LTD-M18 Sub Build - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
Old 03-05-2014, 10:10 AM - Thread Starter
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
I have a few pieces of bracing that I still need to throw in them, but there is some good bracing in them too.
Dank1209 likes this.
jbrown15 is offline
Old 03-05-2014, 10:31 AM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
roger.
Listen. It's All Good.
LTD02 is offline
Old 03-05-2014, 11:00 AM
Point Source
beastaudio's Avatar
Quoted: 3500 Post(s)
Liked: 2831
Im thinking I want to scoop some linacoustic too actually. Right now I have 5 2x4x2" panels behind my front stage. I am sure it will benefit by treating the entire front wall instead, but I have no idea how much benefit that would actually cause. My other though was just completely removing the sheetrock and revert back to stud with insulation in between, then linacoustic over that and call it a day.... Better decide pretty quick before I stack my bad boys in there...
beastaudio is offline
Old 03-05-2014, 11:05 AM - Thread Starter
jbrown15's Avatar
Liked: 1993
Doublewing had the Erskine Group do you the design and treatments for his room and they didn't even use bass traps up front which has me think about doing the same thing. I mean they would know better then I would, so if that's the case I'll pick up some Linacoutics to line the walls and ceiling behind my screen and I'll just install bass traps at the back of the room.
jbrown15 is offline
Old 03-05-2014, 12:16 PM
Point Source
beastaudio's Avatar
Liked: 2831
Woo, just found a place just down the road that has the 2 inch CertainTeed. 50 foot roll will leave me with 2 extra feet to cover my front wall, and then sides and ceiling up the the screen. Might just go ahead and scoop that this afternoon biggrin.gif The 1.5" is a little cheaper, but why not go with 2 since they have it!
Old 03-05-2014, 12:35 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
Last night I was looking thru some different threads on Linacoustic and I read a few times that you don't want to use the 2" stuff, 1" and 1.5" was better to use.
jbrown15 is offline
Old 03-05-2014, 12:43 PM
Point Source
beastaudio's Avatar
Liked: 2831
Reason being?
Old 03-05-2014, 12:44 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
One inch Linacoustic RC + 3mm poly + one inch Linacoustic RC.......you don't want to absorb too much HF......3mm poly does that ie. reflective.
It's a slamdunk going this route.
doublewing11 is offline
Old 03-05-2014, 01:40 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
The eagle has landed!
LTD02 likes this.
jbrown15 is offline
Old 03-05-2014, 02:46 PM
Point Source
beastaudio's Avatar
Liked: 2831
Nice dude!
Last question and I won't derail your thread anymore man smile.gif Where does one find "3mm poly" I wouldn't think it would reflect anything really!?!? Interesting.Still might just do the single layer of 1 1/2" all around and call it. Shouldn't be too much of a difference at that point I wouldn't think.
Old 03-05-2014, 03:04 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
Its my thread so ask all you want and don't worry about derailing the thread Brandon! smile.gif
jbrown15 is offline
Old 03-05-2014, 03:05 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
I would think any local hardware store should have 3mm poly.
jbrown15 is offline
Old 03-05-2014, 03:07 PM
Point Source
beastaudio's Avatar
Liked: 2831
Thanks man! I went ahead and asked in the Corinthian thread as well though biggrin.gif
I am assuming still this is 3mm thick polyester fabric? Or what?
Old 03-05-2014, 05:20 PM
Quoted: 229 Post(s)
Liked: 938
Nice dude!
Lowes, Home Depot............
Look in the mortar section................concrete section.  Sheets come in varying sizes ie. 16 X 25 ft and 6mm, 4mm, 3mm.................mainly used as moisture control for crawlspaces etc.
You would be surprise how that poly helps...................speaking of poly, I have five sheets of 8 X 4 Quest Perfsorber panels that cost close to $800 per sheet!  It looks to me like all it is are varying layers of dense insulation and duct-tape type material sandwiched between layers.  My room is airy and smooth across FS...................whatever it is..............those experts do know their acoustical recipes.............;)
Old 03-05-2014, 05:22 PM
Quoted: 229 Post(s)
Liked: 938
Plastic.................think trash bag...........visqueen..........................not a fabric..........
