UXL-18 Subwoofer driver Group Buy (is now closed out/over/done/fini) !!!! - Page 28 - AVS Forum | Home Theater Discussions And Reviews
post #811 of 1399 Old 03-03-2014, 03:52 PM
steve nn's Avatar
Liked: 433
It always helps to input four drivers when applying 8000 watts. Boy do I impress myself at times wink.gif I want suppa!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #812 of 1399 Old 03-03-2014, 04:46 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Originally Posted by fuzz092888 View Post
This is what BBpro is giving me for the UXL in a 4 cubes with 2000 watts.
Seems to me, both software programs are close enough that we can both say a 10 hz filter is needed to protect drivers.
Looks good.................................
doublewing11 is offline
post #813 of 1399 Old 03-03-2014, 04:50 PM
Quoted: 229 Post(s)
Liked: 968
Could it be dementia? You certainly are close to retirement age.......................
Soon we'll all be feeding you with a Gerber spoon..............mushed bananas on menu!  :p
post #814 of 1399 Old 03-03-2014, 04:54 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
na you won't need a high pass filter on sealed. There's no content that is going to be reference level at that low frequency, and going 1 mm past xmax won't matter even if there was.
JWagstaff is offline
post #815 of 1399 Old 03-03-2014, 05:03 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Soon we'll all be feeding you with a Gerber spoon..............mushed bananas on menu!  tongue.gif
Lol
gpmbc is online now
post #816 of 1399 Old 03-03-2014, 05:04 PM
fuzz092888's Avatar
Quoted: 40 Post(s)
Liked: 100
I would say that depends on the slope of the HPF. For a shallower slope, 15hz wouldn't make a huge difference audibly, but would provide a little extra protection.
Depends on if he decides to add EQ to his subs to EQ them flat. Then it's possibly to overdrive the subs with the right content. If there's no EQ added to get them flat down to 10 or whatever, then he's probably good without them.
fuzz092888 is offline
post #817 of 1399 Old 03-03-2014, 07:13 PM
Quoted: 229 Post(s)
Liked: 968
Just stuck in a second order Butterworth.............no excursion issues.
post #818 of 1399 Old 03-03-2014, 07:21 PM
steve nn's Avatar
Liked: 433
WOW! now that's impressive thinking there douby, nice job.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #819 of 1399 Old 03-03-2014, 08:03 PM
Quoted: 229 Post(s)
Liked: 968
Thanks my winisd guru!  :D
post #820 of 1399 Old 03-04-2014, 05:11 AM
fuzz092888's Avatar
Quoted: 40 Post(s)
Liked: 100
What's the output look like after adding the filter?
post #821 of 1399 Old 03-04-2014, 05:22 AM
fuzz092888's Avatar
Quoted: 40 Post(s)
Liked: 100
Looks like my first of two will be here tomorrow.
post #822 of 1399 Old 03-04-2014, 09:18 AM
Spiderm0n's Avatar
Would these be good screws to use?
http://www.parts-express.com/8-x-1-1-2-deep-thread-pan-screws-head-black-100-pcs--081-430
My Gear: Sony VPL-HW40ES, 130" Spandex Screen, Onkyo TX-NR818, Fusion 12 Tempests (LCR), Axiom M3 & M2 Surrounds, Mach 5 UXL 18 Subwoofer
My theater: Escape from New York theater build
Spiderm0n is offline
post #823 of 1399 Old 03-04-2014, 09:54 AM
fuzz092888's Avatar
Quoted: 40 Post(s)
Liked: 100
I don't see why not, as long as your baffle is double thick. Personally I like to use the machine screws with the inserts, but they ain't for everybody.
Spiderm0n likes this.
post #824 of 1399 Old 03-04-2014, 10:02 AM
steve nn's Avatar
Liked: 433
A old trick if you want extra measure for a heavy driver is to glue 3/4 ply blocks or a ring on the inside of the baffle for extra material to screw into.. that being that, like fuzz says it isn't the only approach.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #825 of 1399 Old 03-04-2014, 11:07 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1660 Post(s)
Liked: 1477
I have a 90lb subwoofer hanging down and didn't want to have any issues so I bought some steel bars off of Amazon, cut it with a reciprocating saw, and then drilled and tapped the holes. If you are interested, I can let you know what I ordered and did in more detail. But I'll tell you this, unlike regular screws or tee nuts, I don't have to worry about the subwoofer coming loose or having trouble getting the screws out.
