a question was asked about reconfiguring for two cabs again, with some additional limitations.
these would be about 38" tall, 32" wide, 22" deep. 3" slot port that is 40" long (one brace down the middle). net cab volume roughly 11 and change. tuning roughly 15-16hz.
Listen. It's All Good.
LTD02 is offline
post #109 of 640 Old 02-05-2014, 10:59 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
So with the cabinet now being smaller the port only needs to be 3" high?
jbrown15 is offline
post #110 of 640 Old 02-06-2014, 05:58 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6519
basshead81 is offline
post #111 of 640 Old 02-06-2014, 05:59 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
Originally Posted by basshead81 View Post
Bass you're back!!! Excellent.
Yes I have gone a little crazy!...lol
jbrown15 is offline
post #112 of 640 Old 02-06-2014, 06:10 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
doublewing11 is offline
post #113 of 640 Old 02-06-2014, 06:51 PM
steve nn's Avatar
Liked: 433
JB> Yes I have gone a little crazy!...lol
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #114 of 640 Old 02-06-2014, 07:07 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
LOL..... Steve you're always good for a laugh! haha
So I had to change the plans up a little after realizing how much of a pain in the a$$ it was going to be to get two monster subs into my basement with the only access by going threw the house. So I've decided on four large single ported cabinets. Each one will be 32" wide, 22" deep and 40" high.
steve nn likes this.
jbrown15 is offline
post #115 of 640 Old 02-06-2014, 07:44 PM
steve nn's Avatar
Liked: 433
Lol.. hey jb.. Yeah I saw that! 4 is going to be a job but with chals help and the tool situation it should work out just fine. It’ll help you out in other ways also like you just suggested. Heck you never know, maybe you’ll part them differently at some point.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #116 of 640 Old 02-06-2014, 08:04 PM
chalugadp's Avatar
Liked: 1531
post #117 of 640 Old 02-06-2014, 08:29 PM - Thread Starter
jbrown15's Avatar
Liked: 1995
LOL.... I think best case scenario is I realize three is enough and give you the forth!..lol
jbrown15 is offline
post #118 of 640 Old 02-06-2014, 08:35 PM
chalugadp's Avatar
Liked: 1531
Sounds good
post #119 of 640 Old 02-06-2014, 09:01 PM
LTD02's Avatar
Liked: 2869
"So with the cabinet now being smaller the port only needs to be 3" high?"
I was trying to figure out what you meant...yes. the cross sectional area of the port is on a 'per driver' basis.
3" x ~19" or whatever it works out to will be fine for each of these cabs which are loaded with one driver each.
if the cab size was doubled and the drivers were doubled, the port size cross sectional area would be double (it would be as if the two ports were simply combined into one big one).
LTD02 is offline
post #120 of 640 Old 02-06-2014, 09:05 PM
LTD02's Avatar
Liked: 2869
in the monster cab, the port was going to be about 4" x 29" or so = 116 sq inches cross sectional area for two drivers.
in each of the smaller cabs, the port is going to be about 3" x 19" or so = 57 sq inches cross sectional area for one driver.
that is roughly the same amount of cross sectional area 'per driver' in both instances, thus they will perform pretty much the same from an air flow perspective.
LTD02 is offline