Thought I had a picture with the layer of 3mm poly........and not for a better term, 20 X 25 FT sheet of trash can plastic!
Here it is....................http://www.homedepot.com/p/Husky-10-ft-x-25-ft-Black-3-5-mil-Polyethylene-Sheeting-RSHK3510-25B-U/100651803
Old 03-05-2014, 06:14 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
Man these things are beastly!
jbrown15 is offline
Old 03-05-2014, 07:06 PM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
blah450 is offline
Old 03-05-2014, 07:33 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Hook em up !!!
Mines rumbling already !!!!
chalugadp is offline
Old 03-05-2014, 08:00 PM
steve nn's Avatar
Liked: 433
I revisited your graph of a single and to think you have four. Me thinks your driver issue is over. tongue.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 03-05-2014, 08:14 PM
Point Source
beastaudio's Avatar
Liked: 2831
No kidding, and those things look so tiny next to the LTD-m18 cabs! Wow. Puts it into perspective for me just how big those boxes are! Nicely done bro!
Old 03-05-2014, 10:01 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
Haha I totally got the eye roll from the wife when she saw them...lol
jbrown15 is offline
Old 03-05-2014, 11:55 PM
LTD02's Avatar
Liked: 2577
LOL.
LTD02 is offline
Old 03-05-2014, 11:59 PM
LTD02's Avatar
Liked: 2577
"I revisited your graph of a single and to think you have four."
i think the ports ended up a little longer, so the tuning might be a hair lower than that graphic. either way, absolutely massive spl is on the way.
LTD02 is offline
Old 03-06-2014, 05:25 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Beast, you would benefit greatly from some additional room treatments! Do you currently have any bass traps? I would not recommend using just the 1.5" stuff that you were referring to, as that provides very little effective absorbing below the Schroder Frequency, and possibly none at all. You need, ideally, at least 4" total, with an air gap. Do you walls currently have any panels? When I added my two 2' by 4' four inch panels with a four inch air gap along each side wall, front & rear wall, and my cloud ceiling panels, the improvements were so great, it really blew me away. I am also using some home made, temporary, ugly pink fluffy Insulation cut into triangles and stacked into each corner, and those have really tightened up the bass response in my room.
Martycool007 is offline
Old 03-06-2014, 08:27 AM
Point Source
beastaudio's Avatar
Liked: 2831
It might be prudent to know all of one's room treatments before suggesting they need more, bro smile.gif I have 4 tri-traps, 4 4 inch thick panels on the rear wall and about a dozen 2 inch panels on side walls that do an excellent job with secondary and tertiary reflections. The front wall already has 5 additional 2x4 panels. My response is good, and the bass is clean. The idea for the linacoustic is to just improve on what I have currently, while also helping with reflections behind the A-T screen.
Old 03-06-2014, 08:43 AM
Quoted: 280 Post(s)
Liked: 176
Sorry! My mistake! I got the impression that you only had two panels on your front wall, and boy, I was way off!
Old 03-06-2014, 08:53 AM
steve nn's Avatar
Liked: 433
beast> No kidding, and those things look so tiny next to the LTD-m18 cabs!
They look like little 10 or 12"s.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 03-06-2014, 09:05 AM - Thread Starter
jbrown15's Avatar
Liked: 1993
I was going to run tri-corner bass traps on my front wall but now I'm rethinking that. Doublewing had the Erskine Group design his room and he following the designs to a T and they said to only use 1" Linacoustics doubled up on the front wall and ceiling behind his false wall/screen.
I would install tri-corner bass traps in the back of the room and a few 4" bass trap panels on the back wall behind my seating though.
jbrown15 is offline
Old 03-06-2014, 09:21 AM
Point Source
beastaudio's Avatar
Liked: 2831
Yea, I suggest that for sure. I have that right now, with just one corner being non-existent with a little hall running off the rear left of my theater. The rest is spot on though, corner trap and 4 inch panels is exactly what I have and it works quite well smile.gif
Old 03-06-2014, 08:28 PM - Thread Starter
jbrown15's Avatar
Liked: 1993
Wow, I got these first two monsters working tonight and even though I'm running them pretty lightly while they break in a little they pound.
LTD02 likes this.
jbrown15 is offline