David
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is online now
post #826 of 1399 Old 03-04-2014, 11:40 AM
Spiderm0n's Avatar
Thanks guys. I have Erich's 4cu ft sealed flatpack, which has a double thick 1.5" front baffle, so I guess I'm good to go.
post #827 of 1399 Old 03-04-2014, 12:09 PM
dece870717's Avatar
I used a 4.0 cu ft flat pack from parts express thats meant for the Dayton HO 18, note for anyone else going this route, either cut the baffle hole 1/4 inch bigger if you want to keep the rubber outer ring on or about 1/8inch if you want to easily drop it in without it, cause I had to actually hammer around the outer rim to get the thing in all the way around and used drywall screws to fully push the subwoofer down against the baffle. I hope to God there is never a reason I have to remove this sub from this enclosure cause it'll suck!
dece870717 is offline
post #828 of 1399 Old 03-04-2014, 12:38 PM
Quoted: 229 Post(s)
Liked: 968
Sure hope you received the SI-18FP.......if not, you'll have issues.
post #829 of 1399 Old 03-04-2014, 12:42 PM
Spiderm0n's Avatar
Woofer Cut Out - Stereo Integrity 18" woofer biggrin.gif.
Yes, I was a bit worried about this....
post #830 of 1399 Old 03-04-2014, 03:01 PM - Thread Starter
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
Spider...those screws above will work fine. I have only advised going with pocket-hole screws similar to those because the head is a little wider,
almost as if a washer is integrated into the head of the screw. You can find pocket hole screws at any Lowes or Home Repo.
blah450 is offline
post #831 of 1399 Old 03-04-2014, 03:17 PM
steve nn's Avatar
Liked: 433
Yeah I thought that myself once when I didn't add the backing and my 50 pound mae-x took a dive in a move, your driver is lighter though. I also have always used the full thread screws.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #832 of 1399 Old 03-04-2014, 03:19 PM
Spiderm0n's Avatar
Blah, those sound even better. So I don't need a Kreg pocket jig to use pocket hole screws? PIus I'd rather get screws from my local Lowes anyway!
post #833 of 1399 Old 03-04-2014, 03:22 PM
Spiderm0n's Avatar
I thought the UXL-18 was 65 pounds?
post #834 of 1399 Old 03-04-2014, 03:25 PM
Quoted: 229 Post(s)
Liked: 968
You are good to go..........
If you have any wood working skills at all..... Use these for a better look and grip...,
post #835 of 1399 Old 03-04-2014, 03:34 PM
steve nn's Avatar
Liked: 433
Uhh! you have the UXL, yes extra measure is definitely warranted if you go the reg wood screw method. From looking at it closely though, I would go another option since your screw heads show if no mounting ring is used.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #836 of 1399 Old 03-04-2014, 03:37 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
I know data-bass.com shows it as 65lbs, but I seem to recall someone saying that they are actually 74lbs. I could be wrong of course smile.gif
jbrown15 is offline
post #837 of 1399 Old 03-04-2014, 03:43 PM - Thread Starter
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
jbrown....from Mark...shipping weight is 72lbs (32kg)....unless he recently changed his packaging. I believe driver weight remains 65#.
blah450 is offline
post #838 of 1399 Old 03-04-2014, 03:45 PM
jbrown15's Avatar
Liked: 1995
jbrown15 is offline
post #839 of 1399 Old 03-04-2014, 03:56 PM - Thread Starter
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
No Kreg kit needed if you are just using the screws as regular screws to fasten driver to baffle. I would recommend pre-drilling the baffle for the screws...but don't overdo it with the pilot hole width. Just use a regular bit. You can even do it with driver in place IF you have a steady enough hand (that sounds a bit weird).
In post 834 above, Double is recommending a nice alternative. Gotta make sure those inserts line up just right with the driver holes. It may be advisable to glue those inserts in when inserted (that sounds a little weird, too).
The inserts he pictured can also be found at Lowes.
If you really want to use the socket-head cap bolts he pictured, and want to make the mount ridiculous...put the insert in to the baffle from the interior of the box...then pull-out will not be be an issue (that sounded even weirder)...biggrin.gif
blah450 is offline
post #840 of 1399 Old 03-04-2014, 04:04 PM
steve nn's Avatar
Liked: 433
In post 834 above, Double is recommending a nice alternative. Gotta make sure those inserts line up just right with the driver holes. It may be advisable to glue those inserts in when inserted (that sounds a little weird).
Yeah way back when I bought a kit that they didn't have lined up right and it turned out to be a real pain in the arss! They also said nothing about gluing which would have been nice if lined up correctly. rolleyes.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
