The new V-10 Volt ported coax for use as mains? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-23-2013, 07:00 AM - Thread Starter
dtsdig's Avatar
Quoted: 828 Post(s)
Liked: 914
Now that these have hit DIYSoundGroup, what are the thoughts on using the 8" or 10" models for mains; on stands so that the height is correct?
dtsdig is online now
post #2 of 11 Old 12-23-2013, 07:26 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2573
they would work just fine.
Listen. It's All Good.
LTD02 is offline
post #3 of 11 Old 12-23-2013, 07:33 AM
LTD02's Avatar
Liked: 2573
winsid is showing a -3db point of around 120hz for the sealed version in a 12" x12" x 12" cab. that seems a little high and a little small. might do a little better than that in room. the ported version will extend lower.
LTD02 is offline
post #4 of 11 Old 12-23-2013, 09:45 AM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
The 10" can be either sealed or ported and work fine. The 8" should be ported.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #5 of 11 Old 01-19-2014, 12:58 AM
raynist's Avatar
Quoted: 1256 Post(s)
Liked: 1194
Erich, do you have a flat pack for the ported 10 inch box?
Also, do you know what the crossover is for the 8 and 10?
Can the compression drivers be upgraded?
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is offline
post #6 of 11 Old 01-19-2014, 08:25 AM
Erich H's Avatar
Liked: 1768
I won't be getting a flat pack for the ported 10 until I know the approximate size most people would want for that model.
Yes, the crossover is completed for the 8 and the 10.
I'm not sure why you would want to upgrade the compression driver. The one that's used can easily keep up with the woofer without breaking a sweat, and it sounds nice and smooth doing it. It's small because it uses neo magnets, but it can handle higher volumes than most people would ever listen to in their house.
They just started shipping out around a week or so ago. Once people build and hear them, you'll see that the compression driver was a good choice.
saginawjuggalo likes this.
Erich H is offline
post #7 of 11 Old 01-19-2014, 08:27 AM
tuxedocivic's Avatar
Quoted: 1905 Post(s)
Liked: 1725
Did Matt post measurements anywhere? Just curious.
Ryan
tuxedocivic is online now
post #8 of 11 Old 01-19-2014, 08:32 AM
raynist's Avatar
Liked: 1194
I am looking for cheaper surrounds to use with my JTR 228 LCR's. Do you know what the crossover frequency is for the 8's?
I am currently looking at the V-8's, V-10, and Fusion 8 Alchemy. Would one perform better than the others?
raynist is offline
post #9 of 11 Old 01-19-2014, 08:59 AM
Erich H's Avatar
Liked: 1768
Crossover point is around 2khz for the V-8. Any of those 3 speakers would be good. Some people like to use coaxials for surrounds though.
Erich H is offline
post #10 of 11 Old 01-19-2014, 10:33 AM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
gpmbc is online now
post #11 of 11 Old 01-19-2014, 12:46 PM
raynist's Avatar
Liked: 1194
If they would all perform pretty much the same I would probably go with the coaxial 8 as it has better placement flexibility.
I am planning on using one if these designs as surrounds for my JTR 228 LCR's.
raynist is offline
